Failed Concrete Footings On A Hill - Carpentry Picture Post - Contractor Talk
Old 08-13-2019, 05:45 PM   #1
Dan_Watson's Avatar
Rewards Points: 2,746
We (Techno Metal Post) were called in after the existing footings washed away and the temporary shoring was in place. We installed 4 helical piers for the (sunroom) addition, 1 helical pier for the corner of the house, and 8 for future stairs down. Ended up going down quite a bit deeper than the concrete
Dan_Watson is offline
The Following 4 Users Say Thank You to Dan_Watson For This Useful Post:
Calidecks (08-13-2019), KAP (08-14-2019), tgeb (08-14-2019), TheConstruct (08-13-2019)
Old 08-13-2019, 10:32 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 778
Re: Failed Concrete Footings On A Hill
You forgot the pics.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
hdavis (08-14-2019), mrcat (08-14-2019), TheConstruct (08-13-2019)
Old 08-14-2019, 12:00 AM   #3
hdavis's Avatar
Rewards Points: 1,554
I'm not sure what your question is, but the answer is
Tree-fiddy.
hdavis is online now
Old 08-14-2019, 12:50 PM   #4
Dan_Watson's Avatar
I have been trying to upload photos. I keep getting failed or a security issue. Regardless of file type or size. I messaged admin last night. Waiting for a response.
The Following User Says Thank You to Dan_Watson For This Useful Post:
hdavis (08-14-2019)
Old 08-14-2019, 01:19 PM   #5
Dan_Watson's Avatar
Got them to work
Failed concrete footings on a hill-1.jpg   Failed concrete footings on a hill-2.jpg   Failed concrete footings on a hill-3.jpg
The Following 2 Users Say Thank You to Dan_Watson For This Useful Post:
Patrickstew (08-17-2019), Seven-Delta-FortyOne (08-14-2019)
Old 08-14-2019, 01:20 PM   #6
Dan_Watson's Avatar
Dropped almost 9"
Failed concrete footings on a hill-4.jpg   Failed concrete footings on a hill-5.jpg
The Following 3 Users Say Thank You to Dan_Watson For This Useful Post:
hdavis (08-14-2019), Patrickstew (08-17-2019), Seven-Delta-FortyOne (08-14-2019)
Old 08-14-2019, 02:24 PM   #7
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 174
Any pics of your helical install?
mrcat is online now
Old 08-14-2019, 02:52 PM   #8
Dan_Watson's Avatar
Working on it still having some trouble.
mrcat (08-14-2019)
Old 08-14-2019, 02:53 PM   #9
Dan_Watson's Avatar
Backed it down the hill using winches. We took it to the first 'landing' and then drove it over and up onto the temporary platform we built on the temporary supports.
Failed concrete footings on a hill-6.jpg   Failed concrete footings on a hill-7.jpg   Failed concrete footings on a hill-8.jpg
hdavis (08-14-2019), mrcat (08-14-2019), Patrickstew (08-17-2019), Rio (08-14-2019)
Old 08-14-2019, 02:55 PM   #10
Dan_Watson's Avatar
We had to lower the machine again to the bottom of the hill to install the lower posts for the stairs and then installed the remaining stair posts as we worked our way up the hill.
Failed concrete footings on a hill-9.jpg   Failed concrete footings on a hill-10.jpg   Failed concrete footings on a hill-11.jpg
hdavis (08-14-2019), MarkJames (08-14-2019), Patrickstew (08-17-2019), Rio (08-14-2019)
Old 08-14-2019, 07:47 PM   #11
hdavis's Avatar
Looks like it could have gotten hairy.
Old 08-14-2019, 08:34 PM   #12
Dan_Watson's Avatar
I am surprised the room was still standing after the footings started washing away. Once it was supported nothing could move.
The only time it was sketchy was getting the machine up onto the platform. There was no place to tie off or winch from.
hdavis (08-14-2019)
Old 08-14-2019, 08:36 PM   #13
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,757
How does somebody find you for that kind of job?
MarkJames is offline
Old 08-14-2019, 08:42 PM   #14
Dan_Watson's Avatar
The contractor that did the temp support found us through Google. They do tons of structural repairs, concrete, foundations, steel work, etc. They knew helical was the way to go but couldn't find someone that could do it.
Some of the other manufacturers told them to pound sand.
Coincidentally, I saw them on another project and took a picture of their sign because I needed their services for another project. He called me a few days later, before I had a chance to call him. We are know working together on a couple of projects.
hdavis (08-14-2019), MarkJames (08-14-2019), mrcat (08-14-2019), Patrickstew (08-17-2019)
Old 08-14-2019, 09:00 PM   #15
Trade: Highwayman
Rewards Points: 778
Wow.
Didn't know NJ had any hills that steep. Or high.
Dan_Watson (08-14-2019)
Old 08-14-2019, 09:18 PM   #16
Dan_Watson's Avatar
Originally Posted by Seven-Delta-FortyOne View Post
Wow.
We have a few in the southern half, many more up north.
rrk (08-14-2019)
Old 08-14-2019, 09:37 PM   #17
rrk's Avatar
Rewards Points: 3,204
Lots of mountains up north including a few ski sreas
rrk is online now
Old 08-15-2019, 11:28 AM   #18
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,545
What's going on with the "tenon" on one of the two support columns? And the funky bolts on the 2x's?
rescraft is online now
Old 08-15-2019, 12:55 PM   #19
Dan_Watson's Avatar
I assume you mean on the 6x6? That is common, we don't do it but I see it often.
Not sure what bolts you are talking about.
Regardless, this was all done by some one else which is the same person that installed those footings that failed.
Old 08-15-2019, 06:31 PM   #20
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 588
Originally Posted by Dan_Watson View Post
Got them to work
I'm not sure you can call that last picture with the 3" piece of concrete a footing. Hacks.
cdkyle is offline
