How Flat Is Enough? - Windows, Siding and Doors - Contractor Talk
How Flat Is Enough?
Old 05-12-2015, 11:02 AM   #1
pegasush's Avatar
Trade: Homebuilder/renovator
Rewards Points: 209
How Flat Is Enough?
I have a house with 2" Roxul IS installed on the exterior, continuous. 1x3 furring screwed thru insulation into studs, and then Hardie (most likely).
The roxul is cool stuff, first time I've used their rigid product. Quite strong under compression, but the furring can be adjusted inwards a bit. So I do have the opportunity to flatten the walls, just by adjusting the tension on the screws thru the furring.
I'm not normally a sider, so the question is, how flat is flat enough to make a good substrate for the siding? +- 1/8"? 1/16"?
It's for my own place.
Teamwork is a lot of people doing what I say!
pegasush is offline
Old 05-12-2015, 11:41 AM   #2
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
Re: How Flat Is Enough?
We recently did a project like this using roxul called Maison Reciprocity look it up. But I was def difficult getting that pretty even for siding out a string on it and get it into planar relation.
Tylerwalker32 is offline
Old 05-12-2015, 01:53 PM   #3
Windwash
Windwash's Avatar
Rewards Points: 150
Not sure what depth is acceptable and even if you get it perfect there is the chance that the studs will dry out and bow anyway. I would spend most of your time on the walls with large areas of siding that have few or no fenestrations. Short walls (less than 12') and walls with windows and doors are harder for someone to eyeball and notice deficiencies in the flatness of the wall.
Windwash is offline
The Following 2 Users Say Thank You to Windwash For This Useful Post:
pegasush (05-18-2015), Tom Struble (05-16-2015)
Flat vs flat enamel bluebird5 Painting & Finish Work 0 04-02-2015 08:08 PM
flat roof wide open and building flooded madrina Roofing 43 05-29-2013 08:11 AM
Flat roof drain to municipal sewer - winter freeze? bob_cntrctr Plumbing 10 05-17-2013 02:28 PM
Ventilation of a flat roof Rio Remodeling 5 08-09-2010 11:10 AM
I find some of these names,shocking sjm Painting & Finish Work 7 08-20-2007 05:51 AM
