When Did You Become Competent? - Carpentry - Contractor Talk
Old 08-19-2015, 11:01 PM   #1
Mansfield97's Avatar
Trade: Apprentice Carpenter
Rewards Points: 170
Hi everyone,
For the past year I have worked with my father as a carpenter. Recently everything I have learned from him has clicked. and I learn 100 more things every day.
Im sure it will be another 2 or 3 years before I dare to call myself competent. A lot of you on hear have never had a formal apprenticeship and are equal if not better than someone with a certificate.
How long were you working before you were competent?
Sorry if its a strange question, but i look forward to your replys
Mansfield97 is offline
Old 08-19-2015, 11:12 PM   #2
Hack
asevereid's Avatar
Rewards Points: 476
Re: When Did You Become Competent?
I've been in the trades for 12 years, and in construction/carpentry for the last 8.
After 6 years I thought I was good, I've spent the last two realizing that I'm adequate.
I've got competence in some areas that I've spent more time in, but I'm still far from being competent all around.
Just keep learning and, more importantly, retaining that information.
Welcome to CT.
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
The Following 2 Users Say Thank You to asevereid For This Useful Post:
C2projects (08-19-2015), tedanderson (08-21-2015)
Old 08-19-2015, 11:22 PM   #3
BRShomerepair's Avatar
Trade: Carpenter-Home Repairs and Renovations
Rewards Points: 290
it depends how wide an area you wish to be competent in. You can really never stop learning new things in this trade, as well as being proficient in other trades, the common remodeling stuff, if that's what you do.
If you do nothing but framing, after a few years you should be a pretty good framer . If you wish to be competent in different areas, then add on some more years for each area, ex. finish carpentry. I would say give it ten years or so to be "seasoned". Of course the level of competency will go up with how eager you are to take on new challenges and learn new things, rather than be happy with just doing certain tasks over and over on each job.
I found it was when I finished my apprenticeship that I really started learning and expanding my knowledge base, and refining techniques. I am always striving to find ways to be more efficient, I enjoy the challenge.
BRShomerepair is offline
The Following 3 Users Say Thank You to BRShomerepair For This Useful Post:
asevereid (08-20-2015), asgoodasdead (09-16-2015), CO762 (08-20-2015)
Old 08-19-2015, 11:58 PM   #4
Rewards Points: 170
I love the problem solving.
Old 08-20-2015, 12:23 AM   #5
Rewards Points: 290
Part of it to for me was learning patience with stuff. When something isn't working, or an unexpected issue comes up, take a step back and think it over, instead of rushing ahead frustrated.
I would focus on working at a steady pace and thinking jobs out and doing a proper job, making sure you aren't in a hurried rush type mode. For me jobs always go smoother when I am relaxed, and if you take your time and do a quality job, speed comes with efficiency, not rushing to do things as fast as you can, which can affect the quality of the end result. Generally speaking about renovation and repair work here, which can be quite different than building new stuff.
The Following 2 Users Say Thank You to BRShomerepair For This Useful Post:
asgoodasdead (09-16-2015), jb4211 (08-21-2015)
Old 08-20-2015, 12:25 AM   #6
VinylHanger's Avatar
Rewards Points: 10,954
Problem solving takes time and costs money. I prefer no problems and smooth sailing.
I hung vinyl and fiber cement siding for probably 3 or 4 years before I felt like I had a firm handle on it. I have been doing it for over 15 years now and I still have the occasional WTF? moment.
As for the other things I do, I tend to stay in my comfort zone. I stick with residential and small commercial glazing because there is way too much to learn in the large commercial glass wall systems. I don't have 5 years or more to become a pro in that area. Also, like I said, I don't like problems.
VinylHanger is online now
Old 08-20-2015, 01:08 AM   #7
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,436
If you truly work to master one area of construction it will inevitably lead you into other areas. I started painting, then finishing floors, then tiling, gotta learn some plumbing if you're going to yank a toilet, then laying hardwood floors, base and case, sash window repair, glazing, pressure washing, fence building, decks, roofing etc etc. One skill leads to the next; one of the best things about being a ronin (woops meant contractor).
Metro M & L is offline
Old 08-20-2015, 01:27 AM   #8
Rewards Points: 170
Thanks everyone.
Old 08-20-2015, 06:31 AM   #9
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 429
Competency is a good starting point. By asking good questions, and listening carefully, you will get there sooner. Once you have reached competency, the real fun begins.
Easy Gibson
Warren is online now
The Following 4 Users Say Thank You to Warren For This Useful Post:
Jaws (08-20-2015), kwunch (09-19-2015), pinwheel (08-20-2015), Xtrememtnbiker (08-20-2015)
Old 08-20-2015, 07:42 AM   #10
Creter's Avatar
Rewards Points: 1,966
The learning stops only if and when you want it to
Creter is offline
The Following User Says Thank You to Creter For This Useful Post:
mrcharles (09-02-2015)
Old 08-20-2015, 07:46 AM   #11
Lazy Millennial
Youngin''s Avatar
Rewards Points: 506
In talking to guys that just got their journeyman ticket that's usually a starting point of sorts for them. There's so much to learn past what they teach in school.
I'm currently a 3rd year apprentice but I inherited crew lead after our last superintendent left. I'm competent in some areas but have so much more to learn in others and I've been at this 5 years now.
If I have a spare moment I'll ask our regular subtrades questions. Most are open to talking about their trade. There is a lot of knowledge out there but you need to take the initiative to ask and make sure to listen.
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is offline
Old 08-20-2015, 08:50 AM   #12
hdavis's Avatar
Rewards Points: 1,342
I'd just trow 5 years out there for a number.
hdavis is online now
Old 08-20-2015, 08:55 AM   #13
KAP's Avatar
Trade: Custom
Rewards Points: 35,728
You are competent when you can accomplish a task to the satisfaction of the customer or owner (if you're an employee) consistently while making instead of losing money for you as a business owner or your employer as an employee...
Consistent doesn't mean you won't make mistakes...
You've mastered it when you find yourself in the position of others coming to you for advice on becoming better or more competent at that task because of your demonstrated consistent competency... this can happen sooner for some than others...
But there's always room for improvement...
IMHO in asking the question, you are a few steps ahead of others...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
BRShomerepair (08-20-2015)
Old 08-20-2015, 09:43 AM   #14
Fire up the BBQ
griz's Avatar
Rewards Points: 12
I'm hoping to get to a basic level in the next 2-3 years...
griz is offline
The Following 5 Users Say Thank You to griz For This Useful Post:
CarpenterSFO (08-21-2015), mrcharles (09-02-2015), pinwheel (08-22-2015), Seven-Delta-FortyOne (08-20-2015), SmallTownGuy (08-20-2015)
Old 08-20-2015, 11:02 AM   #15
Texas Wax's Avatar
Rewards Points: 1,844
Surround yourself with idiots and fools ..... Works every time
Texas Wax is online now
The Following 6 Users Say Thank You to Texas Wax For This Useful Post:
Calidecks (08-20-2015), griz (08-20-2015), j_sims (08-20-2015), KAP (08-20-2015), m1911 (08-21-2015), SamM (08-20-2015)
Old 08-20-2015, 11:10 AM   #16
hdavis's Avatar
You can back slide faster than that!
Old 08-20-2015, 11:28 AM   #17
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,576
That's where I'm at too. Let me know how it feels.
SmallTownGuy is online now
Old 08-20-2015, 11:39 AM   #18
KAP's Avatar
Trade: Custom
In 2-3 years, you realize it's actually another 2-3 years...
KAP is offline
The Following 2 Users Say Thank You to KAP For This Useful Post:
asevereid (08-20-2015), SmallTownGuy (08-20-2015)
Old 08-20-2015, 11:57 AM   #19
The Sheriff
Jaws's Avatar
Rewards Points: 6,736
Thats what i consider myself, competent. I can and have set up a lot of square foundations, framed straight, strong houses, sided and trimmed that look good and im proud of,, roofed quite a few houses/buildings that didnt leak, had straight valleys, ect.... Erected/built/welded quite a few boat docks and some metal buildings that were quality, fabricated handrails, ect... I can make a living doing them. Been in construction over 15 years full time, part time for several years prior.
But im not an expert in any of those, imo. There is a lot of trades im not competent in.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 08-20-2015, 09:15 PM   #20
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
After five years you think you know it all. After ten years you realize how little you knew at five years . After twenty years you realize you will never know it all. There is just too many trades and skills to learn in one lifetime. If you were to stick strickly to one trade, you should be competent after five years. Hopefully after ten you should pretty much have it mastered. Every person is different. Some will never master anything due to lack of ambition or intelligence . Most people as stated don't stick strictly too one trade. I started out framing 32 years ago. I consider myself competent at many trades as trying to stay employed in hard times forces you to expand your knowledge. Every skill you get is money in the bank down the road.
muskoka guy is offline
The Following 14 Users Say Thank You to muskoka guy For This Useful Post:
asevereid (08-20-2015), blacktop (08-21-2015), builditguy (09-16-2015), Calidecks (08-20-2015), CarpenterSFO (08-21-2015), Cricket (09-16-2015), illbuildit.dd (08-21-2015), Jaws (08-20-2015), mikeswoods (09-25-2015), mrcharles (09-02-2015), Ohteah (08-20-2015), pinwheel (08-22-2015), Santi78342 (10-26-2015), Tom M (08-20-2015)
Need a Competent Entry Door Craftsman that services Long Island NY.... CompleteW&D Help Wanted or Looking For Work 0 06-12-2015 01:53 PM
Teaching Your Employees The Competent Person Training pcplumber Business 7 06-24-2014 08:24 PM
Revised OSHA Reg's for Fall Prevention Roofmaster417 Roofing 19 03-16-2011 03:26 PM
Why is it so hard to find competent help..... Ranzan Windows, Siding and Doors 16 09-13-2009 09:14 PM
Illegal labor and no Permits rbsremodeling Marketing & Sales 37 01-29-2009 09:15 PM
