Footings Help - Construction Picture Post - Contractor Talk
Footings Help
Old 08-20-2019, 10:32 PM   #1
quickquestion's Avatar
Trade: Contractor
Rewards Points: 6
Footings Help
Have you ever seen concrete footings poured like this? That's gonna cause bend and leaks which lead to cracks, right?
quickquestion is offline
Old 08-20-2019, 10:40 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,998
Re: Footings Help
what kind of contractor are you?
griz is online now
The Following 7 Users Say Thank You to griz For This Useful Post:
Bull Trout (08-21-2019), cedarboarder (08-21-2019), CScalf (08-21-2019), greg24k (08-21-2019), Joasis (08-21-2019), Seven-Delta-FortyOne (08-21-2019), tang (08-22-2019)
Old 08-21-2019, 01:16 AM   #3
Dirtywhiteboy's Avatar
Rewards Points: 11,276
Re: Footings Help
Man that's a lot of dirt.
Dirtywhiteboy is offline
Old 08-21-2019, 01:34 AM   #4
test
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 662
Re: Footings Help
nice side walk.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 08-21-2019, 05:23 AM   #5
tgeb's Avatar
Rewards Points: 1,038
Re: Footings Help
To answer your questions, No and maybe.
You dropped your hammer there in the lower left in case you're looking for it.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
Old 08-21-2019, 07:21 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 8,300
Re: Footings Help
I bet you they found this picture on the internet and decided to do the same thing. I would have them tear this down and do it the right way.
greg24k is offline
Old 08-21-2019, 06:15 PM   #7
Dan_Watson's Avatar
Rewards Points: 2,670
Re: Footings Help
Please let us get the whole story before shutting it down...
Dan_Watson is online now
The Following 2 Users Say Thank You to Dan_Watson For This Useful Post:
ScipioAfricanus (08-21-2019), TimNJ (08-23-2019)
Old 08-21-2019, 06:31 PM   #8
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,954
Re: Footings Help
That is so weird.
Somebody went through a lot of work to make it look that sloppy.
Andy.
ScipioAfricanus is online now
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
greg24k (08-22-2019)
Old 08-21-2019, 07:27 PM   #9
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 128
Re: Footings Help
Have you taken your concerns to your builder? Mr "Contractor"?
Or are you telling us you poured that?
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Fouthgeneration (08-24-2019), greg24k (08-22-2019)
Old 08-21-2019, 07:31 PM   #10
Trade: Highwayman
Rewards Points: 128
Re: Footings Help
Did you guys run out of concrete?
And did someone actually form gaps in that footing?
Get Off My Lawn.
greg24k (08-22-2019), griz (08-22-2019)
Old 08-21-2019, 07:48 PM   #11
Fire up the BBQ
griz's Avatar
Re: Footings Help
VERY sloppy work...
no idea why there are missing sections of footing.
they definitely are not block puts, at least nothing like i have ever seen.
griz is online now
The Following 6 Users Say Thank You to griz For This Useful Post:
avenge (08-22-2019), cedarboarder (08-21-2019), greg24k (08-22-2019), ScipioAfricanus (08-22-2019), Seven-Delta-FortyOne (08-21-2019), tang (08-22-2019)
Old 08-21-2019, 08:16 PM   #12
Trade: Highwayman
Rewards Points: 128
Re: Footings Help
Nevermind.
Mis-read it.
Get Off My Lawn.
Old 08-21-2019, 09:03 PM   #13
TheConstruct's Avatar
Rewards Points: 1,102
Re: Footings Help
Block outs for plumbing was my first thought but that looks like they ran out of concrete. Super sloppy work. The wall concrete will fill those voids but that step would never pass around here.
TheConstruct is offline
The Following User Says Thank You to TheConstruct For This Useful Post:
Old 08-22-2019, 07:00 AM   #14
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,114
Re: Footings Help
Looks like they used extra thick mix to keep the bulkheads in place and are going to fill in the blanks with a wetter mix.
OR....WUT?
dave_dj1 is offline
Old 08-22-2019, 07:28 AM   #15
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,916
Re: Footings Help
Looks like a small addition; I bet “the contractor” knew a cement truck driver and had him deliver some left over mud from a bigger job. That always works out awesome.
Big Johnson is offline
Old 08-22-2019, 03:27 PM   #16
avenge's Avatar
Rewards Points: 684
Re: Footings Help
Well he registered as "Quickquestion" so he must be a questionable contractor.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
Seven-Delta-FortyOne (08-22-2019)
Old 08-22-2019, 05:20 PM   #17
Trade: Contractor
Rewards Points: 6
Re: Footings Help
Hey guys, just getting back from a long day of contractor work. I'm a series D apprentice, so just learning the ropes. Thanks for all the help.
Old 08-22-2019, 05:30 PM   #18
Trade: Highwayman
Rewards Points: 128
Re: Footings Help
Canadian thing??
Get Off My Lawn.
Old 08-22-2019, 06:25 PM   #19
rustyjames's Avatar
Rewards Points: 1,722
Re: Footings Help
I can't recall any projects that I've ever been involved with where the footings weren't continuous. And if I'm not mistaken step footings shouldn't be higher than 2' the step shown looks like it's more.
rustyjames is online now
Old 08-22-2019, 06:28 PM   #20
rustyjames's Avatar
Re: Footings Help
Um, "cement?" Sorry, pet peeve
The Following 3 Users Say Thank You to rustyjames For This Useful Post:
griz (08-22-2019), quickquestion (08-23-2019), Seven-Delta-FortyOne (08-22-2019)
