Foam Backed Vinyl Siding - Windows, Siding and Doors - Contractor Talk
Old 01-27-2016, 10:42 AM   #1
red_cedar's Avatar
Rewards Points: 1,250
My vinyl siding with foam thickness will be 1 1/4"., Would it be better to shim the 3/4" J channel with 1/2" foam or use a 1 1/4" J Channel and slide the whole thing in.
I'm thinking using the 1 1/4" the foam against the inside of the channel will help cause wicking of water towards the inside.
All corners, top, window/ door sides. Has anyone done it both ways to say which way might be better.
red_cedar is offline
Old 01-27-2016, 02:56 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Foam Backed Vinyl Siding
..the only reason i would use 3/4'' pocket would be because i couldn't find the 1 1/4'',i guess i'm not following this wicking problem
Tom Struble is offline
Old 01-27-2016, 03:34 PM   #3
red_cedar's Avatar
I was just getting ready to clarify.
Perhaps not so much wicking ( wrong way to phrase) but more of using the foam to draw the water in. Kind of like not clipping the corners on a asphalt shingle valley. But I think more like the small space between the siding itself and the foam creating a suction if you will?
As far as the J channel I was going to make it.
Probably go with a 3/4" channel. Thanks Tom.
The Following User Says Thank You to red_cedar For This Useful Post:
Tom Struble (01-28-2016)
Old 01-27-2016, 03:35 PM   #4
Trade: siding
Rewards Points: 20
but it will deadend at the back of the j..i see no issue with that
Old 01-27-2016, 05:35 PM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,202
Is the 1 1/4 the thickeness when lapped? Personally I would use the channel that is recommended for that situation. I know with steel siding I use 1 1/8 J when I use a drop in backer and it comes close to filling the channel . I have made J before , but would rather not when using it around openings. Little harder to wrap the corners the way I do it. But then again vinyl is done different so not sure that would work out.
Randy Bush is online now
Old 01-28-2016, 07:12 AM   #6
red_cedar's Avatar
The 1 1/4 is the overall thickness of the siding with foam. I think I'm going to go with the 3/4 and I ll tell you why.
I do believe if the foam and siding fit into the J it would draw water in. How far I don't know, perhaps to the end of the J, perhaps not. Would depend on what point in the siding/ foam it was drawing water from.
At times I install metal shingle/ shake roofing products that utilize a 'fitted foam in areas of roof traffic, such as along the sidewalls.
The sidewall channel is a more like a F channel with a hem on the roof side used a water channel. I do not extend the foam into the channel or even on the flashing itself. Water would hit the foam and carry in past the hem.
Siding would be similar, but not as prone to the drawing in.
Don't do much siding so never had to think about it before.
In an effort to keep the look uniform I'm making all the corners , door/ window lineals, gable and soffit frieze from PVC coated aluminum.
Thanks guys for your input.
Old 01-28-2016, 07:15 AM   #7
Trade: siding
Rewards Points: 20
oh..i get your point now
Old 01-28-2016, 07:51 AM   #8
Trade: siding
Rewards Points: 20
who's panel are you using?
Old 01-28-2016, 07:53 AM   #9
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 110
You are talking about capillary action, correct or are you worried about surface tension?
Personally I would be more worried about the field. It shouldn't draw water in from the ground up as you should have a gap there, the bulk of the water hitting the siding is going to drain straight off. 1% will not (on average) which will not be focused only at corners, etc... but the whole field where it can be trapped (depending on the vinyl / foam system - some have channels to drain water away). This can be wicked up, but mostly it will try moving into the structure or back out.
If you are really concerned I would add a 1/4" drainage plane all the way around & use the J, etc... designed for that siding. Using the proper J allows for draining, expansion & contraction. As for how far can surface tension pull the water around the corners & under - it all depends but most drains out fine under normal circumstances & that is why we have WRB's & proper flashing for what might get past.
SLSTech is offline
The Following 2 Users Say Thank You to SLSTech For This Useful Post:
red_cedar (01-28-2016), Tom Struble (01-28-2016)
Old 01-28-2016, 08:02 AM   #10
Trade: siding
Rewards Points: 20
Crane's panel uses a contour on the back that they claim helps
Old 01-28-2016, 08:26 AM   #11
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
The crane panel wouldn't fit in a 3/4" J without pushing the J out.
BamBamm5144 is offline
The Following User Says Thank You to BamBamm5144 For This Useful Post:
Old 01-28-2016, 08:40 AM   #12
red_cedar's Avatar
Revere Sovereign select D4 Clapboard with 'Full Back' foam
When I started this off I was thinking of the corners and any vertical abutment which would utilize a type of J flashing.
The Revere would also if one didn't shim a 1/2" behind the 3/4" J
BamBamm5144 (01-28-2016)
Old 01-28-2016, 09:14 AM   #13
Randy Bush's Avatar
That would be my concern too, not a nice look when it does that.
Old 02-01-2016, 06:29 AM   #14
red_cedar's Avatar
I may end up needing to put an additional 1/2" R3 foam board up for added insulation. Do you guys think I should put it over the new house wrap or behind?
Old 02-01-2016, 08:01 AM   #15
Randy Bush's Avatar
If you do that you will need to use furring strips to right.
Old 02-01-2016, 08:20 AM   #16
red_cedar's Avatar
Why?
Old 02-01-2016, 08:24 AM   #17
Sean
SLSTech's Avatar
Rewards Points: 110
It depends really on how you flash your windows - for more:
http://thehtrc.com/2013/common-sense...istive-barrier (about 1/3 of the way down)
Not sure what Randy is getting at, unless he is calling out for the rain screed detail. The other item is check with the manufacturer for how they would prefer it to be done
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
red_cedar (02-01-2016)
Old 02-01-2016, 09:39 AM   #18
Randy Bush's Avatar
If adding 1/2 foam and the siding is 1 1/4 or more with its foam ,that is hanging a long ways out on a nail is all.
Sent from my LG-V410 using Tapatalk
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
red_cedar (02-01-2016), SLSTech (02-01-2016)
Old 02-01-2016, 10:21 AM   #19
red_cedar's Avatar
I see what you mean about thickness.
I'm pretty sure the 1 1/4" thickness is measured at 'butt' thickness and not the nailing flange where it is about 1/2 inch.
So if I added another 1/2" my nail-able thickness is apx. 1" + the 1/2" thats already there.
I'm pretty sure I should try to increase the exteriors R rating. Last time will need to be done in my lifetime, hopefully
Good point though.
The Following 2 Users Say Thank You to red_cedar For This Useful Post:
Randy Bush (02-01-2016), Tom Struble (02-01-2016)
Old 02-01-2016, 01:55 PM   #20
Trade: siding
Rewards Points: 20
there is not even 1/2'' of foam at the flange,nail length is no issue there
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Randy Bush (02-01-2016), red_cedar (02-01-2016)
Health Side effects of cutting Vinyl Siding MarkGreer General Discussion 19 09-11-2014 11:02 AM
vinyl siding over old aluminum? ccmorical Windows, Siding and Doors 12 04-09-2013 10:25 PM
What siding on top of 2" of polyiso? zeester Windows, Siding and Doors 26 03-14-2013 05:27 AM
Tyvek under 1/4in foam for Vinyl siding? PittTrack Windows, Siding and Doors 66 06-22-2012 12:56 PM
Vinyl Siding - what's wrong with this Picture Palagi General Discussion 76 03-31-2010 09:57 PM
