Wide Bevel For A Custom Picture Frame - Carpentry - Contractor Talk
Old 02-25-2019, 03:12 PM   #1
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 12,576
I'm tasked with making several large(5'x3') picture frames for an office.
The frames are simple, but with a deep bevel cut. Basically, I need to take a piece of 1x6 stock and make a bevel that goes from nothing at the center of the face and cuts nearly halfway into the edge(~3/8 into the 3/4 edge). Sorry, I don't have a picture. Apologies if that's annoying to visualize.
I made these once before and did it by standing the 1x up against the fence on my table saw with a slight bevel on the blade. It worked, but you had to be really really careful not to wiggle the board at all while making the cut, and I wasn't very satisfied with the way it went. I had to do more sanding than I wanted to because even the slightest movement in the board translated into lots of work to get the miter to look tight.
Trying to come up with a better way to make these guys for round number 2. Basically I want to do this, but a wider bevel.
Suggestions?
Easy Gibson is online now
Old 02-25-2019, 04:59 PM   #2
hdavis's Avatar
Rewards Points: 3,748
Re: Wide Bevel For A Custom Picture Frame
Most of that goes away if you have a sled for the ts that you clamp the board to.
hdavis is online now
MarkJames (02-25-2019)
Old 02-25-2019, 05:18 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,933
How about a glue up of two parts, prior to cutting and assembling the frames? Just a thought.
MarkJames is online now
Old 02-25-2019, 05:25 PM   #4
hdavis's Avatar
You could always buy a shaper and the right bit...
Old 02-25-2019, 11:18 PM   #5
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,946
When you ran it through tablesaw did you have feather boards .Probable need a tall auxiliary fense also. Last time I just did it on the jointer . Put some pencil marks in place and worked to it .Surprisely easy and accurate . Though having to match 4 boards would require some fiddling I would think .
What about a sled that would keep one edge up higher and run it through the planer .
JFM constr is online now
Timber Frame vs Post & Beam Dustincoc Framing 18 06-26-2014 08:32 PM
Hill country Texas full-stone over frame - rainscreen, weeps, flash? Willin Masonry 38 02-04-2013 08:47 AM
Custom paper overanalyze Wallpaper 4 01-30-2013 08:51 PM
triple post of picture astor Site Feedback and Suggestions 5 11-23-2012 01:05 PM
Face frame hinging basics Gus Dering Finish Carpentry 5 04-07-2009 07:38 PM
