Split Rail Fence Post - Redo ? - Carpentry - Contractor Talk
Old 04-08-2019, 09:15 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,190
Have about 20 split rail fence posts to repair and replace. Some are rotted, some are new and all are loose in the hole.
You guys know the problem, especially the new posts...when replaced the disturbed soil / gravel never really compacts and makes a firm post. Only going into the ground 15" in the previous hole area does not help either.
I'm thinking of bolting on 1-2 PT 2x4 -- 2 ft long to the side of the new posts. Dig out the old hole deeper --- install longer retro-fitted post in the deeper hole and add concrete.
Any other suggestions to stabilize and provide a good installation of the posts ?
Steve
We Fix Houses is online now
Old 04-13-2019, 04:58 PM   #2
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,846
Re: Split Rail Fence Post - Redo ?
ok ,maybe i am missing something . if you are trying to keep them from rotting cannot see how concrete helps .my experience tamp them in gravel .gravel drains . the 15" down might be fine .unless horses are leaning on it .how high are they going up .
what is the material your using . fir next to concrete is short lived .
JFM constr is online now
Old 04-13-2019, 05:59 PM   #3
Bull Trout's Avatar
Rewards Points: 446
Maybe this stuff?
I haven't used it, so I can't speak to how well/if it does what it says, but if it does what it says, this might be the time to use it
Bull Trout is online now
Old 04-13-2019, 06:44 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,871
tamp them in with a 4 or 5 lb sledge and a 2x3, 2x4, 1x3, whatever.
MarkJames is offline
hdavis (04-13-2019)
Old 04-13-2019, 07:02 PM   #5
JFM constr's Avatar
i believe the issue with the water is it goes down the post and sets there in a nice sealed bowl .post never dry's out . we used to always put fence post in gravel when i was young ,it was considered dumb use concrete .though that was then . it is just a fence post . concrete might be faster -no tamping ,also though concrete does add mass .
Old 04-13-2019, 09:19 PM   #6
hdavis's Avatar
Rewards Points: 7,612
The answer depends somewhat on location.
My recollection is your area has sandy clay. You should be able to wiggle those posts when the ground us damp, then pull them up leaving a hole you could slide it right back into carefully.
They wiggle because the side pressure is too great. It's a combination of the post diameter, how deep it is sunk, the soil, and how high the post sticks up. Getting the best compaction in Sandy clay, first you pound in the soil around the post, then you run water around the base for final settling. Personally, I would just compact, wait for a rain, then go back and recompact.
Since you're stuck using short posts, I'd just pull all the posts, dig them down a little further, mix cement in the hole, and set the post in to the correct height.
If the posts were longer, you could skip the cement, and just go deeper.
If it's deep loan, deep and cement....
hdavis is offline
Old 04-14-2019, 12:51 PM   #7
Porterfarm's Avatar
Trade: Handyman/ Home Improvement Contractor
I will use an eight foot 2x4 to tamp the soil back.I tamp as I fill the hole watching my plumb. I never seem to be able to get it stable enough trying to tamp all the fill at once.
When I have an issue with some post loosening up after the initial install. Generally in soil that's hard to compact. I will dig down eighteen inches about 4-8" from the post on one side and then dump some unmixed concrete into the hole, tamping every few inches very hard. This way the mix is getting into all the soil. Put a few inches of soil on the top. This generally packs well keeping the post stable. Keeps me from re digging the hole post. And no mixing of concrete.
I find when you get one or two loose sections and you don't secure them, the weather will continue to loosen the rest
Good luck
Porterfarm is offline
Timber Frame vs Post & Beam Dustincoc Framing 18 06-26-2014 08:32 PM
Fence post extensions HomeFront Decks & Fencing 5 09-30-2011 10:36 PM
Any tricks to shortening a split rail fence? remster General Discussion 7 04-24-2010 07:08 AM
Machine/Tool name for using water to bore fence post holes IHI Decks & Fencing 9 02-13-2010 10:18 AM
