The Wall Of SHAME! - Page 266 - Carpentry - Contractor Talk
The Wall Of SHAME!
Old 11-17-2016, 12:01 AM   #5301
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,717
Re: The Wall Of SHAME!
Originally Posted by SmallTownGuy View Post
I honest to Christmas can't stand to look at that one. Makes me feel violent, very, very violent.
fkn butcher is what that is.
I did puke a little bit when I saw this, but it still looks better than when they don't under cut!!!!
Jay hole is offline
Old 11-20-2016, 03:23 PM   #5302
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,278
Originally Posted by rblakes1 View Post
Yeah, it's pretty atrocious. Almost seems like they didn't adjust the saw from doing hardwood to laminate
Want me to take some more photos when I go back?
Sent from my SM-N910V using Tapatalk
That's pretty typical when someone pulls out carpet and goes to laminate.
madrina is offline
Old 11-20-2016, 04:12 PM   #5303
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 276
That's what I was thinking ...that would be true with the base. But the door trim?
blacktop is offline
Old 11-20-2016, 04:31 PM   #5304
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Yup, not what happened this time. Can see where the casing is freshly splintered from the chainsaw they used to gain a little, um - "clearance".
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
EricBrancard (11-20-2016), KAP (11-20-2016)
Old 11-20-2016, 05:28 PM   #5305
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 506
Yup. If it was carpet first, the door jamb would be sitting on the subfloor.
EricBrancard is offline
Old 11-20-2016, 07:17 PM   #5306
rblakes1's Avatar
Rewards Points: 3,526
The doors and casing were new installs onto the subfloor. I didn't hold the jambs up because I knew it was a thin floor, but didn't know what the client had picked out exactly-they were taking care of flooring on their own.
And I've never seen anyone do that bad a job on an undercut before
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
SmallTownGuy (11-20-2016)
Old 11-20-2016, 07:27 PM   #5307
John the Builder
My practice for the last 20 or so years is to have the baseboards placed up the thickness of the baseboard material - typically 7/16, and the carpys always set the jambs and casing to the subfloor.
Doesn't matter whether its sheet goods, hardwood, carpet.
A good hardwood guy can trim to a snick fit, and it just looks better when the carpet is rolled around the casing and jamb rather than trying to undercut - plus - those jamb legs setting against the floor REALLY DO hold the damned things up - there's only so much an 18 ga 2" nail can do.
The Following User Says Thank You to SmallTownGuy For This Useful Post:
rblakes1 (11-20-2016)
Old 11-20-2016, 07:46 PM   #5308
Drywall Slave
blacktop's Avatar
Rewards Points: 276
^^ That's how I've always seen It done.
blacktop is offline
Old 11-20-2016, 09:19 PM   #5309
Rewards Points: 506
Same here as described with carpet. On tile or hardwood doors, casings and base get set on flooring. For vinyl, I have no idea and I don't want to know.
Old 11-21-2016, 09:47 AM   #5310
rblakes1's Avatar
Not to ruin your week, but...
It's in a closet though, so that makes it ok right?
The base is up because there used to be carpet in this area, running shoe today.
rblakes1 is offline
Old 11-21-2016, 09:51 AM   #5311
Stunt Carpenter's Avatar
Rewards Points: 2,226
Is it just the angle of the picture or is that floor so out of level the door is almost touching when its open?
https://builddaley.com/
Stunt Carpenter is offline
Old 11-21-2016, 10:09 AM   #5312
rblakes1's Avatar
The floor is out from settling, but it's the angle and shadow making it look worse. It's got about 5/8 at the jamb and 3/8 when open
rblakes1 is offline
Old 11-21-2016, 10:34 AM   #5313
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,886
Ran out of vapour barrier? No problem!!!
Sent from my SGH-I337M using Tapatalk
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following User Says Thank You to heavy_d For This Useful Post:
gbruzze1 (11-22-2016)
Old 11-21-2016, 10:35 AM   #5314
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
That's airtight... enough...
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 11-21-2016, 05:04 PM   #5315
hdavis's Avatar
Rewards Points: 1,546
I'll tell you all about it...
hdavis is offline
SmallTownGuy (11-21-2016)
Old 11-21-2016, 06:40 PM   #5316
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Builder/Roofer said he was done.
I guess they don't do valley's in his world. They are both 4:12.
wallmaxx is offline
Old 11-21-2016, 06:44 PM   #5317
CAD Services
wallmaxx's Avatar
Rewards Points: 144
And yes.....the primed pine is in contact with the shingles
Maybe this is the new way.
In my day, I did lay-on framing and the roofer put in a small valley.
wallmaxx is offline
Old 11-21-2016, 09:53 PM   #5318
john5mt's Avatar
Rewards Points: 1,500
That's pretty disgusting.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Remodelling Fool
Helena Siding Windows
https://helenasiding.com/
john5mt is offline
Old 11-21-2016, 11:38 PM   #5319
hdavis's Avatar
Leak and rot.
hdavis is offline
Old 11-22-2016, 06:16 PM   #5320
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 14,412
Proud nails and bent up clips everywhere.
A&E Exteriors is offline
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 18 11-22-2017 08:11 PM
Waterproofing Exterior of Block Wall questions. hevnbnd Masonry 0 11-09-2010 08:42 PM
Furring out wall on top of drywall zesone General Discussion 6 10-27-2010 03:28 PM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 08:01 PM
