Squaring A Housekeeping Pad - Carpentry - Contractor Talk
Old 01-14-2014, 11:23 PM   #1
Pauly-o's Avatar
Trade: Plumber/Steamfitter
Firstly, Happy New Year everyone!!!!
This may be an ignorant question but here it goes.....I need to lay out a housekeeping concrete pad in the middle of A large electrical room. The pad is going to be 8' wide x 14' long. I know the 3 4 5 rule, but my question is, where do I start? Basically, if I mark a point in the middle of the room with an "x" and measure 3' up and than 4' to one side both sides shall equal 5'.....now, how do I know if the 3' mark is out or the 4'????
Thanks for any help in advance.
Pauly-o is offline
Old 01-14-2014, 11:31 PM   #2
slowsol's Avatar
Rewards Points: 2,248
Re: Squaring A Housekeeping Pad
You need to pull a parallel off an existing wall or something else used as a control.
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
CarpenterSFO (01-15-2014)
Old 01-15-2014, 12:31 AM   #3
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Sorry for my ignorance, but what is a housekeeping pad?
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
The Following 2 Users Say Thank You to svronthmve For This Useful Post:
Calidecks (01-15-2014), SmallTownGuy (01-15-2014)
Old 01-15-2014, 12:54 AM   #4
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
a 4" high concrete pad for electrical equipment to sit on, and keeps water on floor away from equipment.
m1911 is offline
The Following 2 Users Say Thank You to m1911 For This Useful Post:
CarpenterSFO (01-15-2014), ScipioAfricanus (01-16-2014)
Old 01-15-2014, 01:04 AM   #5
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Ahh. I've always just heard them called "raised concrete pads". Not sure why it's called housekeeping....
But thanks for clarifying.
Old 01-15-2014, 01:08 AM   #6
m1911's Avatar
I believe it's called "housekeeping" because it refers to when washing the floors or sweeping around the equipment...
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
svronthmve (01-15-2014)
Old 01-15-2014, 03:48 AM   #7
Kiwidan's Avatar
Trade: Residential
Rewards Points: 341
another way to check a slabs square (instead of the 3,4,5 method) is by measuring the diagonals of the slab and if their the same the slabs square
follow me on INSTAGRAM -danthebuilderman
Kiwidan is offline
Old 01-15-2014, 04:12 AM   #8
chewy's Avatar
Trade: Electrical Apprentice and Data Technician.
Rewards Points: 1,208
We call them plinths.
chewy is offline
The Following User Says Thank You to chewy For This Useful Post:
Old 01-15-2014, 08:12 PM   #9
Pauly-o's Avatar
Thank you to everyone for there input....sorry if you misunderstood the question. Basically, I know how to square a pad....I just need to know how to start at a starting point if there are no walls or anything else around me to start, therefore how would I start this whole thing off??????
Pauly-o is offline
Old 01-15-2014, 08:30 PM   #10
Fine Handcrafted Opinions
Bearded Wonder's Avatar
Trade: General
Rewards Points: 2,670
Seems like you would square it with the nearest wall. Or the nearest equipment, if no wall is handy, or the nearest walkway, or square it with the direction it needs to face if nothing else makes sense.
Bearded Wonder is offline
Old 01-15-2014, 08:41 PM   #11
slowsol's Avatar
I don't understand? You're no where near a wall to pull a parallel? Are in the middle of a desert?
-John
slowsol is offline
Old 01-15-2014, 08:46 PM   #12
FrankSmith's Avatar
Rewards Points: 5,124
You need to snap a line on the floor to represent one side to get started. You then need to determine where the center is so you can find the two corners of the first wall. Now you have a place to use your 3 4 5 to get started on your next side.
FrankSmith is offline
The Following User Says Thank You to FrankSmith For This Useful Post:
Railman (01-16-2014)
Old 01-15-2014, 08:48 PM   #13
Dan_Watson's Avatar
Rewards Points: 2,748
He also forgot to mention its a round room.
Dan_Watson is offline
Old 01-15-2014, 08:49 PM   #14
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Make an executive decision?????????????????????????????????????
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 01-15-2014, 08:52 PM   #15
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,990
Sounds like you are the first guy there.
Put a call into the GC.
Sorry I've got nothing else.
B.D.R. is offline
Old 01-15-2014, 08:53 PM   #16
B.Scott's Avatar
Rewards Points: 296
I'm going to out on a limb here and say
Check the PLAN!!!
B.Scott is offline
The Following User Says Thank You to B.Scott For This Useful Post:
Tylerwalker32 (01-16-2014)
Old 01-16-2014, 06:40 PM   #17
joee134's Avatar
Trade: cabinet maker
Rewards Points: 45
I would just let the guy that's going to form and pour the concrete worry about it.
joee134 is offline
Old 01-16-2014, 06:48 PM   #18
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Get a 250' tape. If that won't hit a wall then phuck it
jlsconstruction is offline
Old 01-16-2014, 08:27 PM   #19
Pauly-o's Avatar
Inappropriate comment
Pauly-o is offline
Old 01-16-2014, 08:30 PM   #20
Pauly-o's Avatar
Pauly-o is offline
Tips For Squaring And Framing Walkout Basements FullerFramer Framing 105 12-29-2013 06:13 PM
3-4-5 squaring method DanTheMan6937 General Discussion 108 01-25-2012 03:36 PM
Squaring Walls? markg2 Framing 14 01-13-2011 12:25 AM
Tip on Squaring Tom R Carpentry 82 05-25-2009 01:24 AM
3-4-5 Method of Squaring renkom Framing 19 12-05-2008 02:07 AM
