Minimum Ceiling Height For 7' Garage Door - Windows, Siding and Doors - Contractor Talk
Old 05-31-2016, 12:55 PM   #1
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Minimum ceiling height for 7' garage door
Im estimating a project but hitting a wall with Homeowner. Homeowner wants to GC a split level garage project, and its clear this project is way over his head. We are inserting a new floor system in the existing 158 ceiling for a new loft. Architect plans dont account for garage door minimum ceiling height and head room in loft. I need to keep the new ceiling height as low as I can to clear existing drop steel beam in upper loft.
I see some doors can be set at 75 but is that to sheetrock or framing? Im losing an 1 for two layers of 5/8 rock.
festerized is offline
Old 05-31-2016, 01:04 PM   #2
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Re: Minimum Ceiling Height For 7' Garage Door
I like them 8 1/2 ft. low headroom kit will give you few more inches if an opener is being used.
supersealconstruction.com
superseal is offline
Old 05-31-2016, 01:11 PM   #3
David Festa
festerized's Avatar
I do the same 13 for standard door openers but in this case I need a low clearance system
Old 05-31-2016, 01:18 PM   #4
Anti-wingnut's Avatar
Rewards Points: 3,430
You will still have a 8' foot finished ceiling?
Anti-wingnut is offline
Old 05-31-2016, 03:03 PM   #5
David Festa
festerized's Avatar
I need the lowest ceiling possable, 7'5" or lower would be ideal. Archy has bottom of W8x58 set at 6'8" which only gives me 6' 10 3/4" ceiling height, keep in mind steel is getting 2x10 cap and 2x8 flush joist. I could ask archy to change flush 2x8 16" OC to 2x6 12" OC but that will give crappy R value
Minimum ceiling height for 7' garage door-garage-steel-girder-detail.jpg   Minimum ceiling height for 7' garage door-photo-may-12-8-48-12-am.jpg   Minimum ceiling height for 7' garage door-photo-may-12-8-48-52-am.jpg
Old 05-31-2016, 03:32 PM   #6
David Festa
festerized's Avatar
i made a drawing of relative heights, notice the existing steel beam height in the upper loft
Old 05-31-2016, 08:02 PM   #7
rrk's Avatar
Rewards Points: 5,238
Wouldn't a quick call to a garage door company be easier that asking for guesses?
The 7'5" is to lowest surface
rrk is online now
festerized (05-31-2016)
Old 05-31-2016, 08:42 PM   #8
David Festa
festerized's Avatar
One would think it would be that easy, HO is the GC so he needs to contact garage door company and pick-out a door but somehow feels its my responsibility
This is one of those everything for nothing then tell me to scratch when he gets the final price
Old 05-31-2016, 10:48 PM   #9
Windwash
Windwash's Avatar
Rewards Points: 150
Looks like a vinyl sider's dream
I agree with RRK.....call a garage door company and see what they can do. Usually the installers can tweak a few more inches from the specs as well.
Regarding the R-value comment......How cold does it get in NJ? We have a 60's ranch with a single tuck under garage which is insulated by the ground on two sides for almost the full height and nothing will freeze in it no matter how cold outside(-20+). I can't imagine the garage you have posted being much colder than 50-60 degrees on the coldest day with an insulated garage door.
Windwash is offline
The Following User Says Thank You to Windwash For This Useful Post:
festerized (06-01-2016)
Old 05-31-2016, 10:59 PM   #10
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
It looks like the 'garage' part will be nearly unusable
Maybe a rollup-type door with a linear spring/operator
-Steve
TimelessQuality is offline
Old 05-31-2016, 11:11 PM   #11
MarkJames's Avatar
Rewards Points: 19,225
This is the perfect time to apply the "dazed and confused" subcontractor response. When I start hearing crazy wishes (with tight budget), I passively disengage by design. It was hard for me at first, but I'm getting good at it.
"I'll investigate, but no promises."
Good luck with it, certainly.
MarkJames is online now
Old 06-01-2016, 06:06 AM   #12
General Contractor
greg24k's Avatar
Rewards Points: 8,756
If I'm not mistaken, you need min 10" for standard springs and 12" if you using torsion springs.
greg24k is offline
Old 06-01-2016, 07:03 AM   #13
rrk's Avatar
Can be done with 5" space, top bracket is hinged. screwdrive opener. Just called a co. near me.
rrk is online now
Old 06-02-2016, 07:37 PM   #14
txgencon's Avatar
Rewards Points: 468
I've done 7'6" ceiling rough with a 7' door but used a jackshaft operator.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
The Following 2 Users Say Thank You to txgencon For This Useful Post:
festerized (06-03-2016), Mike-B (06-05-2016)
Old 06-19-2016, 06:53 AM   #15
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Rewards Points: 106
This is called a super sneaky bracket
http://supersneaky.com/product/low-o...e-door-hinges/
They also have a operator bracket that allows the operator to be mounted at the same height as the torsion springs if you want to use torsion.
I have installed a 10'x10' commercial door with torsion springs and commercial trolley operator in a 5-1/2" space. It works.
You will need to use a trolley, not a jack shaft, so the top panel gets pushed tight to the jamb. install the door with some pitch to the tracks helping the door to drift closed, and keep the spring a little underwound so the door is a bit heavy.
This is in a 5-1/2" headroom and the drum is 4" which is larger than you will get for a residential door.
Kevin
www.BadcoDoors.com
Pearce Services is offline
The Following User Says Thank You to Pearce Services For This Useful Post:
rrk (06-19-2016)
Tags
garage ceiling height
adding t&g to garage door face Spike7 Windows, Siding and Doors 6 05-10-2016 06:42 AM
Garage door headers at door height or top of wall? dutchroots Construction 24 12-12-2015 12:26 PM
Garage door openers need help Home wood General Discussion 4 11-24-2015 06:55 AM
Ballpark cost for garage addition? Moze Construction 7 01-10-2015 03:21 PM
garage door dispute edward ormsby Commercial Construction 32 08-03-2010 01:52 PM
