Washer Vibration - Carpentry - Contractor Talk
Washer Vibration
Old 04-05-2014, 01:58 PM   #1
Mikeinboston's Avatar
Trade: Plumbing
Rewards Points: 49
Washer Vibration
Ok this is driving my parents nuts. Washer on the second floor, the vibration is felt and heard in the kitchen below. They do not want to move it to the basement, we have put rubber mats, we had a carpenter build a box and we placed it on that with rubber mats, we have extended the legs on the machines, then another carpenter that my father works with came and took a look and he is still unsure. Hopefully one of you hold the solution to this problem! The photo with the kitchen in view, the top of the picture you can see through the banisters the doorway into the bathroom that the washer and dryer are in. Thanks everyone!!!
Mikeinboston is offline
Old 04-05-2014, 02:55 PM   #2
ObuckiO's Avatar
Trade: Framing
Rewards Points: 327
Re: Washer Vibration
I'm just taking a stab at a fix, although I'd imagine the deck underneath wouldn't help at all...If not, make it worse.
Anyhow, you might try something with more cushion. Maybe some cork board under feet or foam of some sort.
I personally think they are in a bad place to begin with and would also try and see if the washer is faulty.
ObuckiO is offline
Old 04-05-2014, 03:22 PM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Did it always have this issue?
Inner10 is offline
Old 04-05-2014, 03:46 PM   #4
CarpenterSFO's Avatar
Rewards Points: 2,044
Add as much mass as possible to the stand (500 lbs?) and place the washer on top of vibration isolation pads on top of that. There will still be some vibration.
- Bob
CarpenterSFO is offline
Old 04-05-2014, 03:54 PM   #5
Joe The Handyman
Joe thehandyman's Avatar
Trade: Home Improvement Contractor
Rewards Points: 125
Is the floor "bouncy"?
Is the washer touching any wall?
I would think removing the wooden base and lowering the legs would help.
Is it on rubber pads made for a washer?
You can also try vibration isolation pads.
Joe thehandyman is offline
Old 04-05-2014, 08:02 PM   #6
hdavis's Avatar
Rewards Points: 1,946
1) Make sure the shipping retainers were removed
2) Make sure it is not touching anything besides the floor
3) Make sure it's level
4) Have a service call to make sure it's balancing correctly. Some washers won't balance on all size of loads.
5) The more flex in whatever it's on, the more vibration you'll get. I can't tell for sure, but it looks like it's in an alcove / closet type of area. If that's the case, try putting a double layer or 3/4" Advantech across the entire floor, and screw it down about every 6 inches. Besides stiffening the floor, this will help pick up some of the wall mass to help keep the vibration down.
6) If that doesn't work, go with Bob's 500 lb slab plan.
hdavis is offline
Old 04-05-2014, 08:37 PM   #7
Trade: Plumbing
Rewards Points: 49
Its always had this issue since we moved in, back in 2007...this is now the 3rd washer installed and still the same problem =/ ...i know its been leveled, we have had sears out here to look at it..but ill tell them about these ideas and see what we comes from it...thank you all for your time!
Old 04-05-2014, 09:04 PM   #8
mbryan's Avatar
Trade: Ministry
Rewards Points: 568
I had issues with my front load too. Granted mines on a concrete slab.... Found it would shake a little no matter what I did until I retracted one foot to throw it out of level and then push a shim under it until it stopped. Seemed to work alright for me.
mbryan is offline
Old 04-05-2014, 09:21 PM   #9
hdavis's Avatar
Good luck with it, it looks like the obvious has been already covered a couple of times
hdavis is offline
Old 04-05-2014, 09:29 PM   #10
hdavis's Avatar
I'm going to file that one away, good thinking I assume I could get there by retracting one, and then screwing back down, but I don't think that's practical.
hdavis is offline
Old 04-05-2014, 09:37 PM   #11
mbryan's Avatar
Trade: Ministry
Rewards Points: 568
But then you have the adjust the one in the back corner...
mbryan is offline
Old 04-06-2014, 01:23 AM   #12
Frank Castle's Avatar
Rewards Points: 542
When we build boxes around sub-woofers to stop vibration up on the stages, we fill the box with sand.
" ply
6" sand
" ply
" durock (optional if we have room)
Might work for you to fill that box with sand.
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following 4 Users Say Thank You to Frank Castle For This Useful Post:
CarpenterSFO (04-06-2014), hdavis (04-06-2014), Mikeinboston (04-06-2014), Railman (04-06-2014)
Old 04-06-2014, 09:31 AM   #13
Railman's Avatar
Trade: Railing
Rewards Points: 1,055
My first thought was to do what CARPSFO said and do a huge mass of conc. as a platform, but Frank Castles sand filled box sounds even better. The sand will add the needed mass, & act as a damper at the same time.
Joe
Railman is offline
Old 04-06-2014, 10:55 AM   #14
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Joe
And the sand could be taken out... 500#s of concrete... not so much.
RobertCDF is offline
Old 04-06-2014, 11:13 AM   #15
Trade: Plumbing
Rewards Points: 49
Im gunna throw these ideas at my dad and will update you guys on how everything works out..thanks again!
Old 04-06-2014, 11:16 AM   #16
Railman's Avatar
Trade: Railing
Well that depends. It wouldn't have to be done as one piece. I was originally thinking 4 x 8 x 16 solid conc block in a box would work well, but as I said above, the sand box looks like a winner to me. The only thing I might add, is to isolate the sand box from the existing floor with maybe a foam or similar.
Joe
Railman is offline
Old 04-06-2014, 11:19 AM   #17
Inner10's Avatar
Sandbox won't do much, nor will vibration reducing pads. The problem is the resonate frequency of the structure. Unless you can re-enforce the floor by sistering up some joists I think all efforts are in vein. If it's that big of an issue switch to a top load.
Inner10 is offline
Old 04-06-2014, 01:52 PM   #18
Head Light Bulb Changer
66 Shelby's Avatar
Trade: Renovation/Home Repair
Rewards Points: 216
Just my thoughts -
The sandbox idea sounds like a good one. Maybe even layer some rubber or cork every 2-3" to help isolate vibration.
HOWEVER - It doesn't matter what you do (short of an extensive/expensive sound-proofing), you're still going to hear and feel the washer because of where it's placed. It's right over your head. No amount of anything will make it quiet. IMO, either move it or get used to it.
66 Shelby is offline
Old 04-06-2014, 05:32 PM   #19
hdavis's Avatar
Anything that reduces the floor movement will decrease the resulting SPL. Adding a mass, stiffening the floor system through beefing up the top and / or bottom membranes, isolating the washer from the floor, building an enclosure that ties that floor into the joists above...
I personally don't know that floor's resonant frequency or any of the related structural elements.
hdavis is offline
Old 04-06-2014, 07:27 PM   #20
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
Pour a 4" slab
ubcguy89 is offline
Down Idle wire broke on Rigid pressure washer Jas2012 Pressure Washing 8 06-19-2013 05:31 PM
Washer Machine drip Pan Snobnd Plumbing 11 02-25-2011 07:02 PM
Input on purchasing Skid Pressure Washer... EcoWaterWorks Pressure Washing 1 01-17-2011 11:38 AM
Pressure Washer w/ no pressure Sparky Joe Tools & Equipment 16 07-04-2010 03:59 AM
New Pressure Washer maverick28 Tools & Equipment 11 07-06-2009 09:38 PM
