Simple Built-In Bookcases And Trim Work - Carpentry Picture Post - Contractor Talk
Old 02-09-2013, 08:05 PM   #1
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Just started this project tonight. Its nothing fancy but I like posting photos.
Its two rooms, similar to this....
In each room, they want book cases on one wall, upper half. New casing, base, shoe and crown.
I built the carcasses for one room and milled up the face frames. I will go back for a few hours tomorrow to build the shelves and prime the rest.
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
The Following 5 Users Say Thank You to TBFGhost For This Useful Post:
Dirtywhiteboy (02-23-2013), MAD Renovations (02-11-2013), Needles (02-10-2013), Tom M (02-10-2013), Tom Struble (02-10-2013)
Old 02-09-2013, 08:16 PM   #2
dkillianjr's Avatar
Rewards Points: 2,464
Re: Simple Built-In Bookcases And Trim Work
Lookin good so far TBF, keep the pics comin Do you have a new helper in the first pic
dkillianjr is offline
The Following User Says Thank You to dkillianjr For This Useful Post:
Old 02-10-2013, 12:10 PM   #3
alboston's Avatar
Rewards Points: 688
Looks good. How do you like the truecoat? I just bought one last week and have been impressed with it so far.
alboston is offline
Old 02-10-2013, 12:25 PM   #4
TMDC's Avatar
Trade: masonry
Rewards Points: 61
Keep the pictures coming buddy. Planning to do something like this for my house. Need all the ideas I can get since I am not much of a carpenter.
TMDC is offline
Old 02-10-2013, 02:40 PM   #5
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
im guessing the shelves are going to go above the half wall ledge?
best use of space, ive done a few of those, really maximizes space for storage
woodworkbykirk is offline
Old 02-10-2013, 02:52 PM   #6
Finish Carpenter
TBFGhost's Avatar
Yup. That is where they are going. There are three main rooms in this part of the house(basement of a split level). The first room was done already, I am duplicating it in the others.
I spend a few hours at the shop today. Ripped the shelving, added the edge, sanded and primed.
The edging is just a stock PFJ Garden State Profile.
Belt sander and 5" RO make for quick prep.
Got this meter for x-mas...this is a fresh batch of poplar I just got. I bought 100 bd feet. Nice stuff. The boards where more like 4.5/4. I planed them down, ripped one edge on the rail saw and then passed it through the table saw to clean up the opposite edge. All the boards are 15/16 heavy and some of them are 14" wide. Bought it right from the mill.
Primed.
My brother helped me surface the entire batch of lumber the other day. Not all of its for this job. I got 100 bd feet of poplar and 65 bd feet of Red Oak. Locally grown, harvested, milled, dried and now locally turned into woodwork.
Had a decent system going. Took 3 passes. I would infeed, he would stack the outfeed, once they were all through, I turned the planer around and just fed all the lumber back the other way. We stacked the lumber in the middle as it came off the planers final pass, then I ripped one edge with the rail saw, passed it to him, he ripped the other edge and stacked it on the rack.
TBFGhost is offline
The Following 2 Users Say Thank You to TBFGhost For This Useful Post:
MAD Renovations (02-11-2013), woodworkbykirk (02-10-2013)
Old 02-10-2013, 03:00 PM   #7
Finish Carpenter
TBFGhost's Avatar
Its good for small stuff. I am planning on buying an airless that pulls right from the gallon can. If I had it for this job, I would just build everything at once and then spray it all at once. The Truecoat is great for the one-off priming, or priming things in batches as it doesn't waste alot of material or take up space. I have also taken it to the job site to spray full sheets of plywood with primer.....
The only thing I ever painted with it was a small T-111 shed using Behr Exterior paint...it shot it just fine.
In total I have put about 5 gallons of Zinsser Primecoat2/Bullseye through it. 1 gallon of Zinsser CoverStain and 1/2 gallon of Behr Exterior Paint.
TBFGhost is offline
The Following 4 Users Say Thank You to TBFGhost For This Useful Post:
alboston (02-10-2013), smeagol (02-11-2013), thezoo (02-10-2013), Tom Struble (02-10-2013)
Old 02-10-2013, 10:24 PM   #8
Oldmanchaz's Avatar
Trade: Finish carpenter
Rewards Points: 16
How did you decide on the Makita saw? Do you like it? Over Festool, which is what I have been considering. I don't know if it is worth the money or not.
Oldmanchaz is offline
Old 02-11-2013, 07:15 AM   #9
Finish Carpenter
TBFGhost's Avatar
Makita has always been good to me. I have had this saw for about 3 years now. It was a better value for what I got.
TBFGhost is offline
Old 02-11-2013, 07:24 AM   #10
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
You can't go wrong with either. You will wonder how you got anything done with out a track saw once you start using one.
Nice set up you have going there TBF. I wish I had the space to buy that quantity of wood some times. I am sure if would save some $ and be nicer stuff.
CK Carpentry
chris klee is offline
Old 02-11-2013, 04:54 PM   #11
Finish Carpenter
TBFGhost's Avatar
In all honesty buying the lumber pre-surfaced would save alot time except I would have to be careful about what I accepted. Turning the rough sawn into S4S on my own is time consuming and would be costly if I didn't do it all in one shot. I do it during "down time" , ,time I would otherwise "waste" watching TV, typing on CT, etc etc.
On the up side I always end up with flat and straight lumber that is consistent in thickness.
TBFGhost is offline
Old 02-11-2013, 05:26 PM   #12
General Contractor
greg24k's Avatar
Rewards Points: 8,480
Looking good... Nice work
How do you like that Makita saw? Just got my a few days ago didn't get a chance to use it yet
greg24k is offline
Old 02-11-2013, 10:37 PM   #13
Finish Carpenter
TBFGhost's Avatar
Its been a great saw. Coupled with a supply of sharp Oshlun 28 and 48 tooth blades I have been very impressed.
TBFGhost is offline
The Following User Says Thank You to TBFGhost For This Useful Post:
greg24k (02-12-2013)
Old 02-16-2013, 07:45 PM   #14
Finish Carpenter
TBFGhost's Avatar
So for S and Gs I picked up one of these pressure fed, HVLP guns. I thinned the primer down 10% with water and gave it a go. Seems to work well... infact I am pretty sure I don't have to thin it down next time.
We will be doing the install this week so I should have some more photos soon.
TBFGhost is offline
Old 02-16-2013, 10:19 PM   #15
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
I just bought one of those Truecoats this week after seeing this thread. I have a Graco 390 for spraying most jobs, but it's just a pain to set up and clean for small stuff. Used the trucoat to spray out casings, base, wood window and door in a bathroom remodel. Worked pretty good. Need to get the hang of it though, because it puts out a much larger volume of paint than I am used to compared to an SG2 or SG3 gun.
For a quick prime and paint on a door or two, or small area work, it seems like it will fit the bill. I don't mind trading brush time for prep time either when it comes to a spray finish.
EricBrancard is offline
Old 02-17-2013, 07:09 AM   #16
Finish Carpenter
TBFGhost's Avatar
Yeah, the volume of paint it shoves out can be a bit of PITA, I think they just released new TrueCoats, TrueCoat2 or something. It made will all replaceable parts, you don't throw it away after 100 gallons. I think it also has a pressure/volume adjuster on it.
TBFGhost is offline
Old 02-17-2013, 07:11 AM   #17
Finish Carpenter
TBFGhost's Avatar
Oh yeah, they have a bunch of models out now...
http://www.graco.com/us/en/products/...equipment.html
This is what I would have gotten if it was available when I got mine.
http://www.graco.com/us/en/products/...c-sprayer.html
TBFGhost is offline
Old 02-17-2013, 07:53 AM   #18
Kent Whitten's Avatar
Rewards Points: 2,040
I have that identical planer. It's a nice machine, isn't it? Work looks great.
Once you go to airless, you won't look back. Those sprayers have their place though.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 02-17-2013, 07:57 AM   #19
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 102
All you guys with neat, organized shops, there's gotta be something wrong with ya.
Keep the pics coming, enjoying seeing the progress.
pinwheel is offline
Old 02-17-2013, 08:24 AM   #20
Livin the dream...
Spencer's Avatar
Rewards Points: 5,514
An organized shop is a must for me. I start to twitch when things get cluttered.
Lewis Carpentry
Spencer is offline
