Exterior Door Out Of Square - Windows, Siding and Doors - Contractor Talk
Old 02-14-2020, 07:45 PM   #1
Cjm2019's Avatar
Rewards Points: 2
Got my windows and doors for a remodel in this week and installation was moving along smoothly until this afternoon. Was installing a Marvin ultimate swinging french door and ran into an issue. Leveled the threshold, plumbed both jambs and checked the head jamb. Shot them with a laser so i know they are dead on, shimmed and screwed at hinges. The door on the left had perfect reveals all around, but the door on the right was rubbing the threshold on one side and up about a strong eighth on hinge side, the reveal at the head jamb was showing the same thing, while the reveal where the doors meet and the hinge side reveal were perfect. After spending ample time messing with it and wondering what the hell was going on i decided to check my corner to corner measurements on the slab. Sure enough my diagonals measure 3/16 different on this door slab. This is my first time running into a slab that is out of square and quite surprising on an 8k door. Going to have the sales rep come out to check it out and make it right next week, but was just wondering if anyone here has ever run into a similar problem?
Cjm2019 is offline
Old 02-14-2020, 08:13 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 46
Re: Exterior Door Out Of Square
yes, i have seen this scenario before on residential & commercial doors.
we fixed the residential on site & the commercial was aluminum storefront doors.
VERY aggravating until you figure out whats going on...
good luck...
griz is online now
The Following 3 Users Say Thank You to griz For This Useful Post:
KAP (02-15-2020), Patrickstew (02-27-2020), Tom M (02-14-2020)
Old 02-14-2020, 08:40 PM   #3
VinylHanger's Avatar
Rewards Points: 14,180
Yep. Pretty common. Also, you may have a jamb that isn't square
I spent two days trying to get an out swing french door to work a while back. Should have been an hour or so at most.
The jamb wasn't square by 1/4 inch, the doors were hung 1/8 inch off in height and the two doors were mortised 1/8 inch in depth different. Also, the mullion catch was cut wrong and wasn't adjustable. Add in modern noodle like jambs and working solo to begin with and it was a nightmare.
I spent a day trying to get it to work on an unlevel slab which made things worse. Then I started really looking and found all the mistakes.
I changed suppliers and they mill all thier own jambs and haven't had many issues.
Sent from my SM-N975U using Tapatalk
VinylHanger is online now
Old 02-14-2020, 08:41 PM   #4
diplomat
Golden view's Avatar
Rewards Points: 1,550
Those doors also have trick hinges that let you adjust all over the place. Not that that helps with the out of square slab.
Golden view is offline
The Following 4 Users Say Thank You to Golden view For This Useful Post:
KAP (02-15-2020), MarkJames (02-14-2020), Patrickstew (02-27-2020), Tom M (02-14-2020)
Old 02-14-2020, 09:02 PM   #5
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
It's always a treat to get doors and frames that ARE square.
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
griz (02-14-2020)
Old 02-14-2020, 09:16 PM   #6
Cjm2019's Avatar
Rewards Points: 2
Good to know i'm not alone, was driving me nuts for a bit trying to figure out what was wrong with it.
Cjm2019 is offline
Old 02-14-2020, 09:56 PM   #7
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,220
I’ve had problems with Marvin products before .
The good news is they bent over backwards to make it right .
We had some windows with some minor defects . They sent out a rep , confirmed it was their fault , then sent their own technicians to install the replacements.
It did take a few weeks , it was an inconvenience, in the end I and the customer were satisfied.
Much better experience than with other manufacturers when a problem comes up. In my experience Marvin stands behind their products
Molon Labe —— King Leonidas of Sparta
Freedom of choice is what you got
Freedom from choice is what you want—— Devo
Idothat is offline
The Following 2 Users Say Thank You to Idothat For This Useful Post:
Golden view (02-14-2020), Patrickstew (02-27-2020)
Old 02-14-2020, 11:54 PM   #8
Unregistered learner
MN_general's Avatar
Trade: Whatever you want
Rewards Points: 108
I’ve had problems with Marvin on multiple jobs that makes me want to drop them. But then again all products coming out are crap, from all manufacturers
People who think they know everything are a great annoyance to those of us that do.
MN_general is offline
The Following User Says Thank You to MN_general For This Useful Post:
TimNJ (02-26-2020)
Old 02-15-2020, 11:42 AM   #9
I've had great service from Milgard out here. As well as Pella on old service calls for parts and information.
Old 02-26-2020, 02:00 PM   #10
GTXKen's Avatar
Rewards Points: 58
Spent Nearly $4000 on an MMI door for a customer, 36" with 2 12 side lights. Could not get the door to seal properly because the mull post on the latch side was 3/8 longer than the one on the hinge side.
GTXKen is offline
Old 02-26-2020, 02:05 PM   #11
rrk's Avatar
Rewards Points: 80
That may have been a distributor issue not the mfg. That’s the problems I see with distributors here. Most doors are mounted at the distributor
rrk is online now
Old 02-26-2020, 06:50 PM   #12
TimNJ's Avatar
Rewards Points: 870
You will drive yourself insane and also to the poor house if you rely strictly on using a level to install doors.
Way too many variables from manufacturers when they put them together.
I do a quick look on the sill and hinge leg and after that it's all by eye with the reveals and feel when closing and opening.
TimNJ is offline
The Following User Says Thank You to TimNJ For This Useful Post:
hammer7896 (02-26-2020)
Old 02-26-2020, 09:28 PM   #13
Donohue Const's Avatar
Rewards Points: 1,726
yeah, I was taught not to rely on a level to install a door
I usually check the hing side and sill, then adjust everything to operate smooth and have a good reveal
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is online now
The Following User Says Thank You to Donohue Const For This Useful Post:
Dirtywhiteboy (02-26-2020)
Old 02-27-2020, 08:14 PM   #14
Patrickstew's Avatar
Trade: Exterior Remodel and Repair Contractor
Rewards Points: 408
Second the warranty response with Marvin. They’re really strong here in Southern Region for making things right.
Sent from my iPad using Tapatalk
Patrickstew is offline
