Hardi Soffit - Windows, Siding and Doors - Contractor Talk
Hardi Soffit
Old 03-22-2012, 09:45 PM   #1
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Hardi Soffit
Any good or bad experiences?
BamBamm5144 is offline
Old 03-22-2012, 09:46 PM   #2
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Hardi Soffit
And thats how hardie could get worse, hanging it on a soffit.
ohiohomedoctor is offline
The Following 4 Users Say Thank You to ohiohomedoctor For This Useful Post:
BamBamm5144 (03-22-2012), Jaws (03-22-2012), slowsol (03-23-2012), Warren (03-28-2012)
Old 03-22-2012, 09:59 PM   #3
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Hardi Soffit
I used some that was like 1/4"... fragile gunning the edges.
Oh and the lovely dust when cutting.
But it seemed like a good product for the application though...
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
Jaws (03-22-2012)
Old 03-22-2012, 10:01 PM   #4
Re: Hardi Soffit
This guy just insists on it! Driving me nuts. We are doing his roof. This whole project is over 40k (Roof,siding, soffit, gutters and a product called Versetta stone) so I want to be able to do the rest.
Old 03-22-2012, 10:01 PM   #5
Re: Hardi Soffit
I think even the hardie fan boyz are loosing faith in that stuff. There is just no point in making something so heavy, so fragile, and so nasty to cut. Did I mention you still have to paint it..
Old 03-22-2012, 10:03 PM   #6
Re: Hardi Soffit
Then thats what you call a go. My dislike for the stuff has never gotten in the way of my love for money. If thats what they want, thats what want. I would sub that portion so when it fails you have someone to call.
Old 03-22-2012, 10:05 PM   #7
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 702
Re: Hardi Soffit
I really like the pre cut soffit from lp..smart soffit. Can order 12 , 16 , or 24 inch x 12' long. Can get solid or vented. Goes up fast and lots easier to handle than the fiber cement.
overanalyze is offline
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
barry1219 (06-09-2012), Jaws (03-22-2012)
Old 03-22-2012, 10:11 PM   #8
VinylHanger's Avatar
Rewards Points: 10,258
Re: Hardi Soffit
It's fine for running soffit, but for porch lids it really sucks. But you probably already knew that. For my own house I wouldn't want that crap hanging over my head. If you blow through the surface, it will eventually pull down.
VinylHanger is online now
Old 03-22-2012, 10:11 PM   #9
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,534
Re: Hardi Soffit
Never used Hardie soffit. I like using Hardie plank though. I never use the prefinished stuff, my customers like to pick out their own color and like knowing in 10 years they can change the color if they want.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
rojigga (03-28-2012)
Old 03-22-2012, 10:26 PM   #10
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,198
Re: Hardi Soffit
Never use the stuff nor ever plan on it, I can buy quality aluminum panel for half the cost of hardi. plus way easier IMO to install too. The hardi or CF I have seen istalled does not impress me at all. And even though it comes in different sizes I have yet to see a house around that the overhang was 24 or 16 right on the money so then you are back to cutting that stuff. I guess people like it , but not me, see no advantages at all.
Randy Bush is offline
Old 03-22-2012, 10:47 PM   #11
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Hardi Soffit
don't hold back Randytell us what you really think about it
Tom Struble is offline
Old 03-22-2012, 10:52 PM   #12
Randy Bush's Avatar
Re: Hardi Soffit
Better not Might get in hot water, would kind of like to stay on the good side of things here.
Old 03-22-2012, 10:53 PM   #13
The Sheriff
Jaws's Avatar
Rewards Points: 4,776
Re: Hardi Soffit
Most of our work is masonry, stucco and cedar, as far as exteriors ,due to resort ordinance. I dig stucco soffit and metal facia , high dollar though. Other than that LP and cedar soffit. Why don't you like Hardie? Never had a problem with it myself.
Jaws is offline
Old 03-22-2012, 11:04 PM   #14
Sawdust Sweeper
carpentershane's Avatar
Rewards Points: 42
Re: Hardi Soffit
I have installed plenty of hardisoffit.... I hate it... Try standing on a ladder jacks or pump jacks with a gale force wind blowing trying to hold a floppy, heavy, 12' piece of soffit and then nail it off. Pure bliss...
A few things to keep in mind...Make sure that you have adequate soffit backing, and install a double 2x where the 12' splice ends. Don't want to nail to close to any of the edges! Also make sure your gun pressure is set so the nails are not blowing through. Better to have to strike it a few times with a hammer than have the nails overdrive.
Also start nailing from one end and work to the other, it is only a 1/4 inch so it tends to sag. Doing this prevents that Factory ends aren't always square either... best to check before throwing it up there. Sometimes on the vented the perforations are not terribly consistent from piece to piece... So you look up after a run is done and the perforations don't always line up that well
It does paint nicely though! I recently said I was never going to install hardie soffit again, and guess what? The next HO insisted on it... At least it was only 12" soffit Never say never
I reinstalled some hardie soffit once that some jackass had installed with 18 gauge pins... Got a strong wind and it literally sucked the soffit off!
"Perfection is an unachievable goal, the illusion of perfection is the work of a true craftsman. " LoneFramer
carpentershane is offline
The Following 4 Users Say Thank You to carpentershane For This Useful Post:
BamBamm5144 (03-23-2012), rojigga (03-28-2012), Tom Struble (03-23-2012), WNYcarpenter (03-29-2012)
Old 03-23-2012, 07:31 AM   #15
slowsol's Avatar
Rewards Points: 2,248
Re: Hardi Soffit
I am not a Hardi supporter, and that soffit blows. I did a ton of apartments with that crap a few years ago. It blows apart if you nail too close to edges, edges are always chipped, it's thin and hard to control, and the dust is horrible.
-John
slowsol is offline
Old 03-23-2012, 09:38 AM   #16
Re: Hardi Soffit
I am also going to present the LP soffit to him.
I am not a fan of anything Hardi either but you know...
Old 03-23-2012, 09:56 AM   #17
Sawdust Sweeper
Rewards Points: 42
Re: Hardi Soffit
The dust is not the products fault- got to have the right set up.
Old 03-28-2012, 08:48 PM   #18
rojigga's Avatar
Trade: Exterior Finishing
Rewards Points: 152
Re: Hardi Soffit
You, my friend, hit the nail on the head. Your opinion closely mirrors mine. Hardie Soffit will last, you can paint it over and over again, but using finishing nails (18g) simply cannot be done. Do not over sink your nails!
rojigga is offline
Old 04-15-2012, 02:50 AM   #19
ultimatedecks's Avatar
Trade: deks & siding
Re: Hardi Soffit
if you gave me that stuff for free i wouldn't use it.
ultimatedecks is offline
The Following 2 Users Say Thank You to ultimatedecks For This Useful Post:
Randy Bush (04-15-2012), slowsol (04-15-2012)
Old 04-15-2012, 06:13 PM   #20
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
Re: Hardi Soffit
You guys are nuts. I love hardi soffit. When I build my house, that's what i'm using for sure. It's not hard to hang, but it does take 2 guys.
I don't know if its a Tennessee thing or what, but we use it a lot down here. Banks, houses, commercial buildings. Its great. It's not that fragile. I mean you can't go dropping it or picking it up in the middle or on the very ends like 2 stooges. If you pick it up so the weight is distributed evenly, it goes up nice and clean. It is soo smooth to paint and beats the crap out of vinyl IMO.
Hardi siding, hardi soffit, hardi trim, hardi facia: all excellent products.
bluebird5 is offline
Please help with Hardi Plank squarehead Windows, Siding and Doors 19 03-21-2016 12:38 PM
Hardi problems Randy Bush Windows, Siding and Doors 9 08-10-2011 11:12 AM
Can you install recessed ext. soffit lights in pre-vented soffit board? kansasflooring Carpentry 2 03-30-2011 04:04 PM
Tape Hardi Board to 1/2" drywall CGallagher Drywall 4 04-22-2010 07:12 AM
Vinyl soffit span... what backing OC? bobaganoosh Windows, Siding and Doors 11 12-24-2008 12:41 AM
