First Time With Andersen - This A Problem? - Windows, Siding and Doors - Contractor Talk
Old 07-15-2015, 05:49 PM   #1
JD_services's Avatar
Trade: WIndow Installation
Hi
Image attached.
Installing Andersen windows - Home owner is displeased at the aluminum miter joint - the silicone Andersen use is grey and the trim is Bronze - I`m going to try clean up the lumps in the corners with some spirits but I expect the joint will still be highlighted by the grey silicone.
Is this "normal"?
I didn't sell the windows - the supplier (not Andersen) says its to be expected.
I don't see this on the joints on cheaper windows I install.
What finish should I expect to see?
J&D
JD_services is offline
Old 07-15-2015, 08:39 PM   #2
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: First Time With Andersen - This A Problem?
That's probably the best they could do.
color match and paint with a fine brush, like for models.
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 07-15-2015, 08:48 PM   #3
I suggested painting - home owner was not too happy.
Is this normal for Andersen? Their joints are not color matched and a bit on the sloppy side?
Old 07-15-2015, 08:52 PM   #4
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Are you the installer only?
If so, wouldn't stuff like that be 100% completely Andersen's warranty/QC problem?
EDIT: No, in fact it would be Andersen's problem even if you sold the windows.
That's what they have a warranty dept for.
SmallTownGuy is offline
Old 07-15-2015, 09:29 PM   #5
Tom M's Avatar
Rewards Points: 730
I would say its normal. Anderson is pretty liberal with the silicone in joints.
Not the worst thing
Tom M is online now
Old 07-15-2015, 09:47 PM   #6
Yes, I`m just installer but doing other work on home so trying to be helpful. The person who sold the units was saying grey miter joints was to be expected in Andersen line. Owner has already asked to get meeting with the Andersen rep.
If anyone has been through similar circumstances info appreciated.
Old 07-15-2015, 10:02 PM   #7
Box Builder
Morning Wood's Avatar
Rewards Points: 6
I don't know anyone who spends that much time looking at the exterior of windows. Rub the excess off the joint. What else can you do?
Morning Wood is offline
The Following 3 Users Say Thank You to Morning Wood For This Useful Post:
NYgutterguy (07-16-2015), SmallTownGuy (07-16-2015), Tom Struble (07-21-2015)
Old 07-15-2015, 10:18 PM   #8
After cleaning it up the grey seam will still be visible. Customers don't want repairs on new windows.
Old 07-15-2015, 10:19 PM   #9
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Be thankful your not dealing with the older Frenchwood sliders that gooped a 3/8" perimeter bead of silicone with finger smudged corners around the massive glazing. Thank god the latest models deleted that feature.
supersealconstruction.com
superseal is offline
Old 07-16-2015, 01:37 PM   #10
GettingBy's Avatar
Rewards Points: 6,486
Anderson was dismissive with me when I complained about their snap-in grids/muntins not seating properly in their doors.
If I'm going to be their testing lab they should pay me.
GettingBy is offline
Old 07-16-2015, 02:18 PM   #11
TimberlineMD's Avatar
Rewards Points: 738
I wouldn't do anything more than the normal install. If you start messing with the sealant, then Anderson could hold you responsible for leaks and void their warranty.
It's easy to have a business that is busy.. it's harder to have a business that makes a profit
TimberlineMD is offline
The Following User Says Thank You to TimberlineMD For This Useful Post:
CompleteW&D (07-16-2015)
Old 07-16-2015, 03:46 PM   #12
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
EXACTLY.... We had a house full of WeatherShield windows that had some small gaps in the cladding of a few of the windows. They don't use any sealant in the corners of their cladding, because normally they don't need to.
After consulting with the rep, he told us to use a color matched caulk to seal them and they paid our travel time, material and labor. The customer was quite pleased.
But, in the OP's situation, I would not do anything until Andersen looks at it and decides what or what not to do.
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
Old 07-16-2015, 04:09 PM   #13
TimNJ's Avatar
Rewards Points: 870
Who "owns" the windows?
If you are merely supplying labor for install then it is not your problem.
Have Andersen send a rep out, finish your job, and get away from this customer ASAP.
TimNJ is offline
The Following 2 Users Say Thank You to TimNJ For This Useful Post:
CompleteW&D (07-16-2015), Tom Struble (07-21-2015)
problem with a large order of pond products Outdr Contractr General Discussion 6 12-20-2012 07:51 AM
FHW heating system problem porterbruce HVAC 8 11-25-2012 11:45 PM
Problem with my 1997 DPQ250 towable sullair compressor midnightblaster Tools & Equipment 0 11-06-2012 08:54 AM
Time estimate help SD DMB Sandblasting 12 09-04-2012 08:14 AM
Need to hire full time repair man/woman in phoenix arizona, now!! Phoenix8 Help Wanted or Looking For Work 24 05-16-2012 04:39 PM
