Large Skylights - Windows, Siding and Doors - Contractor Talk
Large Skylights
Old 07-09-2015, 09:56 AM   #1
General Contractor
Jaketoo's Avatar
Rewards Points: 81
Large Skylights
Hello,
Trying to find some large skylights, to replace existing.
I'm working on a house built in 1986 that has a lot of large fixed skylights. Flat glass residential style.
The skylights are 8' tall x 3' wide. Some are mulled together with a T type mullion strip.
Looking in from the roof I see no manufacturers name.
Velux doesn't have anything that big.
Looking at an old Brosco Book I see Andersen didn't make one that big.
Looking at Andersen and Pella Websites, I can't tell if either company makes skylights anymore.
I can't find any size chart on Wascos Website.
I've spent a lot of time searching on the internet, but can't find skylights that big.
Any help would be appreciated.
Thanks, Jake
www.McWalterConstruction.com
Jaketoo is offline
Old 07-09-2015, 11:30 AM   #2
Anti-wingnut's Avatar
Rewards Points: 3,414
Re: Large Skylights
Have you contacted a glazing contractor?
Anti-wingnut is offline
Old 07-09-2015, 04:29 PM   #3
General Contractor
Jaketoo's Avatar
Rewards Points: 81
Re: Large Skylights
I am going to contact a local glass company about replacing just the glass.
That's a good idea to ask them if they know where to get whole new units.
The skylights have been sealed several times over the years with different kinds of caulk or glazing. We are stripping the roof. It would be best to put in new units.
The skylights are in a tough spot to get to. Very high off the ground, steep roof, and very little framing to lean a ladder against, or attach anything. This is because the skylights work with big wall windows to create an atrium like glass room on a corner of the house.
Jaketoo is offline
Old 07-10-2015, 09:21 AM   #4
tccoggs's Avatar
Rewards Points: 874
Re: Large Skylights
I Know insula dome, who is now owned by skylight specialists makes a 96 x 30 unit, as well as custom sizes. You can give them a try:
http://www.skylightspecialist.net/products.html
Insula dome was the standard issue skylight on LI for years. They were a victim of the 2008 economic downturn and closed up their plant in Yapank. I have 4 of them in my home and have installed many of them for customers as well.
tccoggs is offline
Old 07-15-2015, 11:53 AM   #5
General Contractor
Jaketoo's Avatar
Rewards Points: 81
Re: Large Skylights
Thanks for the information Anti-wingnut and Tccoggs.
They turned out to be Pella Skylights.
I'm meeting the Glass guy next week.
Although only 1 is fogged, it's mulled to another. So both would have to be custom made and replaced. Plus there's 9 more the same size that might fog in the future, Ones a triple. I think replacing just the glass on the big ones is going to be the only way to go. If the glass company quote is sky high, I might consider replacing the glass myself.
There are also 3 small venting Roto Skylights that need replacing. It looks like Velux Skylights will fit nice.
I'll follow up and let you know what we do.
Thanks again, Jake
Jaketoo is offline
large format tile Video charimon Tiling 9 10-11-2012 09:38 PM
Large rift white oak job nearly finished Gus Dering Carpentry Picture Post 20 09-05-2010 09:11 AM
Venting cathedral cieling w/ skylights mattsk8 Roofing 38 12-12-2009 11:38 AM
Small space between two skylights Young_Buck Roofing 13 09-25-2009 11:44 AM
large slab in pole barn tomscarpt Masonry 17 04-04-2009 03:41 PM
