Hardi Siding Cons - Page 4 - Windows, Siding and Doors - Contractor Talk
Hardi Siding Cons
Old 06-11-2012, 11:12 AM   #61
txgencon's Avatar
Rewards Points: 432
Re: Hardi Siding Cons
Dammit. Brick is starting to look better and better.
txgencon is offline
The Following User Says Thank You to txgencon For This Useful Post:
Tom Struble (06-11-2012)
Old 06-11-2012, 12:56 PM   #62
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Originally Posted by ccappaul View Post
F.C. fiber cement
M.C. ? What's that ? Thanks
moisture content
this was a job i did about 6 or 7 years ago that i went back to recently,i butted everything tight,kept the material covered
what i don't understand is why did just some joints open up?
Tom Struble is offline
Old 06-11-2012, 02:31 PM   #63
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Originally Posted by Tom Struble View Post
moisture content
I've never liked Fiber Cement since I first started selling it back in the mid 1990's when I worked on the wholesale side of the business. It's heavy, adding a TON of weight to the structure, it absorbs moisture (contrary to the hardi in the bucket of water that made it's way around for a long time as a sales tool), you need special tools to cut the stuff, the guys need to wear masks when cutting it and you STILL need to paint it. Plus, we are now finding that with the limestone talc used it it's slurry.... mold is extremely attracted to the back side of the stuff where it sweats.
Tom.... you weren't alone getting "sucked in" on the whole FC storm that swept the industry several years ago. I tried my best to steer all of my contractors away from it then, and I refuse to sell it now. I saw "moisture" as a potential problem back then.... and my fears then are starting to become a reality today. I mean if someone as conscientious an installer as you are, is having issues.... what do you think is going on where one time hack wanna-be's put this stuff up about the same time you did?
I see a firestorm on the horizon to rival the whole LP thing of twenty years ago. At least that was just delamination, but with FC and the growing mold issues, who knows where this is headed.
The product I'm using in place of FC when someone doesn't want vinyl, steel or aluminum, is this Everlast product from Norandex.
http://www.completewindowanddoor.com...st_siding.html
http://everlastsiding.com/
It's made from crushed stone and PVC polymers and resins (ZERO organics so never any mold issues). It's extremely light weight, the color goes all the way through, it feels and looks just like wood and is a dream to install.
A little pricer than FC, but well worth it IMHO.
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
The Following User Says Thank You to CompleteW&D For This Useful Post:
Old 06-11-2012, 09:00 PM   #64
Birch's Avatar
Rewards Points: 1,058
moisture content
I visited one of our local yards recently and they have their Hardie stored outdoors and uncovered. I think it holds moisture for quite a while when stored like that. Sure does shrink once on the wall.
Got Caulk?
Birch is offline
The Following User Says Thank You to Birch For This Useful Post:
Old 06-11-2012, 09:13 PM   #65
Trade: siding
Rewards Points: 20
ive seen that John ,it has some sort of t&g seam no?
i'd like to try that
Old 06-11-2012, 09:18 PM   #66
Trade: siding
Rewards Points: 20
i still don't ''hate'' fc,it has issues,what don't ?
Old 06-11-2012, 09:38 PM   #67
duburban's Avatar
Trade: building
Rewards Points: 1,752
i just demoed some of this stuff and it was hanging on as 5 or so different layers. just getting it to the job without it bending around enough to delaminate like that is close to impossible. i'm all for wood primed on all sides and a good rain screen.
duburban is offline
Old 06-11-2012, 10:31 PM   #68
Shellbuilder's Avatar
Trade: Shell building contractor
Rewards Points: 1,236
Im using the joint covers next job if I can get them. They're not pretty but neither is the open joint. I have a 3 story 6000 sq ft interior and some exterior remodel coming up to do (3 y.0.) that already needs painted, renailed (yep needs face nailed), all the trim nails face nailed are rusting and a ton of joints are open as much as 3/8 with no splines. The butt joint is the only problem I have with F.C. Always on south and west walls
www.shelladditions.com
Shellbuilder is offline
Old 06-11-2012, 10:55 PM   #69
Windwash
Windwash's Avatar
Rewards Points: 148
What is the reveal that it needs to be face nailed now? How is the trim nails rusting a Hardie problem?
If the paint didn't make it 3 years it sounds like there may be other issues to solve than just renailing. Do you have some pictures?
Windwash is offline
Old 06-11-2012, 11:02 PM   #70
Colorplus product. Its a 7" reveal smooth. Caulk no longer matches and I didnt say the nails were a hardie problem. Unless your face pinning with SS nails, dont bother at the beach.
Old 06-11-2012, 11:34 PM   #71
rojigga's Avatar
Trade: Exterior Finishing
Rewards Points: 152
Just use vinyl. A good install will look good. Call me in 3 years when it doesn't, I'll do it it in FC.
Good install in vinyl: Faded product in 3 years.
Good install in FC: No fade
To the non-pro pro's: your work is exclusive of mine, I deal with a specific environment you probably don't deal with.
rojigga is offline
Old 06-12-2012, 01:30 AM   #72
Seams are butted just like FC, However, the Everlast product has a max horizontal expansion of 1/8" on a 12' span. It "sort of" has a T&G type affair where you simply "stack the next course on top of the last. As long as your first course is level, each succeding course stays level as well. I've got a small job of it coming up very soon, so I'll get some pics.
- John Williams
Tom Struble (06-12-2012)
Old 06-12-2012, 01:40 AM   #73
Well, quite un-like any vinyl that I know of, the Everlast has a Lifetime fade warranty. Now, before you shoot the messenger, I haven't actually read the fine print of the warranty, so it's probably some type of fade warranty that guarantee's that it won't fade more than so many color units over the lifetime of the product or some such.
As for FC not fading, you are not correct. The FC isn't what fades, it's the paint applied to it that fades. So to use your nomenclature....
Good install in FC with very expensive finish paint: Probably won't fade much.
Good install in FC with cheap finish paint: Will need to repaint in 3-5 years adding even MORE cost to an already expensive siding job.
- John Williams
rojigga (06-12-2012)
Old 06-12-2012, 01:45 AM   #74
I don't "hate it" either. I just don't care for it very much.
- John Williams
Old 06-12-2012, 11:02 AM   #75
Windwash
Windwash's Avatar
Rewards Points: 148
What do you attribute the loose siding to? Does it need to be re/face nailed because of poor installation or has the wind/other caused it to be a problem.
Windwash is offline
Old 06-12-2012, 07:16 PM   #76
I don't know why this material didnt lay tight. Most of the beach houses are block brick or piling s and the siding starts at 8' above grade so you do notice it more. I could put my finger behind almost all of this stuff. I face nail every job I do and use primed. Paint and caulk looks way better.
The Following User Says Thank You to Shellbuilder For This Useful Post:
Windwash (06-13-2012)
Old 06-12-2012, 07:33 PM   #77
tccoggs's Avatar
Rewards Points: 874
I love the Hardie on my house and 5 yrs in its holding up great. Mine was installed in the summer and I butted everything tight. There are some small seams, but nothing thats an eyesore. The colorplus finish is holding up great with minimal fading even on the south side of the house which gets blasted with sun all year long.
I don;t thing I would go with anything larger than 6.25" or you will get some lifting unless you facenail. Mine is all blind nailed with SS siding nails and nothing is loose or lifting.
Vinyl is far from final and usually looks faded and washed in a few years and the only solution is to tear it off and start over. I will repaint in 10-12 and the house will look like new again. That was the main reason I went with the FC.
tccoggs is offline
The Following User Says Thank You to tccoggs For This Useful Post:
Old 06-12-2012, 07:38 PM   #78
rojigga's Avatar
Rewards Points: 152
I can agree with that. You need good, UV tolerant paint.
rojigga is offline
The Following User Says Thank You to rojigga For This Useful Post:
CompleteW&D (06-13-2012)
Old 06-13-2012, 09:52 AM   #79
md2020's Avatar
Trade: residential contractor
I was pretty excited about this Everlast siding, but after checking its more than "a bit more" than FC.
With the job I'm looking at, material only is 3 1/2 (pushing 4x) times the cost. Of coarse the Everlast does not need painting, so overall done and said (figuring in painting of the FC) its slightly less than double the cost (roughly 40% more for the Everlast).
I did not take in account any advantage or disadvantage to installing one vs. the other. Everlast looks to definitely have advangages with the weight and "tongue and groove" like install.
Looks like a great product, just a very hard sell at that price!
md2020 is offline
Old 06-13-2012, 04:36 PM   #80
With the reduction in labor cost (Everlast goes on nearly twice as fast) along with the cost of two coats of premium exterior paint, no special tools etc.... we've calculated it's about 25% more than a premium FC installation.
With some of the delaminating and mold issues were beginning to see with FC, it just makes more sense for us. I'm not saying it's for everybody.
- John Williams
Tom Struble (06-13-2012)
What is the linear and sq.foot price for Hardi siding? soffit,fascia?Dallas TX user19249 Windows, Siding and Doors 16 02-16-2008 08:46 PM
Rotten Hardi plank siding I replaced dkillianjr Windows, Siding and Doors 4 11-24-2007 06:23 PM
Installing Hardi Plank Siding around windows w/ J channel brownie77 Windows, Siding and Doors 8 11-21-2007 08:52 AM
Hardi Siding going a new way Mike Finley Business 10 07-31-2006 03:49 PM
Question About Hardi Lap Siding Installation slbrown Windows, Siding and Doors 19 05-08-2006 01:18 PM
