The Wall Of SHAME! - Page 57 - Carpentry - Contractor Talk
The Wall Of SHAME!
Old 01-24-2014, 04:06 PM   #1121
Lettusbee's Avatar
Rewards Points: 842
Re: The Wall Of SHAME!
He did ask my opinion on how to fix. But he is a retired architect, and the whole basement project seems to be fun for him. He already had a solution in mind, that was similar to my reccomendation, and I'm willing to bet it's fixed by now.
We were just there to install a double LVL header for a doorway that was going from 3ft wide to 78" wide. He wasn't comfortable doing that on his own.
Lettusbee is online now
Old 01-24-2014, 09:05 PM   #1122
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,250
Originally Posted by Stunt Carpenter View Post
I'm by no means a roofer but I think this belongs here
Attachment 106772
They did the whole roof in 8x8 squares
What did they do between the squares? Was underlayment in 8x8 squares too?
Golden view is offline
Old 01-24-2014, 09:31 PM   #1123
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I'm by no means a roofer but I think this belongs here They did the whole roof in 8x8 squares
If they are doing what I think they are doing it's really not as bad as you think
jlsconstruction is offline
Old 01-24-2014, 10:13 PM   #1124
Framing Contractor
FullerFramer's Avatar
Trade: Framing
Rewards Points: 576
Its called racking and while its not recommended by all roofing manufacturers it is an effective method that can be quicker and will still result in a quality roof.
FullerFramer is offline
The Following User Says Thank You to FullerFramer For This Useful Post:
CanningCustom (01-25-2014)
Old 01-24-2014, 10:34 PM   #1125
Stunt Carpenter's Avatar
Rewards Points: 1,744
They only do underlayment for the first 4 feet and in valleys around here
Stunt Carpenter is online now
Old 01-24-2014, 10:35 PM   #1126
Good to know. Never seen it like that before
Old 01-24-2014, 10:46 PM   #1127
Boondockian
Dustincoc's Avatar
Trade: Getting the job done
Rewards Points: 1,018
Originally Posted by olzo55 View Post
Three joists under the bath tub.
The one I had was 5 or 6 joists under a bathroom, only a shower up there so no tub full of water but I think I still jacked up that floor 2 inches.
In the words of General James Mattis: "Be polite, be professional, but have a plan to kill everybody you meet."
Captain Howdy: We must all go through a rite of passage, and it must be physical, it must be painful, and it must leave a mark.
Dustincoc is offline
Old 01-25-2014, 09:38 AM   #1128
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Unfortunately racking is all to common.
3 tabs, sure i guess so.
Archis... no thanks
Mid winter i would be really hesitant to rack any type of shingle, especially dimensionals... thick, brittle material being bent back every other course to nail.
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
The Following User Says Thank You to FramingPro For This Useful Post:
Chad McDade (01-25-2014)
Old 01-25-2014, 09:53 AM   #1129
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Never seen this done before either. How do you transition between the squares so there aren't 8' vertical seems? What's the deal with bending the shingles over Nick?
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 01-25-2014, 10:07 AM   #1130
Forming and Framing
FramingPro's Avatar
http://www.youtube.com/watch?v=MEN5bEefpJI
Hope this shows it
Old 01-25-2014, 12:19 PM   #1131
Joseph A. Capece
I'm not following how that's any faster. Obviously not higher quality install than stepping off either. So what's the point?
Old 01-25-2014, 01:26 PM   #1132
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
I don't mind racking 3 tab, but I paper the whole roof and snap every horizontal first.
I've seen it done with laminates and I hate it. Looks like crap.
I never took pictures, but last year I replaced a few shingles on a Barn. Owner had had shed, barn, and house all redone year before. In replacing about 4 blown off shingles I found three places with nails right under the bleeder....
I often wonder how long it'll be till his house leaks.
Your Dreams won't work unless you do.
SamM is offline
Old 01-25-2014, 09:46 PM   #1133
General Contractor
Doctor Handyman's Avatar
Rewards Points: 408
Originally Posted by Californiadecks
You can't pin that on OC guys. You can find chitty work everywhere. Although it's guys that do chitty work that keep me busy.
Sorry Mike, didn't mean to imply that it is typical of all OC workmanship. As we all know it can be found everywhere.
I do however hold you personally responsible for the 35 min it took me last night on the 91E between Weir Canyon and Green River. Dammmmn!
Don't know how you do it.
@m1911, Yeah it is too far to drive for a job. Remove acoustics, install crown, and paint for a friend. 7-8 days to fill time before 3 larger projects kick in closer to home.
BTW, that crown was removed today, cut for an outside miter and spray foam used as caulking.
Doctor Handyman is offline
Old 01-25-2014, 09:59 PM   #1134
AndyWRS's Avatar
Trade: Metal Roofing
Rewards Points: 48
Laguna Woods is a retirement community, lots of hacks doing work in there. I have looked at a dozen + roofs in there and its not a pretty sight. Problem is back in the 80s they got a couple of contracts to install Decra and Gerard roofing, over the existing shake. Not a walkable system to the untrained. The maintenance folks there just walk all over them and have ruined 1000s of squares. Some leak, some don't but on only because the wood shake under them is still semi intact.
AndyWRS is offline
The Following User Says Thank You to AndyWRS For This Useful Post:
Doctor Handyman (01-25-2014)
Old 01-25-2014, 11:07 PM   #1135
Forming and Framing
FramingPro's Avatar
Reason why its apparently faster is that it eliminates side to side movement, you can sit in one spot and shuffle 3' up the roof and lay a bundle.
Old 01-25-2014, 11:44 PM   #1136
mart4005's Avatar
Trade: concrete leveling
Rewards Points: 81
http://imgur.com/a/8w1xW I'm speechless
mart4005 is offline
Old 01-25-2014, 11:46 PM   #1137
stacker of sticks
Rewards Points: 590
Originally Posted by mart4005
There are about 5 threads about this "shed" on here. It's still pretty funny though
Old 01-26-2014, 12:00 AM   #1138
mastersplinter's Avatar
Rewards Points: 303
that new shed looks like its 60 years old already.
I would love to know what he was using the ax and the hedge trimmers for
mastersplinter is offline
Old 01-26-2014, 12:51 AM   #1139
Lazy Millennial
Youngin''s Avatar
Rewards Points: 448
I never did see that shed till now. Seriously, what the hell kind of crack shack is that? I certainly don't think anyone on this forum could build that bad even if they tried.
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is offline
Old 01-27-2014, 04:50 AM   #1140
Kiwidan's Avatar
Trade: Residential
Rewards Points: 341
I don't see the problem with it?! Hahaha but seriously that's shocking
follow me on INSTAGRAM -danthebuilderman
Kiwidan is offline
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 18 11-22-2017 08:11 PM
Waterproofing Exterior of Block Wall questions. hevnbnd Masonry 0 11-09-2010 08:42 PM
Furring out wall on top of drywall zesone General Discussion 6 10-27-2010 03:28 PM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 08:01 PM
