Tool Of Choice To Rip 1/2" Off Fiberglass Shower Flange - Carpentry - Contractor Talk
Old 05-01-2014, 07:04 PM   #1
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
What would you use to rip part of a fiberglass shower flange off. I want to do it fast but don't want to bust it.
I figured a circular saw would work as long as I would take it slow and make sure I was at full speed before contacting the workpiece.
I screwed up and grabbed a 32" tub with surround instead of a 30" and now I'm improvising....
Spencer is offline
Old 05-01-2014, 07:08 PM   #2
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Re: Tool Of Choice To Rip 1/2" Off Fiberglass Shower Flange
I bet a skil saw would work fine. Finish blade (more tpi the better). Jig saw would make less dust though.
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
The Following User Says Thank You to CENTERLINE MV For This Useful Post:
EricBrancard (05-01-2014)
Old 05-01-2014, 07:14 PM   #3
CarpenterSFO's Avatar
Rewards Points: 2,044
or angle grinder with cut-off blade.
- Bob
CarpenterSFO is offline
The Following 10 Users Say Thank You to CarpenterSFO For This Useful Post:
98crewcab (05-02-2014), EricBrancard (05-01-2014), hdavis (05-01-2014), Jaws (05-02-2014), JT Wood (05-02-2014), mikeswoods (05-02-2014), overanalyze (05-01-2014), pinwheel (05-02-2014), rrk (05-01-2014), TNTRenovate (05-01-2014)
Old 05-01-2014, 07:14 PM   #4
Livin the dream...
Spencer's Avatar
Yeah, I was thinking that all that fiberglass turned to dust might be a bad idea for the lungs, not to mention being itchy the rest of the day.
Spencer is offline
Old 05-01-2014, 07:23 PM   #5
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Any of the above would work. I wonder if fiber cement shears would do the trick? No dust that way. Either way, you've probably spent more time thinking about it than it's going to take to cut it with and of those tools. I do the same thing....
EricBrancard is offline
Old 05-01-2014, 07:26 PM   #6
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
I would be leary of a skil saw. If you do, use as fine a tooth blade as you can and support the cut with a piece of ply.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 05-01-2014, 07:30 PM   #7
tjbnwi's Avatar
Rewards Points: 4,138
Track saw with a 48 tooth blade, connected to a dust extractor. Secure rail with the FS Rapid Clamp.
tjbnwi is offline
Old 05-01-2014, 07:35 PM   #8
Board Shortener
Johnny_5's Avatar
Trade: Carpentry / Remodels
Rewards Points: 706
I'd probably try an oscillating multi tool first. Might be a bit slower, but probably do the job fairly quickly and with a little more control and less chance of grabbing and breaking off a chunk. Plus less airborne dust.
Johnny_5 is offline
Old 05-01-2014, 07:44 PM   #9
dkillianjr's Avatar
Rewards Points: 2,464
I've used both a jigsaw and a grinder with a diamond wheel to cut fiberglass. With both though I held the shopvac hose right at cut as I was cutting to catch the dust.
dkillianjr is offline
Old 05-01-2014, 07:49 PM   #10
Livin the dream...
Spencer's Avatar
Now you're talkin. I think that would work real good.
Spencer is offline
Old 05-01-2014, 07:52 PM   #11
Livin the dream...
Spencer's Avatar
Probably, but I really don't want to screw it up and I just love coming on here and picking everyone's brain finding better ways to fix mistakes.
Spencer is offline
Old 05-01-2014, 07:53 PM   #12
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Plus none of the other options involved festool.
Xtrememtnbiker is offline
Old 05-01-2014, 07:57 PM   #13
Hair Splitter
Trade: General
That's not a bad way.
Old 05-01-2014, 08:00 PM   #14
Dan_Watson's Avatar
Rewards Points: 2,748
Grinder with a diamond blade.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
Tom Struble (05-02-2014)
Old 05-01-2014, 08:11 PM   #15
Hair Splitter
Trade: General
Originally Posted by dan_watson View Post
grinder with a diamond glade.
Tool of Choice to Rip 1/2" Off Fiberglass Shower Flange-glade_diamond_cool_water_refill_80ml_front.jpg
The Following User Says Thank You to TNTRenovate For This Useful Post:
dkillianjr (05-02-2014)
Old 05-01-2014, 08:13 PM   #16
Dan_Watson's Avatar
Originally Posted by TNTSERVICES View Post
Covers the smell of the burning fiberglass right up....Like you werent even cutting.
The Following 2 Users Say Thank You to Dan_Watson For This Useful Post:
CarpenterSFO (05-01-2014), dkillianjr (05-02-2014)
Old 05-01-2014, 10:11 PM   #17
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
if you hot glue a strip of masonite on the back and cut thru it and the surround with a skilsaw, it's less likely to break off a piece.
m1911 is offline
Old 05-01-2014, 10:35 PM   #18
hdavis's Avatar
Rewards Points: 1,280
Roughly 0% chance of cracking with a drywall route if you don't push hard. It's slow, the bits will gum up. but you don't have to support it. If you use an improvised guide, you can get a really straight cut. Otherwise, high RPMs, fine teeth, and a reversed blade are your friends - circ saw or angle grinder with reversed metal blade or ply blade.
Frankly, I tend to break thin plastic stuff of any kind if what I'm using has teeth.
hdavis is offline
Old 05-02-2014, 08:46 AM   #19
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 18,712
At this rate we'd be better off meeting at a central location and helping him cast a new tub.
Grab that angle grinder and cut the thing already. Sheesh.
Easy Gibson is offline
Old 05-02-2014, 08:47 AM   #20
TimelessQuality's Avatar
Rewards Points: 1,730
So you're removing the entire back wall flange??
Need some pics of this...
-Steve
TimelessQuality is offline
tool definitions go do it General Discussion 10 05-15-2017 01:44 AM
Fiberglass tub / shower refinishing RightConnection Kitchens & Baths 3 04-23-2007 09:04 PM
Question on fiberglass handicapped shower tzzzz216 Plumbing 4 03-27-2007 11:56 PM
