Nailing Utility Trim Under Window For Vinyl - Windows, Siding and Doors - Contractor Talk
Old 07-16-2012, 05:30 AM   #1
3rd Generation
Nick R's Avatar
Rewards Points: 391
So, I just rehabbed a dormer that had a lot of bad flashing issues/ 25 year old vinyl and two layers of roofing. Roof replaced, step replaced, siding replaced, everything nice. Then I replaced the window with a new construction vinyl with J channel built in. Double 4" vinyl siding going on later. I flashed the window with flashmate sticky tape on the bottom before window went in, then cualked sides and top of back of flange, set window, nailed and taped sides and top of window flange with the flashmate.
Question is, when I went to install the siding, I wanted to use my new shiny snap lock tool and utility trim under the window for the piece of siding that got the nailing flange cut off, and I had to nail the utility trim under the window through the flange and flashing. I didn't like doing it, but I only put a few nails toward the center, trying to stay away from the side corners. I figured the flashmate will hopefully seal against the nails like I/W. Is that how the real siding guys do it when using a window like this?
Nick R is offline
Old 07-16-2012, 12:07 PM   #2
larryb's Avatar
Trade: Retail and insurance repair claims consultant
Rewards Points: 258
Re: Nailing Utility Trim Under Window For Vinyl
I always nailed vinyl sill/utility trim under and over windows and over doors over lath after channeling was installed and made sure to allow for expansion and contraction when nailing. Snap locked siding into sill/utility trim which always left a nice finished look and never once had a problem.
3RSystems, LLC - Storm Damage Contractor Insurance Claim Sales and Process Training, Hail Reports, and loss report analysis.
larryb is offline
Old 07-16-2012, 01:49 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
if your worried about nailing up so high you could take a strip of aluminum say 3'' wide,slide it all the way in to the u/t
that will effectively extend the nailing flange about an inch and a half lower
the cut in the siding panel will control side to side movement
i don't bother with snap locking window cuts 3'and under
Tom Struble is offline
Old 07-16-2012, 05:25 PM   #4
DavidC
DavidC's Avatar
Rewards Points: 2,006
For most windows we snap the undersill on the siding panel before install. IOW, no nails into the flashing tape. Make sure to place a nail close to the window on either side and I'm assuming that you would never put a seam directly under a window.
Related, you will find an excellent flashing detail in the JLC Field Guide for the J channel sides pieces.
Good Luck
www.CookContractingLLC.com
DavidC is offline
New construction Window bow/warp. Help typer0186 Windows, Siding and Doors 7 06-14-2012 09:38 AM
Lead check test kits and cedar trim VinylHanger Lead RRP Discussion 11 02-02-2012 08:36 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
My custom window trim Bill Finish Carpentry 46 12-16-2009 09:25 PM
Screwing aluminum trim to window. Patrick Windows, Siding and Doors 27 07-08-2008 03:44 PM
