2012 IECC - Aluminum Vs. Vinyl Windows - Windows, Siding and Doors - Contractor Talk
Old 08-13-2012, 04:21 PM   #1
Glazier_David's Avatar
Trade: Glazier
Does anyone know if aluminum framed windows will meet the 2012 IECC? I can't seem to lock down a definite answer. We work in what the IECC defines as Zone 3.
I know they came out with thermal aluminum framing, but I've read in a few places that even that won't meet the IECC.
Any tips or links to an IECC guide would be much appreciated.
Glazier_David is offline
Old 08-13-2012, 05:10 PM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 132
Re: 2012 IECC - Aluminum Vs. Vinyl Windows
Yes they will - you just need to check the SHGC / NFRL label on each one to see if it qualifies or falls under an exception (sorry I don't have 2012 specs in front of me)
You may wish to start here http://texaswindowsinitiative.com/code/code_req.asp (that looks like the right specs) & then possibly contact your favorite manufacturer
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Glazier_David (08-14-2012)
Old 08-14-2012, 05:04 PM   #3
Trade: Glazier
Ah ok, that makes a little more sense. Thanks for the help
Old 01-27-2013, 02:42 AM   #4
Windows and Doors
window-door's Avatar
Trade: Windows and Doors
SHGC ratings for all horizontal slider windows from the on-line NFRC database were reviewed in July 2005. There were 50,367 products, of which 35,114 were rated for SHGC. The most common product used to meet the 0.40 SHGC requirement are low-E windows. Low-E technologies have experienced dramatic growth in the last decade and are now included in over 60% percent of the residential market (Door & Window Maker Magazine, April 2005). There are 13,672 horizontal slider double-glazed low-E windows that are rated for SHGC and 93% of these are 0.37 SHGC or below. Lower SHGC levels can be easily met by windows with any type of frames. For example, 91%, 94%, and 97% of rated low-E horizontal slider windows with aluminum, vinyl, and wood frames now easily meet (or are lower than) this proposed 0.37 SHGC requirement.
More info here: http://www.iccsafe.org/Pages/SearchR...inum%20windows
Doors and Windows Toronto manufacturing, installation and replacement. Windows Toronto doors Toronto serving all GTA area in Ontario
window-door is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
aluminum windows contractorjay Windows, Siding and Doors 6 11-23-2010 01:34 AM
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 07:02 PM
Wood windows vs Vinyl windows davinci Windows, Siding and Doors 2 02-14-2010 09:42 AM
Vinyl over aluminum? Sal616 Windows, Siding and Doors 6 02-20-2006 09:37 AM
