The Wall Of SHAME! - Page 379 - Carpentry - Contractor Talk
The Wall Of SHAME!
Old 05-15-2019, 09:55 PM   #7561
hdavis's Avatar
Rewards Points: 3,776
Re: The Wall Of SHAME!
I've run 10' spans on low slope roofs with 2X4s. Accessory structures only. Solid.
There's a little twist to the framing, it isn't standard
hdavis is online now
Old 05-15-2019, 10:44 PM   #7562
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,653
Iíve always understood that slope doesnít matter in span.....
Jay hole is offline
Old 05-15-2019, 10:49 PM   #7563
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,695
Slope will matter with load calculations. Apply the cosine of the slope to the weight to get the true load on the roof.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
hdavis (05-15-2019)
Old 05-15-2019, 11:56 PM   #7564
hdavis's Avatar
As long as you're talking span, it doesn't matter. Span tables and span calculators give you the right numbers.
Old 05-16-2019, 12:10 AM   #7565
hdavis's Avatar
I mentioned low slope because of how I'm framing them. It works well with low slope, but it isn't prescriptive.
Put in the ceiling joists.
Run a 2X4, 2X6, what ever peroendular to them on edge down the center.
Put rafters on top.
Ceiling joists and rafters both work to support the roof. The 2X12 on edge helps with the side thrust as well, similar to a structural ridge.
Jay hole (05-16-2019)
Old 05-16-2019, 05:59 AM   #7566
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,364
Steeper pitch will have a longer rafter but same span so thatís why pitch doesnít affect span tables.
Big Johnson is online now
Old 05-16-2019, 06:05 AM   #7567
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,652
6' 6" for a #2 SPF with a 30lb total load. 7' 3" for SYP. I'm thinking that the trusses without the webs are overspanned a bit.
Home Designer Series Software
B.Johnson is offline
Old 05-16-2019, 08:33 AM   #7568
hdavis's Avatar
LOL, ya think?
Old 05-16-2019, 07:28 PM   #7569
B.Johnson's Avatar
Trade: Builder
It's just a suspicion. I've been wrong before.
The Following User Says Thank You to B.Johnson For This Useful Post:
hdavis (05-17-2019)
Old 05-16-2019, 07:39 PM   #7570
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 6,820
Hate when they side around the gutter.
NYgutterguy is online now
The Following 7 Users Say Thank You to NYgutterguy For This Useful Post:
asevereid (05-16-2019), cedarboarder (05-16-2019), hdavis (05-17-2019), META (05-16-2019), Randy Bush (05-16-2019), rblakes1 (05-16-2019), Rio (05-17-2019)
Old 05-16-2019, 09:11 PM   #7571
META's Avatar
Trade: General and Trades
Rewards Points: 3,538
Maybe 1.5" on centers will work....
META is online now
Old 05-17-2019, 05:33 AM   #7572
B.Johnson's Avatar
Trade: Builder
Maybe. Find me a table with 1.5" centers and I'll look it up for you.
Old 05-17-2019, 05:35 AM   #7573
B.Johnson's Avatar
Trade: Builder
We all know that it doesn't meet code. I've seen a lot of shoddy workmanship in this thread, but this is the first time that I said that it needed to be reported. It's too dangerous to ignore.
Rio (05-17-2019)
Old 05-17-2019, 06:08 AM   #7574
Photoshopped.
I’m really not buying that someone would actually do that. My money is on that roof coming off and someone thought it’d make a good pic. for the inter webs so they took the sawzall to it.
Old 05-17-2019, 09:25 AM   #7575
Stunt Carpenter's Avatar
Rewards Points: 1,782
Originally Posted by Big Johnson View Post
Photoshopped.
Iím really not buying that someone would actually do that. My money is on that roof coming off and someone thought itíd make a good pic. for the inter webs so they took the sawzall to it.
Iím going to agree with this especially because the lighting is so good and it look like they cut out a plumbing stack.
https://builddaley.com/
Stunt Carpenter is offline
Old 05-17-2019, 09:41 AM   #7576
Mordekyle's Avatar
Rewards Points: 4,812
Photoshopped.
Photoshopped.
Ya, okay.
I think itís a legitimate WOS piece of work.
Iíll inquire a bit perhaps, but itís a strange day when we have to prove how inept people are.
Mordekyle is offline
Old 05-17-2019, 09:44 AM   #7577
META's Avatar
I personally wouldn't even consider that approach were I to demo out that roof.
Pull all the sheathing, maintain some bracing, then work your way from one side to the other, as you demo or lift each truss.
META is online now
Old 05-17-2019, 12:24 PM   #7578
TheConstruct's Avatar
Rewards Points: 1,054
Great way to add some additional living space! Good luck getting all those hang nails off though... didnt think that one through did they?
TheConstruct is offline
Old 05-17-2019, 04:05 PM   #7579
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 954
Point me to a span table for 2x4 rafters, and I will look it up for you.
I've seen some pretty long rafters made out of 2x4 in some of the old houses around here. I did an attic to bonus room conversion on one of them and the deflection was 5" over 16'. That roof looked like a chinese pagoda with that much curve!
SPG is offline
Old 05-17-2019, 06:56 PM   #7580
Then you donít have an outrageous picture to get some people on the internet all riled up.
META (05-17-2019)
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 18 11-22-2017 08:11 PM
Waterproofing Exterior of Block Wall questions. hevnbnd Masonry 0 11-09-2010 08:42 PM
Furring out wall on top of drywall zesone General Discussion 6 10-27-2010 03:28 PM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 08:01 PM
