Maple Table - Carpentry Picture Post - Contractor Talk
Maple Table
Old 10-17-2013, 07:27 PM   #1
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Maple Table
Maple Table.
Primed with Shellac (BIN), sanded, sprayed with EM6500 pigmented lacquer tinted to Ben Moore White Dove, Top coated with cross linked EM9000 Poly.
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
The Following 2 Users Say Thank You to TBFGhost For This Useful Post:
hdavis (10-18-2013), Railman (10-18-2013)
Old 10-17-2013, 07:28 PM   #2
Finish Carpenter
TBFGhost's Avatar
Re: Maple Table
Waiting to be picked up by client (Google hit from NYC)
TBFGhost is offline
Old 10-18-2013, 06:31 AM   #3
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
Re: Maple Table
Looks good, how did you like the 6500? im gonna try it for the first time this weekend on a small bookcase.
jkfox624 is offline
The Following User Says Thank You to jkfox624 For This Useful Post:
TBFGhost (10-18-2013)
Old 10-18-2013, 08:53 AM   #4
Finish Carpenter
TBFGhost's Avatar
Re: Maple Table
I love the stuff. I found it sprays best (like all waterbornes) at 70 degrees or better. When the temp drops its viscosity goes up. I also found it likes to spray and lay out best when I use a 2.0 tip and don't reduce it any. I used to spray it with a 1.7 and about 10-20% water. I am am pretty much a Target Coatings fan. The only thing I found is it tends to get get dirty quick unless its topcoated with something like the EM7000 or 9000...although I am thinking if I waxed it that would hold off the dirt as well.
TBFGhost is offline
The Following User Says Thank You to TBFGhost For This Useful Post:
jkfox624 (10-18-2013)
Old 10-18-2013, 04:06 PM   #5
Jeff
jkfox624's Avatar
Rewards Points: 502
Re: Maple Table
You use a seal coat under it at all? I've got some Em1000 left was thinking of using it as a sanding sealer
jkfox624 is offline
Old 10-18-2013, 07:39 PM   #6
Finish Carpenter
TBFGhost's Avatar
Re: Maple Table
I use Zinnser BIN to prime all my stuff. Covers well, block tannin and sands to a glass smooth finish. Shellac is about the only solvent I use.
TBFGhost is offline
Old 10-19-2013, 01:33 AM   #7
Yonde's Avatar
Rewards Points: 22
Re: Maple Table
As usual, nice work and nice pics. What's in the mason jar? Zinser BIN? I use that as well, but only for plywood. I wish there was a latex base that hid grain just as well. I'm spoiled with the ease of latex cleanup and low odor.
Yonde is offline
Old 10-19-2013, 05:01 PM   #8
Finish Carpenter
TBFGhost's Avatar
Re: Maple Table
I buy the EM6500 in bulk, then put it in a mason jar when I need to get a smaller amount tinted. I take it to a local Ben Moore store and they tint it for me.
TBFGhost is offline
Old 10-19-2013, 05:02 PM   #9
Finish Carpenter
TBFGhost's Avatar
Re: Maple Table
You could try this...I have not yet but I am thinking about it.
http://www.targetcoatings.com/produc...r-a-glaze.html
TBFGhost is offline
Yonde (10-19-2013)
Old 10-31-2013, 07:29 PM   #10
Jeff
jkfox624's Avatar
Rewards Points: 502
Re: Maple Table
After i got the hang of it i really liked the 6500. This was just something simple that my mom was bugging about for a couple years.
jkfox624 is offline
TBFGhost (10-31-2013)
Old 10-31-2013, 07:42 PM   #11
Finish Carpenter
TBFGhost's Avatar
Re: Maple Table
Yeah...the biggest thing I found was to keep it warm (around 70 degrees) and spray it with a 2.0mm tip in my conversion HVLP guns. The more and more I use target coatings the more and more I like them.
TBFGhost is offline
Old 11-04-2013, 07:54 AM   #12
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,882
Re: Maple Table
How did you join the maple boards together? I am just starting to experiment with fine woodworking and am curious how with just 3 clamps you are able to keep the boards from twisting or bowing during glue-up, and perfectly flat?
heavy_d is offline
Old 11-04-2013, 08:07 AM   #13
Finish Carpenter
TBFGhost's Avatar
Re: Maple Table
There is actually 6 or 7 clamps in that photo. The boards were surfaced and edge jointed so they were pretty flat and easy to glue up.
TBFGhost is offline
Old 11-04-2013, 08:25 AM   #14
Livin the dream...
Spencer's Avatar
Rewards Points: 5,514
Re: Maple Table
Any special tips for getting finishing done as the weather gets colder? I don't see a spray booth so I assume you just open your doors up and spray. I don't have an HVLP setup, I just use a siphon gun and it puts a lot of dust into the air. If I don't either get it sucked out or move the piece somewhere else for drying I'm in trouble. Do you have any of the same issues?
Spencer is offline
Old 11-06-2013, 04:36 PM   #15
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 12,382
Re: Maple Table
A lacquer man near 78... we need to talk.
Easy Gibson is offline
The Following User Says Thank You to Easy Gibson For This Useful Post:
not2late (11-08-2013)
Old 11-06-2013, 10:49 PM   #16
Finish Carpenter
TBFGhost's Avatar
Re: Maple Table
Its all waterborne....so nothing is explosive or smelly (except for shellac when I do use that but I don't spray it in large quantity or at a high psi...)
This is how I spray when is cool out. The shop is heated with propane.
There is an exhaust fan on the other side of the filters. The filters collect the over spray, every now and then I walk outside and blow them out with a blow gun. The air is just circulating with-in the shop.
That in itself does a remarkably good job...compared to nothing anyway. I also wear respirator. I used to wear a half mask, but I just upped to a full face for the hell of it.
TBFGhost is offline
not2late (11-08-2013), Spencer (11-07-2013)
Old 11-07-2013, 11:41 AM   #17
98crewcab's Avatar
Trade: General contractor
Rewards Points: 488
Re: Maple Table
great job, beautiful table. My wifes been on me about building our dining set.....king of procrastination here....thanks for the info on the materials you spayed.....waterbourne huh? hmmmmm...
98crewcab is offline
The Following User Says Thank You to 98crewcab For This Useful Post:
TBFGhost (11-07-2013)
Old 11-07-2013, 03:11 PM   #18
Livin the dream...
Spencer's Avatar
Re: Maple Table
Cool. I'm working on devising some kind of spraying setup. Was thinking of pulling air from outside and sending it back out the other end. Never considered circulating it withing the shop. That would help with the heat issue. Thanks for posting the pics.
Spencer is offline
The Following User Says Thank You to Spencer For This Useful Post:
Walnut table top. Leo G Carpentry Picture Post 32 02-19-2013 01:02 AM
Cased Maple Rose - A Tribute Texas Wax Finish Carpentry 6 02-17-2013 10:56 AM
bosch table saw problem Mrmac204 Tools & Equipment 15 01-20-2013 09:47 AM
Jet Table Saw not starting without assistance Texas Wax Tools & Equipment 0 11-15-2012 07:37 PM
Broke the Tapco cut table out after 3 years. VinylHanger Tools & Equipment 4 05-26-2012 12:00 AM
