Collection Of Random Photos From The Job Site. - Page 4 - Carpentry Picture Post - Contractor Talk
Old 10-31-2011, 04:59 PM   #61
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 514
Re: Collection Of Random Photos From The Job Site.
Updates to re-claim your thread?
KnottyWoodwork is offline
Old 11-01-2011, 06:09 PM   #62
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Not too many. I have been doing alot of little things.
TBFGhost is offline
Old 11-02-2011, 06:29 PM   #63
Finish Carpenter
TBFGhost's Avatar
First coat of BenMoore's "Hot Lips" pink in the girls dressing room.
Shower enclosures were installed
Building post wraps for the porch
Best way to cut small moldings without sending off-cuts flying....
The smaller 23 awg hole is from my HF pin nailer, the larger onee is from the Bostitich Pin nailer
TBFGhost is offline
Old 11-02-2011, 06:32 PM   #64
Finish Carpenter
TBFGhost's Avatar
Painters on the second floor
My "workshop"
Random
My sharpening stones
HF four sided diamond stone, 200/300/400/600 grit, DMT 1200 grit diamond stone and a Larson honing guide.
Also used the belt sander with 120 grit to flatten out some REALLY bad "field chisels"
TBFGhost is offline
Old 11-02-2011, 06:36 PM   #65
Finish Carpenter
TBFGhost's Avatar
Cased these two doors today, but the guy who hung them left the jambs all bowed.
I wish I got a shot of the otherside there was atleast a 1/4" bow. The Jambs were fastened and finish painted already. I used some end grain spanish cedar shims I made on the miter saw.
I set the miter saw a 5 degrees, made a cut, flipped the board and then made another cut making for some fat triangle shims. Pounded them in with a hammer pushing the jamb free of the foam and deck screws holding the jamb in the wrong place. Once I got the jamb where I needed, I just him the shim with my hammer breaking it off flush.
Sometime so simple, saves so much time, yet no one bothered to teach me that. I bumped into making end grain shims in a YouTube video I was watching. So much knowledge is being lost...
EDIT: and these shims are strong enough to "cut" their way through the foam without breaking.
TBFGhost is offline
The Following User Says Thank You to TBFGhost For This Useful Post:
Tom Struble (11-02-2011)
Old 11-09-2011, 06:47 PM   #66
Finish Carpenter
TBFGhost's Avatar
Lou bought the little 7 1/4" Craftsman slider so I could carry it around and do shoe molding.
Here is how I do shoe
Decent fitting miters...
Caulk the ends
Spooge Out
Wipe with Rag.
Done and on to the next.
Faster then coping and better result IMO. If the shoe ever moves, which I doubt a molding that small will move much, the caulk will just stretch with it hiding the movement. I got this idea from some beadboard paneling I have in my home. I installed it during the spring, caulked the joints with DAP DynaFlex230, and every summer I watch the joints "Close"(swell) causing a small bump where it pinches the caulk, and during the winter, the baseboard heat drys it out real well, shrinking the paneling and causing the joint to "open", but the caulk stretchs with it and no dark joint appears...
I have been doing the same thing on cope joints in crown and base....time will tell if my idea was good or not.
TBFGhost is offline
Old 11-14-2011, 03:17 PM   #67
Cobbler's Avatar
Trade: Jack of all trades - master of none
Rewards Points: 14
One of those "why didn't I think of that moments." Definately going to try that. Learn something new every day.
Cobbler is offline
Old 11-14-2011, 08:24 PM   #68
badwood's Avatar
Trade: apprentice carpenter
Rewards Points: 25
when i saw that i wanted to laugh at the size of the saw but, then I started to think to my self "HOLLY CRAP! I DON'T have to carry a 65 lb. tool to do small stuff like that holly **** I'm stupid." well I started out as a framer and now do mostly finish so i need to get out of that whole mine is bigger than yours Idea out of my head... o_O
badwood is offline
Old 11-14-2011, 08:47 PM   #69
Finish Carpenter
TBFGhost's Avatar
I am not a huge fan of cutting on the flat, I much rather have my trim nested, so I personally own a Makita LS1016 (my third attempt at getting one and this is one is a keeper...finally) and the Bosch Axial Glide. If I where to get a small slider, I would take a good hard look at the 7 1/2" Makita slider....its ALOT of money but if cutting on the flat is your thing, it might be the way to go.
Altho, since being hired full time as an employee, I bought the Makita more so I could keep the Bosch at home....there is no reason to get my nice tools beat up. Not that the Makita is a bad saw, its just $300 cheaper then the Bosch, and easier to move around.
TBFGhost is offline
Old 12-06-2011, 06:23 AM   #70
Finish Carpenter
TBFGhost's Avatar
TBFGhost is offline
Old 12-06-2011, 06:24 AM   #71
Finish Carpenter
TBFGhost's Avatar
TBFGhost is offline
Old 12-06-2011, 10:58 AM   #72
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
What type of wood did you use on those post wraps?
Tylerwalker32 is offline
Old 12-06-2011, 04:54 PM   #73
Finish Carpenter
TBFGhost's Avatar
Most of the post wraps are made up a variaty of exterior grade materials. The first "wrap" that formed the 5x5" square body was made of 1/2" MDO, then Western Red Ceder or Cypress was used to create the applied stiles and rails. Azek was used for the base, base cap and shoe mold. The shoe was simply some 1/2" Azek I ripped down to 1" and put a 3/8" round over on. Pine was used for the 3/8" nose and cove.
TBFGhost is offline
Web site questions Roberts Ren Websites and SEO 2 10-27-2009 08:58 AM
Today's job site.... the whole site, and nothing but the site. 480sparky Off Topic (Non Trade) 18 09-04-2009 12:05 AM
Just found this site and liking it Larry D. New Member Introductions 9 02-18-2009 08:56 AM
Random photos of decks and fences wallmaxx Decks & Fencing 17 02-14-2009 12:13 AM
Nice Web Site Feature To Show Off Refferals Job Photos Ed the Roofer Technology 10 06-26-2008 12:21 PM
