This Is Why I Check EVERY Terminal In EVERY Panel I Open. - Electrical Picture Post - Contractor Talk
Old 07-28-2020, 04:17 PM   #1
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,976
Got a call yesterday from the owner of a townhouse, having issues with a breaker tripping. I assumed it was an AFCI and I can't stand those types of calls. But I stopped by early this afternoon to check it out.
I remove the panel cover and check the connections on breaker no. 13, which is off and is marked "LR and MBR outlets". Nothing unusual there. But just out of habit, I check every terminal in the panel.
I just about filled my drawers when I worked my way up the breakers to the 40a 2p for the range.
There's a 2011 inspection sticker on the panel. I've got a dollar that says this breaker's terminals were never tightened down 9 years ago. Amazing that the range even worked, let alone didn't melt the breaker at some point.
I usually find one or two terminations in every panel I open that could benefit from a bit more torque. But this one just floored me.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following 8 Users Say Thank You to 480sparky For This Useful Post:
bwiab (07-28-2020), Joasis (07-29-2020), jproffer (07-29-2020), overanalyze (07-28-2020), rselectric1 (07-29-2020), Seven-Delta-FortyOne (07-28-2020), tgeb (07-29-2020), TheConstruct (07-28-2020)
Old 07-28-2020, 04:51 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,034
Re: This Is Why I Check EVERY Terminal In EVERY Panel I Open.
Well,it looks like the wiring was dressed neatly...
Tinstaafl is online now
Old 07-28-2020, 07:16 PM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,972
https://youtu.be/CWMPOPdRHxg
Old 07-29-2020, 07:49 PM   #4
Aaron Berk2's Avatar
Trade: Trim Carpenter/Remodeler
Rewards Points: 256
fire hazard for sure.
Electrical panels are a sore subject for me.
So many HO's and remodeling hacks messing with things they shouldn't be.
I'm on my way this friday to add a 220 breaker to a house that had a 30amp singe pole breaker supplying one leg of a 220 dryer outlet.
Someone ran 12/3 but cut the red short, outlet was wired with the black and white, but in the panel the white went to the neutral bar.
Why would they do that?
Every thread deserves a photo
Aaron Berk2 is offline
