1950s Era Commercial Door Lever - Windows, Siding and Doors - Contractor Talk
Old 06-02-2020, 05:14 PM   #1
jpatton's Avatar
Trade: General
Rewards Points: 8
I'm replacing several door levers in a 1950's era office. Most have gone smoothly. One, not so much.
I've removed the interior handle and rose to reveal a heavy-duty, cast mounting plate. I removed the bolts securing the mounting plate, expecting to be able to unscrew the mounting plate from the threaded hub on the chassis assembly. However the mounting plate will not turn more than an eighth inch or so before come to a complete stop.
I've applied considerable force with a pipe wrench and am convinced that there's still some sort of locking mechanism in play that needs to be dealt with before the mounting plate can be removed.
Any insights?
jpatton is offline
Old 06-02-2020, 06:09 PM   #2
MarkJames's Avatar
Rewards Points: 19,385
Re: 1950s Era Commercial Door Lever
Just a guess, but did you put a wrench on that threaded collar (or whatever it's called)? It looks like it's meant to be turned.
MarkJames is offline
asevereid (06-02-2020)
Old 06-02-2020, 08:37 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 2,366
is it reverse threaded?
put the knob back on and check that it is unlocked...
i dunno with out seeing it...
good luck
griz is offline
Old 06-03-2020, 12:10 AM   #4
Stunt Carpenter's Avatar
Rewards Points: 2,890
Did you take both sides apart? I have seen some heavy duty handles that are screed together from both sides.
https://builddaley.com/
Stunt Carpenter is offline
Old 06-03-2020, 06:31 AM   #5
jpatton's Avatar
Trade: General
Rewards Points: 8
Thanks for feedback and suggestions. Some late night research led me to this page which both exactly describes my experience and the solution.
https://kc.allegion.com/kb/article/h...k-from-a-door/
It appears a specialized wrench is required to remove a castle nut before the collar can be unscrewed.
jpatton is offline
The Following 2 Users Say Thank You to jpatton For This Useful Post:
asevereid (06-03-2020), MarkJames (06-03-2020)
Old 06-03-2020, 06:41 AM   #6
MarkJames's Avatar
I was eyeing that "castle nut", too. Thanks for posting it.
Old 06-03-2020, 06:54 AM   #7
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 52
https://www.lock-depot.com/schlage-4...le-nut-wrench/
Old ones were metal. They come with all A & D hansdets.
goneelkn is online now
Old 06-03-2020, 08:47 AM   #8
rrk's Avatar
Rewards Points: 5,330
you can use a modified piece of electrical conduit to get that off
That wrench posted brought back memories how we used to remove them when electric doorknobs started to come around in the early 80s.
Those are good knobs last a real long time
rrk is online now
Old 06-03-2020, 09:08 AM   #9
Lettusbee's Avatar
Rewards Points: 1,606
Usually somebody on site will have the spanner wrench for the locks. Facilities guy or janitor type. Root around in the basement or supply closet.
Sent from my SM-N960U using Tapatalk
Lettusbee is offline
The Following User Says Thank You to Lettusbee For This Useful Post:
rrk (06-03-2020)
Old 06-03-2020, 04:29 PM   #10
jpatton's Avatar
Trade: General
Rewards Points: 8
Thanks for the follow up insights and suggestions. I was able to loosen and remove the castle nut with a couple of small screwdrivers. As usual, half the battle is just knowing what you're dealing with. This handle is definitely a nice piece of hardware. I'll be re-purposing it elsewhere in the building.
jpatton is offline
Old 06-03-2020, 06:44 PM   #11
Lettusbee's Avatar
Glad you got it.
Here's a side by side pix of the wrench that went with 50s era knobs we removed, compared to the modern version for the new ones.
