Is Glass Code In Garage Door Between House And Garage? - Windows, Siding and Doors - Contractor Talk
Old 09-12-2011, 08:57 PM   #1
abacab's Avatar
Rewards Points: 390
I had someone mention this today, and I hadn't heard it before. Can I have a steel door with a window in it, between the house and garage? This is your typical steel door you get from home depot. I could see why it might not be, as a window breaks out quickly in a fire.
abacab is offline
The Following User Says Thank You to abacab For This Useful Post:
concretemasonry (09-12-2011)
Old 09-12-2011, 09:00 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,484
Re: Is Glass Code In Garage Door Between House And Garage?
Door, Frame & Glass will all have to be fire rated.
griz is online now
Old 09-12-2011, 09:15 PM   #3
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 458
And a spring hinge or other type of closer.
Warren is offline
The Following User Says Thank You to Warren For This Useful Post:
griz (09-12-2011)
Old 09-12-2011, 09:19 PM   #4
Fire up the BBQ
griz's Avatar
It would be handy to have you guys when bidding a job or on bid day...nothing would slip by...
griz is online now
Old 09-12-2011, 09:22 PM   #5
Geometrist
Warren's Avatar
Rewards Points: 458
Trust me Griz, my bidding mind is very sharp nowadays. Now if I only I could actually get a few of these jobs...
Warren is offline
Old 09-12-2011, 10:06 PM   #6
Sawdust Sweeper
carpentershane's Avatar
Rewards Points: 42
I don't think self closer is code for fire doors with the latest IRC
Apparently too many people prop them open when bringing groceries in...
"Perfection is an unachievable goal, the illusion of perfection is the work of a true craftsman. " LoneFramer
carpentershane is offline
Old 09-12-2011, 10:23 PM   #7
Sawdust Sweeper
Rewards Points: 42
IRC 2006
R.309.1 Opening Protection. Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 1 3/8-inches (35 mm) in thickness, solid or honeycomb core steel doors not less than 1 3/8-inches (35mm) thick, or 20-minute fire-rated doors.
Old 09-13-2011, 07:53 PM   #8
TimNJ's Avatar
Rewards Points: 6,838
Glass has to have wire in it and size is limited I believe depending on rating.
TimNJ is offline
Old 09-13-2011, 11:22 PM   #9
Gonna die a glass guy
ccappaul's Avatar
Trade: Skylights and Glazing
Rewards Points: 250
You would need to use a steel retaining frame as the plastic home depot style would melt out long before the wire glass fell apart and the glass would be to small to worry about, maybe 5 x 18
Unless possibly you went to a very expensive specialty glazing, gel filled fire rated, smoke seal, I don't know about self closing for sure after the last post... I thought that was required
Way in over my head...... goodnight...
ccappaul is offline
Old 09-13-2011, 11:26 PM   #10
Fire up the BBQ
griz's Avatar
Maybe a jurisdictional thing...
Heard from a supplier,today, that wire is not an option.
griz is online now
Old 09-13-2011, 11:35 PM   #11
ccappaul's Avatar
Rewards Points: 250
Griz, I think you are right, couple years ago Oregon was all over banning wire glass from use in schools, due to kids getting cut up from it. There are some very expensive fire rated systems out there, I am sure it could be done. But at what cost ? Most certainly not $219.00 home depot
ccappaul is offline
The Following User Says Thank You to ccappaul For This Useful Post:
griz (09-13-2011)
Old 09-13-2011, 11:41 PM   #12
ccappaul's Avatar
Rewards Points: 250
I am leaning on the " or 20 minute fire rated door " clause . It can be
done, but you are gonna have to want to see that car of yours real bad too spend that kind of money.
ccappaul is offline
Old 09-13-2011, 11:44 PM   #13
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,858
Just put it in later. I am a rule breaker because I have put them in before, I figured the paneling in the garage would go way before the door.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 09-13-2011, 11:48 PM   #14
Fire up the BBQ
griz's Avatar
Not out here...
Can you spell A-T-T-O-R-N-E-Y & L-A-W-S-U-I-T + L-I-A-B-I-L-I-T-Y?
Sucks to live by the big salt pond
griz is online now
Old 09-13-2011, 11:50 PM   #15
I like Green things
It was a R&R and it had glass already. I told them, they didn't care, I put it in.
There has to be at least 2 dozen I have seen that way, if not more.
Warner Mill Works
Facebook
YouTube
Old 09-13-2011, 11:53 PM   #16
Fire up the BBQ
griz's Avatar
Read my previous post...
I would not do that out here.
griz is online now
Old 09-13-2011, 11:55 PM   #17
I like Green things
It sucks in backwoods Indiana too. At least you guys have good prescription meds out there.
Warner Mill Works
Facebook
YouTube
Old 09-13-2011, 11:59 PM   #18
Fire up the BBQ
griz's Avatar
Top notch locally grown organic herbal varieties also...
griz is online now
MALCO.New.York (09-14-2011)
Old 09-14-2011, 12:05 AM   #19
HAT's Avatar
Trade: Windows & Doors
Rewards Points: 25
I sell about 6-10 fire doors a month on average to frantic H/O's who are trying to close escrow or whatever & can't because somebody previously scabbed in a HC flush door from a box store.
On the flip side...I have a high end builder that does a lot of contemporary homes who almost always re-hangs a 1 lite white lami door after final.
HAT is offline
Old 09-14-2011, 12:12 AM   #20
ccappaul's Avatar
Rewards Points: 250
Well since your talking about whether is done despite the code after the inspection .
I have a very nice 1/2 lite with internal blinds where the 20 minute door was when the inspector came and vice versa.
I think its going to give me a chance to get out if I can see the fire before it gets too big .
ccappaul is offline
griz (09-14-2011)
