Grinder To Cut Vinyl - Windows, Siding and Doors - Contractor Talk
Old 03-08-2015, 12:20 PM   #1
Tom M's Avatar
Rewards Points: 11,058
So I am wondering if anyone has tried a grinder and what blade they found to work well.
I have used a flat straight edge and the circular saw I use for siding to carve out a window or a door where one doesnt exist.
I have to carve out 4 sections in between a roof and floor, so I will be starting and stopping alot. Those cuts need to be finished. Was thinking maybe my Fein with the drywall blade or something fine toothed.
As for the grinder, I have been able to make excellent cuts using a grinder with a diamond wheel on aluminum. I never tried it with vinyl. Normally I would just use snips or unclip the material. The reason I am considering a grinder for the vinyl is the very cold temps we have been having. I can see cracking panels trying to unclip them and I dont want to chip the hell out the siding with an aggressive blade.
Tom M is online now
Old 03-08-2015, 12:26 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 934
Re: Grinder To Cut Vinyl
That's probably the safest, though slow. I've used a grinder with a carborundum blade, but that tends to be messy.
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Tom M (03-08-2015), WarriorWithWood (03-08-2015)
Old 03-08-2015, 12:29 PM   #3
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,242
Tom. Last spring I did a job for a firefighter/ DIY er and he asked if I could step flash a carport that he just roofed that butts up against existing house..
Was gonna rip out the panels and start fresh but he insisted I try the grinder that he had set up. I was actually surprised how good it worked. Not sure what type of blade but there was no chipping at all. Not sure if I'd have the guts to do it during winter though
NYgutterguy is offline
Old 03-08-2015, 12:38 PM   #4
BradingCon's Avatar
Rewards Points: 740
I use a grinder to cut vinyl in the winter. The only blade that works is a smooth diamond tile blade. All others chip the vinyl too easily.
BradingCon is offline
The Following User Says Thank You to BradingCon For This Useful Post:
Tom M (03-08-2015)
Old 03-08-2015, 12:44 PM   #5
Tom M's Avatar
Thanks guys, I knew a grinder would be useful, wasnt sure about which blade for plastic.
Tom M is online now
Old 03-08-2015, 05:29 PM   #6
klintala's Avatar
Trade: General Contracting/Concrete
Rewards Points: 136
Thats what we use all year round. It makes for quick, accurate cuts.
The only issue we had was recently installing this stuff. It just wanted to stick to the blade and melt more than cut.
Grinder to cut vinyl-img_0517.jpg   Grinder to cut vinyl-img_054.jpg   Grinder to cut vinyl-img_055.jpg
klintala is offline
Old 03-08-2015, 05:35 PM   #7
hammer7896's Avatar
Rewards Points: 26
When I cut vinyl with a grinder, I use a wafer wheel like you would use on steel. I works great.
hammer7896 is offline
The Following 3 Users Say Thank You to hammer7896 For This Useful Post:
spartancc (03-22-2015), Tom M (03-08-2015), WarriorWithWood (03-08-2015)
Old 03-08-2015, 06:40 PM   #8
Tom M's Avatar
Thats a diamond blade with melted shakes on it and not a tile blade right?
Tom M is online now
Old 03-08-2015, 06:41 PM   #9
Tom M's Avatar
I do keep an assortment I thought about the thin kerf metal blade but was concerned about the cold.
Thanks guys
Tom M is online now
Old 03-08-2015, 08:20 PM   #10
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
I use a 5" 1 mm (or thinner) wafer steel slicer blade...they work best because they take out very little material and doesnt melt it like the diamond blades tend to do. I used to use a bacwards plywood blade in circ saw but forgot it one day and tried the grinder, I'll never go back. I have found that the grinder is faar more accurate and easier to control.
-Dennis
WarriorWithWood is offline
The Following User Says Thank You to WarriorWithWood For This Useful Post:
Sir Mixalot (03-09-2015)
Old 03-08-2015, 08:45 PM   #11
BradingCon's Avatar
Rewards Points: 740
I was just talking about in cold weather. In warm weather straight cuts are made with a backwards plywood blade in a circular saw setup in a homemade jig. Then, windows, doors, etc. are cut out with the grinder. But in cold weather the circ saw chips vinyl badly. So i use the grinder with a smooth diamond blade.
Old 03-08-2015, 08:53 PM   #12
pizalm's Avatar
Rewards Points: 830
Walter zip cuts are perfect for cutting vinyl.
Sent from my iPad using Tapatalk
pizalm is offline
Old 03-08-2015, 09:29 PM   #13
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
I use the thin wafer style blades. The only problem I find is that it can leave static charged dust on the siding that doesn't want to come off. I usually keep a compressor with a blower nozzle to keep the siding clean. I know it'll wash out after a while but I can't stand the look. I want it to look perfect.
Your Dreams won't work unless you do.
SamM is offline
Old 03-09-2015, 06:45 AM   #14
Artworks's Avatar
Trade: Renovations & Construction
Rewards Points: 354
Zip cut wheel , cordless Dewalt grinder works great. Especially on scaffold doing the gable .
IF IT WAS EASY, EVERYONE COULD DO IT !
Artworks is offline
Old 03-09-2015, 07:44 AM   #15
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
I've used zip blades as well, and for the OP, I think it's the right choice for what he wants to do.
I use high leverage shears for most of my vinyl which is okay, but tiring on the hands for sure. I'm hoping my new turbo shears from Malco take some of the stress off.
I just got them a couple of weeks ago and have only sampled some cuts - seem to work real well.
supersealconstruction.com
superseal is offline
Old 03-09-2015, 07:53 AM   #16
Artworks's Avatar
Rewards Points: 354
I think for long rips the shears work good, I have older Milwakee electric I use. if you got "take another 1/4" " they don't work very good !
Vinyl ( & plastic) seams to dull blades.
Artworks is offline
Old 03-09-2015, 08:30 AM   #17
Tom M's Avatar
You guys are getting nuts. Shears are the right tool 90% of the time if it wasnt cold. It warmed up so I will be cutting with some shears. I look forward to using the grinder for speed plunging through an already installed wall.
Tom M is online now
Old 03-09-2015, 04:46 PM   #18
Tom M's Avatar
So I didnt bother trying the thin steel blade, I had a toothed diamond blade on the grinder already and it was a breeze. Like Dennis I doubt I will use a circular saw again unless its the only tool available.
Tom M is online now
Old 03-09-2015, 04:58 PM   #19
AustinDB's Avatar
Rewards Points: 1,520
I've used a grinder and thin (metal) cutoff wheel for cutting flanges off vinyl doors/windows. I make shallow and fast passes-staying in one position too long can cause melting. The downside is the vinyl dust is thrown all over the place.
try laying a 2x4 or 1x4 across the vinyl siding to ride the grinder along to keep a straight line
AustinDB is offline
Old 03-09-2015, 07:40 PM   #20
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
I use a 1/8" thick fiber blade all the time for vinyl siding.
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
New hardwood deck over vinyl duradeck jonno38 General Discussion 3 04-27-2013 10:03 PM
Vinyl Flooring Adhesive Question josephdan General Discussion 1 03-05-2013 05:36 PM
White Vinyl Rail and Trellis killerdecks Decks & Fencing 9 02-13-2013 05:45 PM
seem treatment for 5/8" plywood and vinyl plank flooring GO Remodeling Flooring 5 01-11-2013 10:51 PM
