The Wall Of SHAME! - Page 356 - Carpentry - Contractor Talk
The Wall Of SHAME!
Old 11-01-2018, 04:47 PM   #7101
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,405
Re: The Wall Of SHAME!
Mike-B @ #7099: Until it fails again? Did you check your hoses DOM?(date of Manufacture)?
Catch pans under washers and Hot water heaters greatly reduce plumbing repair costs...
When was the last time you exercised your water stop valves indoor and kerbside?
Outlet filters??? for septic system?
Fouthgeneration is online now
Old 11-01-2018, 06:29 PM   #7102
Mike-B's Avatar
Rewards Points: 1,148
DOM on the outlet hose? The thought hadnt crossed my mind. Its as old as the washer. 13 or 14 I'd say. Probably still be ok if it hadnt been rubbing on the corner of a CMU pilaster all this time.
I can see a drain pan being useful if it were on the main floor. My washer, hot water tank, and furnace are all in my unfinished basement right next to a drain. If anything leak, it goes right to a drain.
I have city water. The local water authority was at my house maybe 12 months ago to remove an old meter for a house that was on my property that i demo'd and to install a new remote reading device on the existing meter. We exercised the valve at the curb and in the house that day.
Outet filters are for the new washer discharge house. Keeps lint from clogging up my utility tub.
Mike-B is offline
Old 11-02-2018, 10:58 PM   #7103
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 60
I can't compete with hacks.
donerightwyo is offline
The Following 7 Users Say Thank You to donerightwyo For This Useful Post:
asevereid (11-04-2018), Calidecks (11-02-2018), cedarboarder (11-07-2018), Dirtywhiteboy (11-03-2018), mrcat (11-03-2018), Rio (11-07-2018), Xtrememtnbiker (11-03-2018)
Old 11-03-2018, 06:29 AM   #7104
Trade: Masonry
Mike-B @ #7102:The DOM was in regard to the two Supply hoses, a much greater threat then a 20-40 gallon leak....
If your water supply has a one way valve( anti-back flow preventor) I'd install an expansion tank for hot water heater driven over pressure cycles.
Also some cities routinely run over 60 PSI service pressures that can lead to in house plumbing failures, thus a pressure regulator is recommended...
A few correctly sized anti hammer devices can also lower wear and failure of plumbing components.
Old 11-03-2018, 10:57 PM   #7105
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,262
Originally Posted by donerightwyo View Post
not sure if the electrical issue is worse than the return air grill
Anthill is offline
The Following User Says Thank You to Anthill For This Useful Post:
donerightwyo (11-04-2018)
Old 11-04-2018, 12:17 AM   #7106
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 930
Thatís a hand dryer, it dries your hands while you wash. Big time saver, gets people in and out of the bathroom faster.
Big Johnson is offline
The Following 4 Users Say Thank You to Big Johnson For This Useful Post:
cedarboarder (11-07-2018), donerightwyo (11-04-2018), MN_general (11-11-2018), TheConstruct (11-04-2018)
Old 11-04-2018, 03:48 AM   #7107
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
SmallTownGuy is offline
Old 11-05-2018, 03:31 PM   #7108
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,278
Originally Posted by NYgutterguy View Post
Lady insisted on doing the gutters here first. We removed galvanized half round gutters that were completely deteriorated and probably older than Tinstaafl
Damn, they made gutters back then? Civilization is amazing. I will say this tho, we have made leaps and bounds over all the other centuries. But couldn't have done so without all their hard work. Tinstaafl, we salute you for all your struggles.
madrina is offline
The Following 8 Users Say Thank You to madrina For This Useful Post:
Dirtywhiteboy (11-08-2018), donerightwyo (11-05-2018), Fouthgeneration (11-08-2018), mrcat (11-05-2018), NYgutterguy (11-05-2018), tgeb (11-07-2018), Tinstaafl (11-05-2018), Xtrememtnbiker (11-05-2018)
Old 11-06-2018, 09:24 PM   #7109
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,350
Had a network patch panel today where the work done by the original installer was so bad the punch downs were being held down with electrical tape.
A first for me.
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
Old 11-06-2018, 09:26 PM   #7110
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,074
A first for me.
Pics dude pics...
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
asevereid (11-06-2018), overanalyze (11-06-2018)
Old 11-06-2018, 09:30 PM   #7111
Box Builder
Morning Wood's Avatar
Rewards Points: 10,298
A first for me.
No idea what youíre talking about. But sounds bad
Morning Wood is offline
Old 11-08-2018, 12:29 AM   #7112
Mordekyle's Avatar
Rewards Points: 5,594
WOS Haiku:
Unattached ledger
Held fast with drywall screws
No flashing either
Mordekyle is online now
The Following 4 Users Say Thank You to Mordekyle For This Useful Post:
asevereid (11-08-2018), Rio (11-08-2018), SmallTownGuy (11-08-2018), sparehair (11-17-2018)
Old 11-08-2018, 11:43 AM   #7113
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 836
Job my brother just did. Funnel up top and downspout down around and trough railing down the deck skirt around to the front skirt and down post 🤷*♂️
NYgutterguy is online now
The Following 2 Users Say Thank You to NYgutterguy For This Useful Post:
hdavis (11-09-2018), TheConstruct (11-08-2018)
Old 11-08-2018, 07:47 PM   #7114
Stryker1-1's Avatar
Originally Posted by Inner10 View Post
Pics dude pics...
I will have to get some on the next visit to the site.
Old 11-11-2018, 09:56 PM   #7115
test
cedarboarder's Avatar
Trade: General
Rewards Points: 2,279
Fail.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
The Following 4 Users Say Thank You to cedarboarder For This Useful Post:
Anthill (11-13-2018), asevereid (11-11-2018), Fouthgeneration (11-13-2018), mrcat (11-12-2018)
Old 11-17-2018, 06:14 PM   #7116
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Finally wrapping that dang deck up. It was a total cluster.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following 6 Users Say Thank You to TNTRenovate For This Useful Post:
asevereid (11-18-2018), Calidecks (11-17-2018), overanalyze (11-23-2018), Rio (11-19-2018), Snobnd (11-19-2018), Xtrememtnbiker (11-18-2018)
Old 11-17-2018, 07:36 PM   #7117
Mordekyle's Avatar
The Following 8 Users Say Thank You to Mordekyle For This Useful Post:
asevereid (11-18-2018), META (11-17-2018), onmywayup (11-19-2018), rblakes1 (11-17-2018), Rio (11-19-2018), SmallTownGuy (11-19-2018), tgeb (11-19-2018), Xtrememtnbiker (11-18-2018)
Old 11-19-2018, 04:21 PM   #7118
90%-er
onmywayup's Avatar
Rewards Points: 2,252
That last pic really takes the cake man. Jesus. What a mess.
onmywayup is offline
The Following User Says Thank You to onmywayup For This Useful Post:
hdavis (11-20-2018)
Old 11-20-2018, 01:11 PM   #7119
META's Avatar
Trade: General and Trades
Rewards Points: 5,878
No problem bubba, just cut the single ply header out of the way.
META is online now
The Following 2 Users Say Thank You to META For This Useful Post:
asevereid (11-20-2018), hdavis (11-20-2018)
Old 11-20-2018, 01:37 PM   #7120
hdavis's Avatar
Rewards Points: 2,456
At least the pipe has straps...
hdavis is online now
META (11-20-2018)
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 18 11-22-2017 08:11 PM
Waterproofing Exterior of Block Wall questions. hevnbnd Masonry 0 11-09-2010 08:42 PM
Furring out wall on top of drywall zesone General Discussion 6 10-27-2010 03:28 PM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 08:01 PM
