Any Idea??? - Windows, Siding and Doors - Contractor Talk
Any Idea???
Old 01-05-2020, 07:24 PM   #1
tjbnwi's Avatar
Rewards Points: 5,264
Any Idea???
Oldest daughters home, Denver area, home was painted 6-8 months ago, she says it appears to be coming from between the top siding seam.
I have not seen this in person yet.
tjbnwi is online now
Old 01-05-2020, 07:32 PM   #2
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 496
Re: Any Idea???
Roof leak/Ice damming washing junk out of the soffit?
mrcat is online now
The Following User Says Thank You to mrcat For This Useful Post:
Tom M (01-05-2020)
Old 01-05-2020, 07:39 PM   #3
tjbnwi's Avatar
Re: Any Idea???
The weather has not been bad to a point where there would be an ice dam.
Last major rain was about 10 days ago.
As far as I know there is no interior damge at all. I will check on this.
Thank you for the input.
mrcat (01-05-2020)
Old 01-05-2020, 07:43 PM   #4
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,492
Re: Any Idea???
Bat chit
NYgutterguy is offline
The Following 2 Users Say Thank You to NYgutterguy For This Useful Post:
AustinDB (01-06-2020), rrk (01-05-2020)
Old 01-05-2020, 07:44 PM   #5
tjbnwi's Avatar
Re: Any Idea???
Originally Posted by NYgutterguy View Post
Bat chit
Crazy----yes she is....
NYgutterguy (01-05-2020), Rio (01-06-2020)
Old 01-05-2020, 07:46 PM   #6
Radical Basement Dweller
Robie's Avatar
Rewards Points: 1,404
Re: Any Idea???
I've seen that kind of streaking after I pressure wash sometimes. It usually turns out to be some kind of old hornet or wasp nest.
“A great civilization is not conquered from without until it has destroyed itself within”
― Will Durant
Robie is online now
Old 01-05-2020, 07:56 PM   #7
Robie's Avatar
Re: Any Idea???
I enlarged the picture and there looks to be a "clump" in the upper corner where the soffet meets whatever that other structure is.
I wonder if the painters could have painted over an old nest?
Nah.
― Will Durant
Robie is online now
Old 01-05-2020, 08:04 PM   #8
tjbnwi's Avatar
Re: Any Idea???
Nah.
I'll take a look when I'm there.
I blew up the one pic, it does appear to be coming from the seam. I also see a smudge on the bottom of the fasica board.
I believe her siding is a fiber type board.
Old 01-05-2020, 08:07 PM   #9
Tom M's Avatar
Rewards Points: 12,658
Re: Any Idea???
Gutter clean? Gutter miter at the base of a valley with unvented soffit.
It's getting in between fascia sheathing gap above and collecting in the eave
Tom M is offline
Old 01-05-2020, 08:08 PM   #10
Tom M's Avatar
Re: Any Idea???
Maybe someone never plugged up holes from pump jack brackets
Tom M is offline
Old 01-05-2020, 08:18 PM   #11
tjbnwi's Avatar
Re: Any Idea???
Good thought, I'll ask her if they used pump jacks or ladders.
Old 01-05-2020, 08:37 PM   #12
MarkJames's Avatar
Rewards Points: 19,667
Re: Any Idea???
A valley covered with a pile of leaves or other crud? Blocked condensate line? Bad roof vent collar?
MarkJames is offline
Old 01-05-2020, 09:00 PM   #13
tjbnwi's Avatar
Re: Any Idea???
Text her about leaves in the gutter and valley. She won't go up on that part of the roof. She's crazy, not stupid. The one granddaughter would love being up there, info from a 3 year old probably wouldn't help....
No attic HVAC. I know the bath vent is routed properly, I did it. It is not in this area.
I'll check the vents when I'm up there.
Old 01-05-2020, 09:13 PM   #14
MarkJames's Avatar
Re: Any Idea???
Maybe it's honey. New business opportunity!
Old 01-05-2020, 09:28 PM   #15
rrk's Avatar
Rewards Points: 5,706
Re: Any Idea???
Bat chit
Thats what it looks like to me
rrk is offline
Old 01-05-2020, 09:30 PM   #16
TimNJ's Avatar
Rewards Points: 852
Re: Any Idea???
What's the roof look like above that area?
TimNJ is offline
Old 01-05-2020, 10:01 PM   #17
tjbnwi's Avatar
Re: Any Idea???
They do go through a lot of honey.
Old 01-05-2020, 10:02 PM   #18
tjbnwi's Avatar
Re: Any Idea???
Been a few years since I've been up there, will let you know when I take a look at it.
Old 01-05-2020, 10:08 PM   #19
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,550
Re: Any Idea???
I goog'd -- Brown Ooz coming down siding --look at images.
From your pics I'd say gutter - D/S first, ice dam back up.
In the search a couple of people's fix was a bath exhaust vent issue, then -- moisture activating Celotex, wrong nails, black felt under siding, OSB bleeding, Vycor type bleed..
Addl - condition is called Crying House
https://structuretech1.com/qa-siding...do-houses-cry/
Steve
We Fix Houses is online now
Old 01-05-2020, 10:17 PM   #20
tjbnwi's Avatar
Re: Any Idea???
Originally Posted by We Fix Houses View Post
I goog'd -- Ooz coming down siding --
No ice dams this season, has not been cold or snowy enough.
Exhaust vent is no where near this area, I installed it a few years ago.
1/4" thick foil sheeting, something i had never seen before.
Not a nail issue.
No felt under the siding.
No OSB.
No black Vycor or ProTecto wrap there, I used Vycor Pro at the window you see in the picture.
Thanks for looking and posting the reply, makes me think through what has been done over the last few years.
I'm leaning towards the leaf/gutter issue.
