Cinderblock Wall - Windows, Siding and Doors - Contractor Talk
Cinderblock Wall
Old 01-30-2006, 05:29 PM   #1
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Cinderblock Wall
I need to enlarge an opening in an interior wall (concrete block) from 2 ft. to 12 ft. x 8ft. high. What is the easiest way to bring down the blocks? I'm thinking of hammering into the mortar lines with a concrete chisel and then just smash the blocks with a sledgehammer. Install a lintel recessed a min. 12" on each side, and Bob's your uncle. This is in a showroom of a carpet store and I would rather not use a concrete saw. Advise?
ron schenker is offline
Old 01-30-2006, 08:10 PM   #2
bob the builder's Avatar
Rewards Points: 250
Re: Cinderblock Wall
Or you could invite a karate class to perform a demonstration on your wall...
bob the builder is offline
Old 01-30-2006, 08:20 PM   #3
i_plant_art's Avatar
Rewards Points: 75
why not use a concrete saw???? so much easier and fast dontya think. the vibrations from the hammer could possible crack the block in other places, not to mention the sound, and how "rough" a cut it would make vs. the saw. personally i would use the saw and the ole sledge to knock out the inner portion.
i_plant_art is offline
Old 01-30-2006, 08:35 PM   #4
mdshunk's Avatar
Rewards Points: 2,002
That's why God made Zip Walls. Get yerself one, or fashion something, then go to town with the concrete saw.
mdshunk is offline
Old 01-30-2006, 09:28 PM   #5
ATS's Avatar
Rewards Points: 150
What I's would do is, buy a 40 dollar concrete blade for my circ. saw and cut the block to your dimensions, then do your sledge work. Piece a cake! And a good looking end result.
ATS is offline
Old 01-30-2006, 09:56 PM   #6
Teetorbilt's Avatar
Rewards Points: 2,000
Isn't there a lintel already in place? I would replace the lintel first and then widen the opening. How many courses of block are overhead and how much are they supporting?
Albert Einstein
Teetorbilt is offline
Old 01-30-2006, 10:32 PM   #7
locofoco's Avatar
Rewards Points: 75
Teetor is right do that lintel 1st. 12 feet is a good span to support.
One thing I've done in the past, when I've wanted to keep the dust down is to take a GOOD hammer drill with a small bit (1/4"-1/2") and score the opening (holes 1/2-1") apart on both sides. It's a good job for a new apprentice, etc. Slow but it works. Then use sledge or electric demo hammer.
locofoco is offline
Old 01-30-2006, 10:39 PM   #8
Teetorbilt: The opening now is 2 ft. wide by 8 ft. high, I want to increase that to a 12 ft. wide opening. There is a 2 ft. lintel now that I will tear out and replace with a 12 ft. lintel. The new lintel will be fine structurally, there's only the roof above and it's not a loadbearing wall. This new opening will open up the other showroom beside it allowing customers better access. I thought about the saw, but isn't it really dusty and loud.
Old 01-30-2006, 11:45 PM   #9
IHI's Avatar
Rewards Points: 1,040
Do you have any wall swawing contractors in your area? I used to cut in my own openings for egress but found by the time I rented a saw, set everything up, cleaned everything up the extra $100 I spent to have it done by a specailist was well worth the money since there's no easy way to cut concrete in living spaces and confined walls to prevent dust bowls.
Gas saws work great outdoors cutting but do not go deep enough into 8" block so you have to cut inside. gas models will trigger co2 detectors and fill the house with exhaust smoke...i know. Electric quickie's suck cuz they dont have the brute power of gas and it takes forever, not to mention they love bursting fuses/breakers in older homes...did I mention teh dust problem since you typically try and make "fallout" area as small as possible?
I have'nt rented it, but have heard the concrete chain saws work very well with minimal dust as compared to quickie saws...only problem is you get charged every way possible for them from the saw itself, then the blade, then the wear on the blade....heard rental for a chain saw & masonary blade from a rental store typically runs in the $4-500 range and that's $200 more than it costs me to have it done if we dig the hole and only costs $500 to have hole dug and hole cut if I get lazy and sub out that entire deal
Either way you rgonna need to cut in the I beam prior to cutting anything out, that's too wide of a span to trust the unsupported block to hold itself up..waay too much liability there for somebody getting hurt badly.
IHI is offline
Old 01-31-2006, 04:25 PM   #10
Thanks guys, gonna start thurs. morning. I'll keep you posted.
Old 02-01-2006, 08:55 AM   #11
GC
Jess's Avatar
Trade: General Contractor - Remodeling Secialist
Rewards Points: 25
Ole Teeter is thinking ahead - here in Fla we deal a lot with masonry walls. Even if this is an interior non-bearing wall, the courses above the existing 2' lintel could put a goose egg on your cap. I would consider taking the block down to my plate height and infill framing the space above with metal studs. What is the finished wall surface - will you cover it with DW? Over the years I,ve created new openings in masonry walls at least a dozen times. Tried everything from 21" diamond blade elec wet saws to drill & sledge. Drill your holes and call for a renta-drunk.
Ps - tell the agency he needs goggles, gloves, and hard hat an workers comp.
Jess is offline
Old 02-02-2006, 08:51 PM   #12
Job got postponed until Monday. However,upon second inspection I noticed that there had been a large opening there at one time complete with lintel. It is just a little bigger than the client wanted. He says the place was an auto repair shop many years ago. It looks to me like it was a big garage door that got cinder blocked up to allow for 2 smaller retail showrooms. I explained how it would be a little cheaper for him to let me open it back up to the way it was, rather than the other way with a new lintel and smaller opening. He's fine with that, so Monday we'll have sledgehammers in hand (no saws, wet or dry) and drill some holes along the mortar joints and start smashing. I luv demolition, it makes me feel macho!
Old 02-02-2006, 09:03 PM   #13
Teetorbilt's Avatar
Sounds to me like you're 'in like Flynn'.
Albert Einstein
Old 02-03-2006, 05:50 PM   #14
jmic's Avatar
Bob might just want to drive his new skid steer up there and knock down that wall fer ya.
Joe
jmic is offline
Old 02-03-2006, 06:52 PM   #15
C'mon up Uncle Bob, I'll buy the beer!
Old 03-06-2006, 06:30 PM   #16
Finally got ok'd for this job last week. Here's a before and during picture.
Old 03-06-2006, 06:34 PM   #17
Here's the before, I couldn't do both pictures on the same post!
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 06:16 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 10:27 PM
moving centennial wall stacker Masonry 4 10-19-2006 11:12 PM
Roof sagging wall pushed out christy Roofing 5 10-14-2006 08:53 PM
Low (12" or so) brick garden wall questions bindersbee Masonry 8 04-27-2006 07:31 PM
