LP Smartside Vertical Siding Plate To Plate Limitations. - Windows, Siding and Doors - Contractor Talk
Old 05-09-2019, 05:22 PM   #1
META's Avatar
Trade: General and Trades
Rewards Points: 3,460
According to LP's install notes, their 16"x16' vertical siding cannot be installed through two floors.
"Vertical Siding may only span one plate-to-plate. Each vertical application is not to span beyond one floor to ceiling distance, or one floor to top of gable distance."
In other words, the 16' is useless on typical homes trying to eliminate seams.
Any idea what complications they are trying to avoid from spanning through floor and rim joist transitions?
META is online now
Old 05-09-2019, 05:42 PM   #2
Tom M's Avatar
Rewards Points: 3,678
Re: LP Smartside Vertical Siding Plate To Plate Limitations.
That's a huge panel. I didn't know that it existed. Floor shrinkage maybe.
Shear wise that seems useful unless so who knows.
Call tech support
Tom M is online now
META (05-09-2019)
Old 05-09-2019, 06:05 PM   #3
Bull Trout's Avatar
Rewards Points: 542
I always assumed it had to do with floor deflection, but never asked
Bull Trout is offline
The Following 2 Users Say Thank You to Bull Trout For This Useful Post:
META (05-09-2019), Rio (05-16-2019)
Old 05-09-2019, 06:39 PM   #4
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,262
Tall gables, tall walls. Probably 16í because that pretty much covers everything and thatís what the make their lap siding in.
Big Johnson is online now
Old 05-09-2019, 06:47 PM   #5
Tom M's Avatar
There would be no floor defection on exterior walls
Tom M is online now
Old 05-09-2019, 06:59 PM   #6
Found this:
“Vertical Siding or Batten may only span one plate-to-plate. Due to plate shrinkage, each
top of gable distance. (See Figures 4 & 5)”
https://lpcorp.com/resources/product...ertical-siding
META (05-09-2019)
Old 05-09-2019, 08:35 PM   #7
META's Avatar
I figured it was to keep it from buckling after settling, or even from slight gable truss deflection.
I've got a client, with existing home, wanting seamless board and batten. Fortunately they really don't have too many areas where the technical limitations will be .. "ignored".
The client would sign off on it.
META is online now
Old 05-10-2019, 09:39 AM   #8
VinylHanger's Avatar
Rewards Points: 10,494
I think seamless board and batt would look odd.
I'm just used to seeing the seams I guess.
VinylHanger is offline
Starting a siding crew nlgutters General Discussion 81 03-20-2013 10:15 PM
fiber cement siding issues. chapstick Windows, Siding and Doors 36 08-30-2012 08:14 PM
Need siding identification help CharlieM Windows, Siding and Doors 9 06-22-2012 05:40 PM
Shed picture. lmahome Carpentry Picture Post 14 05-25-2012 11:19 PM
LP Smartside vs. LP Canexel Siding [email protected] Windows, Siding and Doors 15 12-18-2011 09:51 PM
