Getting Rid Of Asbestos Siding - Windows, Siding and Doors - Contractor Talk
Old 08-18-2013, 10:09 PM   #1
spazman
spazman's Avatar
Trade: floorcovering installer
Rewards Points: 2
I hope that I'm in the right forum for this question. I have a friend who has an old farm house with asbestos siding. He says it was installed sometime in the late 50s. The pieces are a gray color and measure about 1 foot by 3 foot. He wants to remove it down to the sheeting and install new vinyl siding. What he wants to know is can he remove it himself or is an abatement company required and if so how many hoops does he have to jump through? Thanks for looking I appreciate the advice.
spazman is offline
Old 08-18-2013, 10:17 PM   #2
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Getting Rid Of Asbestos Siding
A homeowner can legally remove asbestos from a single family house they live in. Get a dumpster, put 6 mil poly in it, tape the seams. Fill it and cover it with poly. When he gets the dumpster make sure they know it's for asbestos.
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
spazman (08-18-2013)
Old 08-18-2013, 10:24 PM   #3
Educator of Codes
jar546's Avatar
Trade: Construction Aficionado
Rewards Points: 164
Why not just leave it in place and go over it?
"The more I learn, the more I realize just how much I don't know" "It's OK to eat some humble pie every know and then. It has what you need in nutrients"
jar546 is offline
Old 08-18-2013, 10:29 PM   #4
stacker of sticks
Rewards Points: 590
How do you propose doing that without braking all the old shingles?
Old 08-18-2013, 10:30 PM   #5
Boondockian
Dustincoc's Avatar
Trade: Getting the job done
Rewards Points: 1,018
My experience with asbestos siding tells me its fragile and driving nails through it(to secure the vinyl siding) will just break it up, thereby releasing asbestos fibers.
In the words of General James Mattis: "Be polite, be professional, but have a plan to kill everybody you meet."
Captain Howdy: We must all go through a rite of passage, and it must be physical, it must be painful, and it must leave a mark.
Dustincoc is offline
Old 08-18-2013, 10:37 PM   #6
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Why would you want to remove it? It's way more durable than most of what's on the market today & left alone, is almost zero risk?
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
Old 08-18-2013, 10:40 PM   #7
stacker of sticks
Rewards Points: 590
Maybe its broken up. I have it on my house and I'm getting to the point something needs to be done. The basketball hitting the house has done its damage on the driveway side.
If it wasn't I would just paint it
Old 08-18-2013, 10:44 PM   #8
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Good point. That's the only reason I'd do it.
Old 08-18-2013, 10:47 PM   #9
Birch's Avatar
Rewards Points: 1,058
Asbestos siding is better than vinyl, IMO. I'd leave it where it is.
When I do remove it, I usually just store it on the property somewhere. If it is a pier and beam home, then under the home it goes.
Birch is offline
Old 08-18-2013, 11:22 PM   #10
spazman
spazman's Avatar
Rewards Points: 2
I'm not sure but I think the asbestos may be over some other siding. If he went over the asbestos then it looks like he would have to build out the window sills. As far as just leaving it alone, well he has a lot of broken and battered pieces and it is also an ugly battleship gray.
spazman is offline
Old 08-18-2013, 11:44 PM   #11
Boondockian
Dustincoc's Avatar
They do make non-asbestos containing siding that looks like the asbesotos siding. May be hard to match the pattern though. You can paint the siding to change the color.
Old 08-18-2013, 11:48 PM   #12
stacker of sticks
Rewards Points: 590
I think certainteed make one
j_sims (08-21-2013)
Old 08-19-2013, 06:49 AM   #13
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
I've removed quite a bit of asbestos siding and even more asbestos roofing. We always ordered a dumpster like normal but you have to tell them what you are doing and that you need a liner. They make liners that fit the inside of the dumpster. I don't think that pricing is to bad. I would call the around to couple local dumpster companies and see what you can find out. They are going to know what standard procedure is in your area better than anyone on here.
I wouldn't think Missouri wouldn't have to much red tape to go around. In Cali it would probably cost you 100 k just to get it removed.
Spencer is offline
Old 08-19-2013, 07:14 AM   #14
hdavis's Avatar
Rewards Points: 514
Double check state laws, which can be more restrictive.
hdavis is offline
Old 08-19-2013, 07:23 AM   #15
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 52
Around here I can't remover the stuff , but the home owner can, remind you of any current situation like lead paint? In past when have resided over them it was normal to just leave cover with fanfold and side. And yes at times do have to fir the openings out.
Randy Bush is offline
Old 08-19-2013, 07:29 AM   #16
stacker of sticks
Rewards Points: 590
It's actually less restricted then I thought
Old 08-19-2013, 07:37 AM   #17
Educator of Codes
jar546's Avatar
Rewards Points: 164
Have done it before by adding furring strips and packing out the windows and doors. it was cheaper than stripping down and hauling away asbestos and kept the neighbors happy.
Up until 1998 we had some leftover asbestos siding in stock but then sold the cutter and after that, never touched it again except to cover it with cheap vinyl.
jar546 is offline
Old 08-19-2013, 10:20 AM   #18
hdavis's Avatar
Rewards Points: 514
Looks like your buddy is good to go.
hdavis is offline
Old 08-19-2013, 08:47 PM   #19
spazman
spazman's Avatar
Rewards Points: 2
Thanks for all the input guys. I'll pass the info on to him.
spazman is offline
Old 08-20-2013, 11:40 AM   #20
Livin the dream...
Spencer's Avatar
All I can say is if asbestos is as bad as everyone acts like it is I am screwed. Tore off to many roofs on days with no wind to take the dust away.
I did some research and decided it was harmless unless you were around it for a very long period of time. Like the navy guys who were stuck down in subs with it for years. A lot of hype for nothing IMO.
Spencer is offline
Siding Bid dc4502334 Windows, Siding and Doors 3 01-16-2013 01:43 PM
fiber cement siding issues. chapstick Windows, Siding and Doors 36 08-30-2012 08:14 PM
Asbestos Shingle Siding Prep!! Nail Ace Painting & Finish Work 16 05-17-2009 03:09 AM
siding an old house gtmstang Windows, Siding and Doors 14 12-20-2008 06:21 PM
