Four Year Old Window Trim Rotting - Windows, Siding and Doors - Contractor Talk
Old 10-19-2018, 08:59 AM   #1
sliver's Avatar
Trade: handyman
Rewards Points: 206
An HOA asked me to give a bid on replacing the trim on 60 windows and doors that are rotting on two condo buildings here in low-humidity Northern Colorado. Some mushrooms are growing. The material is hardboard and the two other buildings that were completed first used Hardie trim. Both buildings used Hardi siding. Not sure why the builder is not responsible.
Could it just be inadequate caulking? There are shutters so the sides are difficult to see.
I have never seen this before. Other, decades old buildings with hardboard trim in this area, look fine.
I have smartphone photos on my desktop but, apparently, they are too large for this particular site.
sliver is offline
Old 10-19-2018, 12:45 PM   #2
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,146
Re: Four Year Old Window Trim Rotting
For your PC get paint dot net a good lightweight photo program been around for years.
Resize > to about 640 x 360 pixel or 4x6 > Save
Then you can post.
Steve
We Fix Houses is online now
Old 10-19-2018, 10:17 PM   #3
Mordekyle's Avatar
Rewards Points: 4,404
Inadequate paint or exposed end grain I surmise.
I replace lots of trim due to no/not enough paint.
Those who can, do.
Those who canít, paint.
Mordekyle is online now
Old 10-20-2018, 10:59 AM   #4
sliver's Avatar
Trade: handyman
Rewards Points: 206
Downloaded the paint dot net and this is what I see...
sliver is offline
Old 10-20-2018, 04:07 PM   #5
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,864
If your desktop is running any modern version of Windows, open the image in "Paint"..
1. Resize what you see in "Paint" with the slider on the bottom right of the work screen.
2. Select the "Resize" control.
3. Choose the percentage option and select something less than 100%. 75 % always works for me with my older iPhone.
Then "save" the reduced image under a different file name - so you can preserve the original. Then upload the newer, smaller image.
SmallTownGuy is online now
Old 10-20-2018, 07:42 PM   #6
Here you go. At this address. A very good lightweight photo program. (That means it doesn't take 2 min to open up -- like Photoshop types)
https://www.getpaint.net/
Steve
Old 10-20-2018, 08:29 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 769
www.irfanview.com
Lightning fast, keyboard shortcuts for everything, and freeware. Been using it for years.
Tinstaafl is online now
Old 10-21-2018, 03:42 AM   #8
John the Builder
Originally Posted by Tinstaafl View Post
www.irfanview.com
One of the great things about Irf is that it does batch processing. You can view/select a whole slew of images and then apply the desired change to all of them at once.
Old 10-22-2018, 08:52 AM   #9
sliver's Avatar
Trade: handyman
Rewards Points: 206
Thanks for the tips. I am currently attempting to resize but need to run off to work soon.
sliver is offline
Old 10-22-2018, 09:17 AM   #10
sliver's Avatar
Trade: handyman
Rewards Points: 206
The other photo fails to upload.
sliver is offline
Old 10-22-2018, 01:38 PM   #11
jarhead0531's Avatar
Trade: Electrician and Remodeler
Rewards Points: 119
That looks like bacon. Do not replace this magic wood that grows bacon. MMMMMM, bacon.
Just kidding. Without seeing more its hard to say. Need more information and pictures. Is it a multi story building? Is this only on first floor? Do you see evidence of caulking? With that type of rot after only 4 years I wouldn't be surprised if the sheathing is also getting wet below the window.
Honestly this is one of those time where you won't know until you start taking stuff apart IMO.
jarhead0531 is offline
Old 10-22-2018, 08:10 PM   #12
sliver's Avatar
Trade: handyman
Rewards Points: 206
Two story, multi unit condo buildings.
Yes, I will not know what if there is any damage until I pull of the pork belly trim.
Keep getting Error 520 messages when trying to upload the next photo which I reduced to 75% then tried 25%.
https://screenshots.firefox.com/0tLA...ractortalk.com
sliver is offline
Old 10-23-2018, 05:24 AM   #13
John the Builder
That might be a current, but temp issue with the site.
Old 10-23-2018, 08:51 AM   #14
sliver's Avatar
Trade: handyman
Rewards Points: 206
One more try...
sliver is offline
Old 10-24-2018, 11:27 AM   #15
Lettusbee's Avatar
Rewards Points: 674
Having run miles of 1x4s around windows in NoCo, I can tell you that the hardboard 1x can get mushy within a year. Not in every situation, but often enough that I flat out quit using it.
My regular go to is the OSB based Smart Trim from LP. If I have to use a smooth product, I'll go with Miratec. TJBNWI recommends Boral, but nobody up here that I know of keeps it in stock.
Hopefully they used decent housewrap, and installed it correctly, or there will be rotten sheathing.
Lettusbee is offline
Old 10-24-2018, 07:32 PM   #16
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,358
Ive seen a lot of that material rot. 3 mil Blow and go builder paint job goes 15 years without maintnenance. Then the conro board takes the lowest bid again. Everything powerwashed and sprayed with another 3 mils of paint and then 5 more years go by...
sparehair is offline
Old 10-25-2018, 09:11 AM   #17
sliver's Avatar
Trade: handyman
Rewards Points: 206
They agreed to allow me to remove the trim from one window, access the situation then replace with Hardi trim. I will report back.
I also live in FC and oddly have never seen this before. I replaced most of the cedar trim on my 1986 house with hardboard when I painted 15 years ago and it still looks new.
sliver is offline
Fastening exterior window trim Callipygous Windows, Siding and Doors 2 09-28-2017 06:12 PM
Basement window trim - best practice? FCCOH Construction 6 01-31-2011 11:32 PM
Trim a Kitchen Window in tile or wood? NLB Kitchens & Baths 1 01-19-2011 01:44 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
