The Wall Of SHAME! - Page 121 - Carpentry - Contractor Talk
The Wall Of SHAME!
Old 03-18-2015, 05:25 PM   #2401
matthewcims's Avatar
Trade: Carpenter/Home Inspector.
Rewards Points: 155
Re: The Wall Of SHAME!
Today doing a home inspection in Baltimore County. I feel bad for the the poor guy trying to buy a home. Its been a year long process finding good realtors and half decent home to buy for his family. After an hour of walking threw doing my normal process, everything looking good (newer heat pump,Hot water heater,Appliances). We get into the attic:
You can see they removed various webs in the truss's. Even cut the bottom cord to put the attic steps in. A townhome, they must of wanted just a little bit more storage.
matthewcims is offline
Old 03-18-2015, 05:27 PM   #2402
Rewards Points: 155
More:
Old 03-18-2015, 06:36 PM   #2403
Stunt Carpenter's Avatar
Rewards Points: 2,482
Wow I can't believe anyone would think that was a good idea
https://builddaley.com/
Stunt Carpenter is online now
Old 03-18-2015, 07:55 PM   #2404
Lazy Millennial
Youngin''s Avatar
Rewards Points: 714
Does your area get snow? I wonder how that roof would hold up with those hackifacations.
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is online now
Old 03-18-2015, 09:48 PM   #2405
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,198
Would be a little work, but it is fixable. Crazy that they did that , some HO's should not be allowed to touch their house.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
m1911 (03-18-2015)
Old 03-19-2015, 12:35 AM   #2406
river rider's Avatar
Trade: general contractor
Rewards Points: 458
Around here all truss repairs need to be drawn and stamped by engineer, and run through bldg dept.. Any repairs, scabs, gussets, or web replacement, no matter how stout, or obviously stronger than the originals. Full replacement is fine, as AHJ just accepts mfgrs sheet. I'd imagine Baltimore is not a "Ah sure. Yeah, looks fine now. Approved." kind of bureaucracy either.
I did a week long back country river trip in Arizona in January. Nice little intimate run with some good whitewater and desert wildlife. Mid way through there's a hot springs with a bunch of hippie artwork and writings. Kind of a cool place. I remembered this wall scribbled quote from doing the river 10 years ago. I liked it, and have quoted it several times since. So I searched and found it on the walls again this year as I soaked riverside on a fine January morning. Seems to apply perfectly to this truss hackery....
"-People are stupid.
-People are stupider than you think.
-Never underestimate the stupidity of people."
river rider is offline
Old 03-19-2015, 12:49 PM   #2407
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Mmmm...bondo!
The Wall of SHAME!-1426787306932.jpg   The Wall of SHAME!-1426787321213.jpg   The Wall of SHAME!-1426787334439.jpg
www.callbathdoctor.com
Driftweed is offline
Old 03-19-2015, 01:14 PM   #2408
We Put Poles In Holes
baerconstructio's Avatar
Trade: Post Frame Builder
Rewards Points: 325
Originally Posted by Driftweed View Post
Mmmm...bondo!
Did that even hold water?!
baerconstructio is offline
Old 03-19-2015, 03:46 PM   #2409
Accidental Painter
Driftweed's Avatar
Cavity was filled with a porous foam. Now, THAT held some water ha.
good ole structure foam....
Our fix: clean out ALL old foam throughout, rebrace with 2 x 4 on end (3 running full length with shims), fill void with foam (between bracing), patch with fiberglass, cover with a liner, and resurface the tub. 3 days work. But that tub will be stiff and look like new.
Now, you ask, why not replace the tub? Because the toilet & vanity would have to removed/installed to make room. Which would make it cost prohibitive.
This is a $1000 job.
The Following User Says Thank You to Driftweed For This Useful Post:
CarpenterSFO (03-23-2015)
Old 03-19-2015, 06:59 PM   #2410
Bathroom Remodeler
srwcontracting's Avatar
Trade: Bathroom Remodeling
Rewards Points: 560
You've definitely found a niche!
Never even heard of such a thing done!
srwcontracting is offline
Old 03-19-2015, 07:05 PM   #2411
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Obviously practice makes perfect, but how hard is it to patch fibreglass tubs? It would be a handy trick to know if one was to ever accidentally damage it on a job.
TaylorMadeAB is offline
Old 03-19-2015, 07:44 PM   #2412
jb4211's Avatar
Rewards Points: 2,306
How much is a new tub?
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
NJGC (03-20-2015)
Old 03-19-2015, 08:49 PM   #2413
Accidental Painter
Driftweed's Avatar
We patch with a fiber cloth and resin, cured overnight. Then topped with automotive icing.
Clean up your hole like you would in drywall so it won't spread. Here's a picture I snapped of my guy doing it.
If it's just a ding and no penetration, just use automotive icing. Faster drying and easier to work than plain bondo.
Old 03-19-2015, 08:50 PM   #2414
Accidental Painter
Driftweed's Avatar
$2500 installed bare bones.
jb4211 (03-19-2015)
Old 03-20-2015, 04:34 PM   #2415
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Sometimes, "The more work you do, the less money you'll get....if you'll even be able to sell it".
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 03-22-2015, 09:37 AM   #2416
Rewards Points: 155
We get a few snow storms every winter. The house was built 1977. Townhome. Not sure when the truss's where cut.
This year we had about a total of 12" of snow on the ground at one time. The roof was clear of snow, No deflection at all on the outside surprisingly.
Old 03-23-2015, 02:19 PM   #2417
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 948
Just your typical bump out in my area The Wall of SHAME!-imageuploadedbycontractortalk1427138374.980755.jpg
local zoning allows you to build on 90% of property
NYgutterguy is online now
Old 03-23-2015, 07:29 PM   #2418
A Showhome that I'm demoing. Only been up three years
Tiles came up easy
The Wall of SHAME!-imageuploadedbycontractortalk1427156957.874223.jpgThe Wall of SHAME!-imageuploadedbycontractortalk1427156971.343315.jpg
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
Old 03-23-2015, 08:03 PM   #2419
Framer87's Avatar
Trade: Framing
Rewards Points: 1,156
What happened there...?
Framer87 is offline
Old 03-23-2015, 08:23 PM   #2420
Ironwood07's Avatar
Rewards Points: 204
Was the wall leaking or poor vapour barrier job ?
Ironwood07 is offline
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 18 11-22-2017 08:11 PM
Waterproofing Exterior of Block Wall questions. hevnbnd Masonry 0 11-09-2010 08:42 PM
Furring out wall on top of drywall zesone General Discussion 6 10-27-2010 03:28 PM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 08:01 PM
