Attaching White PVC Trim To CMU Block Wall. - Windows, Siding and Doors - Contractor Talk
Old 06-18-2016, 04:45 PM   #1
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Looking for ideas on how to attach PVC sheets and other PVC trim details to a CMU wall.
Would like glue and fasten with Tapcons then use cortex plugs but not sure if Cortex makes a larger size plug?
Any advice would be great
festerized is offline
Old 06-18-2016, 05:26 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Attaching White PVC Trim To CMU Block Wall.
i don't even think you can buy just plugs..large or otherwize
Tom Struble is offline
Old 06-18-2016, 06:03 PM   #3
David Festa
festerized's Avatar
I'll end up making my own
Old 06-18-2016, 06:24 PM   #4
mako1's Avatar
Rewards Points: 1,094
That's what I'd do.Buy a plug cutter and make your own.Wish I knew where all my plug cutters went over the years .They seem to disappear quicker than anything else.
Plug cutters and countersinks.
mako1 is offline
The Following 2 Users Say Thank You to mako1 For This Useful Post:
festerized (06-18-2016), Tom Struble (06-19-2016)
Old 06-18-2016, 10:16 PM   #5
Lettusbee's Avatar
Rewards Points: 1,820
Instead of tapcons, i like to drill a 3/16 hole, insert solder and use grk screws. Tapcons always seem to break at the worst time. Any one else use the solder trick?
Lettusbee is offline
The Following 5 Users Say Thank You to Lettusbee For This Useful Post:
festerized (06-18-2016), Philament (06-19-2016), Rio (06-18-2016), Tom Struble (06-19-2016), wazez (06-19-2016)
Old 06-18-2016, 11:20 PM   #6
Hack
asevereid's Avatar
Rewards Points: 538
No... But I like that idea
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
The Following User Says Thank You to asevereid For This Useful Post:
Rio (06-18-2016)
Old 06-19-2016, 05:13 AM   #7
wazez's Avatar
Trade: masonry
Rewards Points: 784
I gotta remember this. I will be fastening wood trim to a CMU wall in my house.
When you say solder are you talking just a short piece cut off a roll of solder?
wazez is offline
Old 06-19-2016, 09:10 AM   #8
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 2,095
Gorilla glue?
rescraft is offline
Old 06-19-2016, 10:24 AM   #9
Dan_Watson's Avatar
Rewards Points: 2,748
I agree, they always break at the worst tim . We switched to simpson Titan screws.
And they come in white.
Dan_Watson is offline
Old 06-19-2016, 10:32 AM   #10
Trade: siding
Rewards Points: 20
whats the detail dave?Can you hide most of the fasteners under additional trim?
Old 06-19-2016, 03:30 PM   #11
Lettusbee's Avatar
This is the one i use with gold deck screws, and some of the grks. It's in the welding aisle at home desperate. The solder from tge plumbing section never seemed to work. Gauge of wire, diameter of fastener, and hole diameter are all variable. I don't remember what i used for grk trim head screws, but usually have somewhere inconspicuous to experiment. Stranded copper works well also. Solid copper has never worked.
The Following 2 Users Say Thank You to Lettusbee For This Useful Post:
Rio (06-20-2016), wazez (06-19-2016)
Old 06-19-2016, 03:44 PM   #12
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
Originally Posted by festerized View Post
Looking for ideas on how to attach ” PVC sheets and other PVC trim details to a CMU wall.
tapcon and plug but will have most likely make your own plug. make sure you use the phillips screw head tapcon that way your countersink does not have to be big enough to accommodate hex head. then scrape off excess wih chisel and 120 grit sandpaper. like it never happened.
also don't forget to back glue probab;y an overkill but you know your job and conditions. gorrilla is new structural 10oz tube is ridiculous.
measure the tap con screw head to determine bit size.
https://www.amazon.com/s/ref=nb_sb_n...ords=plug+bits
lowes and depot have them too. cheap.
CITY DECKS INC is offline
The Following 2 Users Say Thank You to CITY DECKS INC For This Useful Post:
festerized (06-19-2016), Rio (06-20-2016)
Old 06-19-2016, 04:12 PM   #13
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,242
Not to insult your intelligence, just a friendly reminder that if there's a cap/coating on the boards/panels you're using and you're making plugs for it you have to do sort of a reverse plug from scrap stock because the plug cutters are widest at the bottom.
Some good tips in this thread about making plugs in composite materials
https://www.contractortalk.com/f50/su...x-like-138362/
Out of curiosity, does anyone use the Grex concrete T-nailer (http://www.grexusa.com/grexusa/products.php5?id=2564) for this kind of situation, or is hole filling too much work?
Philament is offline
The Following 2 Users Say Thank You to Philament For This Useful Post:
Old 06-19-2016, 04:55 PM   #14
no insult here. just one of those details that can be easily overlooked.
Old 06-19-2016, 07:25 PM   #15
David Festa
festerized's Avatar
Not much details, i can hide screws along the two sides. I planned on installing 3 1/2 stock along the side to match siding corners above.
I'll get a pic of the elevation plan and house this week.
The Following User Says Thank You to festerized For This Useful Post:
Old 06-19-2016, 08:25 PM   #16
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,526
I hate Tapcons...as was mentioned they seem to strip out or break at the worst times...GRK Caliburns are about the only way I go now, haven't had one strip out or break yet...I'm sure one will strip out eventually, but so far I'm a believer!
mstrat is offline
Old 06-20-2016, 12:06 AM   #17
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
It's not really a trick is what you do when you don't have the correct fastener. You can also use a scrap piece of copper wire, zip tie tails, the handle of a lollypop, whatever ya got laying around.
The problem with concrete friction fasteners is that they require slightly different sizes of holes in block vs concrete. That's why they make specialty bits.
...But with a tapcon you will damn near never break them off in block, they work best in block with their specified drill size. Concrete is the problem.
Inner10 is offline
Rio (06-20-2016)
Old 06-20-2016, 01:31 AM   #18
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
With tapcons, it's all about, or aboot as Canadians say, proper hole size and depth, and blowing the dust out of the hole.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
bigdaddyrooster (06-26-2016)
Old 06-20-2016, 06:03 AM   #19
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Run wood or metal furring strips along the wall in a vertical pattern every 16 inches like you're getting ready to sheetrock it. Use glue and cut nails to attach the furring strips to the cmu. Then you'll have a surface that can be nailed or screwed.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Tie in New CMU block wall perpendicular to an existing CMU wall madayew Masonry 16 03-25-2016 11:12 AM
New block construction question(s) TLHWindows Construction 2 01-31-2014 01:42 AM
Coloring Mafia block Wall Nac Masonry 21 11-13-2010 07:17 AM
Block wall and electrical-commerical. ApgarNJ General Discussion 17 11-04-2010 09:33 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
