Hardi Fiber Cement Fastening Air Tool - Windows, Siding and Doors - Contractor Talk
Old 01-16-2012, 09:07 PM   #1
904sorock
904sorock's Avatar
Trade: General Building Contractor
Rewards Points: 75
Just wondering what you siding pros use to install fiber cement siding. I just submitted a bid for siding job and was accepted. Since I do not own a siding air nailer I was thinking of either using my roofing nailer or my framing nailer. What do you guy think . I would hate to invest in siding nailer for 1 time job. Thanks SM
904sorock is offline
Old 01-16-2012, 09:16 PM   #2
guardian's Avatar
Trade: siding
Rewards Points: 512
Re: Hardi Fiber Cement Fastening Air Tool
read the manual
roof nailer is just fine..
two of my guys use a roofing nailer and two use a siding nailer
guardian is offline
The Following User Says Thank You to guardian For This Useful Post:
Tom Struble (01-16-2012)
Old 01-16-2012, 09:33 PM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,220
I won't put the stuff on , but I have been told by other guys that do, that you need a gun that fires fast. A slow one , older framers , cause problems. Mainly with Certaintee brand.
Randy Bush is online now
Old 01-16-2012, 10:12 PM   #4
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,708
Read the install manual for your area, it's on hardis website. Used to be 1 1/4" roofing nails were ok, now I think 1 3/4" is required.
I use a Hitachi siding gun. I know it's $$$, but you can use it for your corner/window trim, face nails, etc.
You need some kind of nailer (framing gun will work with HDG) for the odd face nail, other wise you will be pre-drilling.
jhark123 is offline
Old 01-16-2012, 10:36 PM   #5
pro
country_huck's Avatar
Trade: Capenter/ Remodeler
Rewards Points: 768
Roofing gun works as people said check manufacture specs.
Nathaniel Huckins (huck)
Facebook
country_huck is offline
Old 01-16-2012, 10:45 PM   #6
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
we use siding guns..when their not used for siding their used for underlay
woodworkbykirk is offline
Old 01-16-2012, 11:05 PM   #7
A.Murrill's Avatar
Rewards Points: 150
We use Senco siding nailer. It can be used for fencing also. I have used roofing and framing guns. I prefer siding gun because you can use it for siding and trim. I like that the nails are the right diameter as well as length to support manufactures warranties. Also the gun is lighter than my framing nailer. Also the nails have a full head. I believe most fiber cement manufactures will not warrant a clipped head install.
A.Murrill is offline
Old 01-19-2012, 09:53 AM   #8
pro
413Sean's Avatar
Trade: residential/framer
Rewards Points: 326
we use roofing gun or hitachi siding nailer as long as its covered in the warannty specs
413Sean is offline
Old 01-19-2012, 04:55 PM   #9
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
We also use either a roofing gun or a siding nailer.
I like the siding nailer because it shoots longer ring shank nails. I like the roofing nailer because the head is larger.
I want a combination of the 2.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
The Following User Says Thank You to redwood For This Useful Post:
JWilliams (01-19-2012)
Old 01-20-2012, 09:07 AM   #10
trim carpenter/remodeler
MKnAs Dad's Avatar
Trade: trim carpenter/remodeler
Rewards Points: 560
I have always used a roofing nailer. Obviously that is for blind nailing the siding. I was told by my sales rep that for fastening the OSC together, as well as nailing it up, Hardi recommends using 15ga Galv nails. T"hat info was about 2-3 years old so it might have changed too. I was on a job that had plywood sheathing and either one or two layers of 5/8" exterior drywall for fire rating. 1 3/4" coil nails were too small for the siding. This job was Certainteed Weatherboard siding. I researched the best options from manufacture specs. According to what I read, full headed framing nails would be fine.
I used a Hitachi siding nailer on a cedar job last year. I loved the idea of it, but had soooo many jambs because of the way the nails are collated. Next job, I will use these instead:
http://www.abccatalog.com/view_produ...uct=9834271298
Not necessarily that exact nail, bu tyou get the idea. Yeah, the framing nailer is heavier, but the nails probably will not jamb. Also, one less tool to buy/carry around.
MKnAs Dad is offline
Old 01-22-2012, 09:20 PM   #11
GARRETT RENOVATIONS LLC
Garrett's Avatar
Trade: GC,Builder,Custom Renovations
Rewards Points: 75
roofing nailer if you have one already but if you are going to do more than 1 job invest in the hitachi siding nailer it is sweet!
Garrett is offline
Old 01-23-2012, 02:38 PM   #12
rojigga's Avatar
Trade: Exterior Finishing
Rewards Points: 152
I hear siding installers have guns to fasten siding properly. Maybe get one of them to install it. Or just bid on jobs in which you can professional finish without needing to ask questions HO ask.
rojigga is offline
Old 01-23-2012, 03:28 PM   #13
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
thats not fair,everybody starts somewhere, better guys than you and me put together have asked this kind of question...it's kinda why this site works,but you gotta be willing to play
Tom Struble is offline
GRB (01-23-2012)
Old 01-24-2012, 12:16 AM   #14
904sorock
904sorock's Avatar
Rewards Points: 75
Rojigga in case you havent figured it out , this is the whole purpose of this forum, to ask questions! Correct me if im wrong but I dont believe you know it all even in your trade!
Old 01-24-2012, 12:17 AM   #15
rojigga's Avatar
Rewards Points: 152
I think it's entirely fair, although I do agree with your statement of everybody needing to start somewhere. I believe in asking for help, but bidding on something you have no idea how to complete is something entirely different. This is why the price of jobs continue to decline and why there are so many shoddy installs being done.
If you want to learn a new trade, ask someone to show you. If no one is hiring, ask to shadow someone. I'm no plumber, electrician, or HVAC guy; I couldn't imagine bidding one of those jobs, or even thinking about winning it.
I see this happening more and more, everyone wanting to expand their scope of work to stay busy; but unless you know you can do it properly, it is irresponsible to claim you can.
rojigga is offline
Old 01-24-2012, 12:22 AM   #16
rojigga's Avatar
Rewards Points: 152
I don't know everything in my trade! I learn or try to learn something new everyday! But unless I can complete a project properly I'm not bidding on it. You don't even know how to fasten the very material you're quoting, which by the way is the easy part- there are instructions that come with it! How can I expect you to know some of the more complex things like building envelope? What you are doing is completely irresponsible, and why I believe there needs to be more regulation/inspection like you see in other trades.
rojigga is offline
Old 01-24-2012, 12:25 AM   #17
904sorock
904sorock's Avatar
Rewards Points: 75
you just cant compare a siding installation to plumbing electrical hvac, Anybody with carpentry skills can put up siding with good results, homeowners do it themselves all the time.
Old 01-24-2012, 12:30 AM   #18
904sorock
904sorock's Avatar
Rewards Points: 75
Please explaing to me what is so difficult about installing siding even with half a brain.
Old 01-24-2012, 12:35 AM   #19
904sorock
904sorock's Avatar
Rewards Points: 75
So you are learning on the job!!! huh
Old 01-24-2012, 12:49 AM   #20
rojigga's Avatar
Rewards Points: 152
Yes as you say anyone can install siding who has half a brain. Although I'd be concerned about this half brained person installing membrane properly, installing flashing properly, venting when needed properly, and many, many other areas a lot of people don't really understand is all part of our job. My point wasn't to point out your ineptitude, rather that someone who obviously knows very little or nothing at all about a trade should not be undertaking the job.
If there wasn't a water issue, and it were purely cosmetic, I would say go to town, and I would recommend just about any coil nailer that can shoot 2" galvanized nails.
http://www.amazon.com/Hitachi-NV65AH...7384094&sr=8-1
http://www.amazon.com/CN565S-4-Inch-...7384119&sr=1-1
http://www.amazon.com/Bostitch-N66C-...7384140&sr=1-1
I highly recommend The Max.
rojigga is offline
tool definitions go do it General Discussion 10 05-15-2017 01:44 AM
Ridgid fiber cement saw RadRemod Tools & Equipment 8 08-25-2011 05:56 AM
Hardi board/fiber cement install question enforcer Windows, Siding and Doors 16 07-02-2009 02:31 AM
suare footing pricing for fiber cement siding guardian2474 General Discussion 61 06-09-2009 06:40 PM
ring shank nails with fiber cement siding? Jer Windows, Siding and Doors 16 01-18-2009 12:58 PM
