The Wall Of SHAME! - Page 334 - Carpentry - Contractor Talk
The Wall Of SHAME!
Old 05-02-2018, 02:29 PM   #6661
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,232
Re: The Wall Of SHAME!
Originally Posted by Anthill View Post
Typical scenario. Homeowner (me) tries to patch the siding on his house and he's too cheap to do it right. So he (me) just patches it in the most inconspicuous way. You can hardly even tell where the chimney chase used to be!
Blends right in.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Anthill (05-02-2018)
Old 05-02-2018, 02:41 PM   #6662
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,819
Ok, Why do the images insist on being sideways? And how can I change it?
Rotate them on your phone and resave it. Then upload it here. If you take the photo in landscape view it won't happen. Only seems to happen when you take it in portrait view.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 05-02-2018, 04:26 PM   #6663
Hack
asevereid's Avatar
Rewards Points: 178
Now it's a feature wall!
Sent from my SM-G530W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
The Following User Says Thank You to asevereid For This Useful Post:
Old 05-04-2018, 07:36 PM   #6664
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,006
Bet the last gutter guy told homeowner these would work great lol.
NYgutterguy is offline
Old 05-04-2018, 08:30 PM   #6665
water re-locater
House across from one I looked at today in a very wealthy part of NJ. Not like they don't have the money to have it replaced. . Just don't get it.
Actually never looked at it that closely. Maybe just a sample to see what new roof would look like ?
Old 05-04-2018, 08:53 PM   #6666
LRG WoodCrafting
Leo G's Avatar
Looks like they are trying to decide what color/style they want.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
NYgutterguy (05-04-2018)
Old 05-04-2018, 08:58 PM   #6667
water re-locater
After I zoomed in common sense kicked in lol
Old 05-04-2018, 09:01 PM   #6668
Jonbuild's Avatar
Trade: Log home builder
Rewards Points: 492
Originally Posted by B.D.R. View Post
Just snapped this shot while at the hairdressers with my wife.
They did a good job scribing to the light fixture
Jonbuild is offline
The Following User Says Thank You to Jonbuild For This Useful Post:
B.D.R. (05-07-2018)
Old 05-04-2018, 09:46 PM   #6669
Hack
asevereid's Avatar
Rewards Points: 178
As promised, here's the sidewalk we did yesterday... Next time we really ought to pay someone to do it.
The "broom" finish is lumpy as hell because the boss used a push broom... It never got screeded properly, so it's wavy as hell... I just shake my damn head sometimes.
Might be time to think about moving on...
http://goo.gl/Il8c2
SmallTownGuy (05-05-2018)
Old 05-04-2018, 10:28 PM   #6670
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 18,090
I mean, those should definitely be stairs, but the job doesn't look thaaaaat bad. Those chunks will probably get kicked away over time.
Easy Gibson is offline
Old 05-04-2018, 10:29 PM   #6671
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 2,516
No they wonít, thatís a disaster.
Big Johnson is offline
Old 05-04-2018, 10:41 PM   #6672
Hack
asevereid's Avatar
Rewards Points: 178
The chunks did get kicked away today... But that doesn't make it any better.
This is the direct result of an owner trying to save someone some money... I get where he's coming from, but it's not right.
I will state that I am not a flatwork guy... I'll do foundations and footings all day... But if it's a slab? Then someone who knows what they are doing needs to get in there... Not a guy like me, and a laborer.
The screeding was all done by mag float, and then it got a quick steel float before it was properly flattened... Followed immediately by the "broom" finish.
Does it work? Is it a sidewalk?
Yeah.
Is it the best that could have been done for the client?
No ****ing way.
I will be more than happy to hang my head in shame on this one.
http://goo.gl/Il8c2
Old 05-05-2018, 09:49 AM   #6673
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,260
Yeah.
No ****ing way.
You probably know this, but the proper method is screeding first, usually with a wood 2x4, sometimes a Mag or aluminum screed. This should get your slab absolutely flat.
Then a bull float.
Then you must wait until all bleed water is evaporated before you put steel trowels on the slab, otherwise, you'll get scaling.
Then a final broom finish with a purpose-built concrete broom.
asevereid (05-05-2018)
Old 05-05-2018, 12:14 PM   #6674
Hack
asevereid's Avatar
Rewards Points: 178
Then a bull float.
The boss tried to use a bull float... Couldn't figure out how to attack all the angles on this one... Then he gave up and started steeling.
Sent from my Nexus 7 using Tapatalk
http://goo.gl/Il8c2
Old 05-05-2018, 03:12 PM   #6675
Trade: Highwayman
Old 05-05-2018, 03:54 PM   #6676
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,350
Looks like it will be a treat to get up and down when it gets wet
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
The Following User Says Thank You to Stryker1-1 For This Useful Post:
Old 05-05-2018, 04:33 PM   #6677
Randy Bush's Avatar
A mess I have to fix when I reside one of my sisters house this fall. Good thing it does not leak into the house.
Sent from my LG-V520 using Tapatalk
The Following 5 Users Say Thank You to Randy Bush For This Useful Post:
asevereid (05-05-2018), cedarboarder (05-10-2018), Morning Wood (05-05-2018), Rio (05-06-2018), SmallTownGuy (05-05-2018)
Old 05-06-2018, 04:09 PM   #6678
Even bigger treat to walk on with bare feets.
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
Rio (05-06-2018), SmallTownGuy (05-06-2018)
Old 05-06-2018, 04:42 PM   #6679
Hack
asevereid's Avatar
Rewards Points: 178
Yep... Waste of time and money if you ask me.
The HO don't ever plan on walking on this in bare feet... But they got "this" simply because they asked for it. The boss (I guess) didn't have a problem with giving to them with no questions asked.
I don't get to make the decisions about all the jobs we do, and I seem to have a problem with continuing to work for companies whose MO devolves in to this "get work, do work, get paid" mentality over time.
I'm considering a change again... Maybe find someone else who cares, or maybe try going on my own again. Who knows?
What I do know is that I don't ever WANT to display any project I've been involved in, in this thread.
http://goo.gl/Il8c2
Old 05-06-2018, 05:09 PM   #6680
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
FWIW: I've had flatwork guys do sidewalks for me that deserve to be in this thread. They passed inspections too.
Chit happens. Take a chill before you leap froggy is all I got.
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
asevereid (05-06-2018)
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 18 11-22-2017 08:11 PM
Waterproofing Exterior of Block Wall questions. hevnbnd Masonry 0 11-09-2010 08:42 PM
Furring out wall on top of drywall zesone General Discussion 6 10-27-2010 03:28 PM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 08:01 PM
