Foam Backed Vinyl Siding - Page 2 - Windows, Siding and Doors - Contractor Talk
Old 02-01-2016, 03:11 PM   #21
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,206
Re: Foam Backed Vinyl Siding
Originally Posted by red_cedar View Post
I see what you mean about thickness.
I'm pretty sure the 1 1/4" thickness is measured at 'butt' thickness and not the nailing flange where it is about 1/2 inch.
So if I added another 1/2" my nail-able thickness is apx. 1" + the 1/2" thats already there.
I'm pretty sure I should try to increase the exteriors R rating. Last time will need to be done in my lifetime, hopefully
Good point though.
I see ,being I don,t do vinyl did not really know. But being that is all it is agree not a issue.
Sent from my LG-V410 using Tapatalk
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Tom Struble (02-01-2016)
Old 02-01-2016, 03:26 PM   #22
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
years ago we used to do insulated aluminum,fiber or foam was attached to the panel with glue
Tom Struble is offline
Old 02-04-2016, 11:59 AM   #23
windows & siding
HomeSealed's Avatar
Trade: windows and exterior remodeling
Rewards Points: 618
I'd suggest installing to manufacturer specs unless you want a voided warranty. I can't say that I have ever seen foam backed siding installed into a built out, shallow j-channel where the foam was cut back. I understand the concept of what you are worried about, but I'd leave that to the engineers that designed the system in the first place.
HomeSealed is offline
The Following User Says Thank You to HomeSealed For This Useful Post:
Tom Struble (02-04-2016)
Old 02-04-2016, 03:57 PM   #24
Trade: siding
Rewards Points: 20
that's true because the foam, depending on the temp installed should either have a 1/4'' gap between the foam or be butted tight
Old 02-06-2016, 07:44 AM   #25
red_cedar's Avatar
Rewards Points: 1,250
The foam manufacturer also offers a product 1/2" thick called 'easy shim'. In case you dont have the 1 1/4" J one could use regular 3/4" J.
I ended up so far shimming everything so far.
red_cedar is offline
The Following 2 Users Say Thank You to red_cedar For This Useful Post:
HomeSealed (02-09-2016), Tom Struble (02-06-2016)
Old 02-06-2016, 10:37 AM   #26
Trade: siding
Rewards Points: 20
i get it..just seems like more work to cut back for..well let's say uncertain results
but if you think it's worth it i get that
Old 02-06-2016, 07:16 PM   #27
red_cedar's Avatar
It is extra work but it will come out nice. Not pressured to get it done and make money. Sure is taking a little while though, everything I'm doing.
The Following User Says Thank You to red_cedar For This Useful Post:
Old 02-06-2016, 07:34 PM   #28
Randy Bush's Avatar
Would be nice to see some picture of what and how you are doing things.
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
hammer7896 (02-06-2016), Tom Struble (02-06-2016)
Old 02-16-2016, 05:54 PM   #29
red_cedar's Avatar
This question goes to what Randy brought up. Length of nails.
The house has a 1/2 inch rigid foam over the studs. I'm thinking of adding another 3/4 inch rigid foam and then the siding foam which adds another 1/2 to the needed length at the nailing flange. Will 2 3/4 or 3 inch nails be to long to adequately hold the siding up?
Old 02-17-2016, 12:34 AM   #30
Randy Bush's Avatar
Figuring the house has 1/2 sheeting that would only give you roughly 3/4 into the stud using 3"nails. Not a lot. Maybe Tom or someone else has done something like this and has some input.
Old 02-17-2016, 08:11 AM   #31
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 110
General rule when you get past an 1.5 to 2" you need to use furring strips for regular vinyl siding - many manufacturers do have preferred methods for installing their products
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
red_cedar (02-17-2016)
Old 02-17-2016, 09:09 AM   #32
red_cedar's Avatar
Have not yet checked the manufacturer, but did with the Vinyl Siding Institute. Their information says 1 1/4 penetration with fastener into wood.. My situation is 1/2 inch + 3/4 + 1/2 = 1 3/4 inches of insulation.
a 3inch nail should work.
Maze sells 3 inch vinyl siding nails. Wont mind furring strips, but would I not be losing some R value with the wood?
Old 02-17-2016, 09:10 AM   #33
oldfrt's Avatar
Rewards Points: 94
Had a somewhat similar application a few years back.
The house had double layered shakes and we added 1"
foam over before siding.Figuring the siding at 1",foam1",
1/4 " for nail's hanging loose,leaving 3/4" into sheathing.
Called siding rep. for installation recommendation.
The 3" nails worked fine because the siding offered
some lateral support.
With just foam board,I'd of gone with the furring.
One thing that was recommended, was to close off
the bottom of siding insulation plane to keep "wind wash"
from creating condensation from forming between the
wood siding and 1" foam,since the house had minimal
insulation in the walls.
Foam backed vinyl siding-407491_194550623974779_2108318990_n.jpg   Foam backed vinyl siding-315450_303607053069135_2014238593_n.jpg
oldfrt is offline
The Following User Says Thank You to oldfrt For This Useful Post:
Old 02-17-2016, 09:34 AM   #34
red_cedar's Avatar
I actually was going to do that, mostly to deter mice from getting up there and chewing the insulation.
Old 02-17-2016, 11:13 AM   #35
Trade: siding
Rewards Points: 20
yea but look at that,the up bend is in the wrong position in the drainage plane,we used to cap the bottom over the foam all the time
This is where all the water that gets behind the siding will end up in that bend leading directly into the plate
I guess the top edge can be taped but maybe be best is to cap the bottom in 2 jumps,do the first bend from foundation to under the house wrap then from the foam to the first wrap.that will break any water from getting to the house..jmo
..personally i wouldn't be too concerned about the longer nails..just add more of them,go 10-13 o.c. with the nails,but the mechanic will know is the nailing isn't adequate..or should
Old 02-17-2016, 02:14 PM   #36
oldfrt's Avatar
Rewards Points: 94
This return is 2" below the plate,anything that gets behind it will drain out onto the block foundation,and my siding doesn't leak!
oldfrt is offline
Tom Struble (02-17-2016)
Old 02-17-2016, 04:40 PM   #37
Trade: siding
Rewards Points: 20
meant no disrespect John..just musing philosophical like..
Old 02-17-2016, 05:00 PM   #38
red_cedar's Avatar
After some reading, like the certainteed vinyl recommendations/ requirements, I'll just limit the extra rigid foam to 1/2 inch. Its still a 1/2 more than certainteed requires but the 3inch steel maze nail will help hold it up. Dont know yet though. Cant add more nails as the wall assembly is 1/2 foam over the framing. I suppose evey 4 ft. I could use some 3" screws?
Thanks guys
Old 02-17-2016, 05:05 PM   #39
Trade: siding
Rewards Points: 20
oh..no wood sheathing?then yea..forget that
Old 02-17-2016, 05:08 PM   #40
Randy Bush's Avatar
Thanks guys
That is the pits no sheeting. I have done houses in the past done that way . Pain working around the meter box and such.
Health Side effects of cutting Vinyl Siding MarkGreer General Discussion 19 09-11-2014 11:02 AM
vinyl siding over old aluminum? ccmorical Windows, Siding and Doors 12 04-09-2013 10:25 PM
What siding on top of 2" of polyiso? zeester Windows, Siding and Doors 26 03-14-2013 05:27 AM
Tyvek under 1/4in foam for Vinyl siding? PittTrack Windows, Siding and Doors 66 06-22-2012 12:56 PM
Vinyl Siding - what's wrong with this Picture Palagi General Discussion 76 03-31-2010 09:57 PM
