Router Lift - Carpentry - Contractor Talk
Router Lift
Old 06-28-2015, 09:41 PM   #1
rondon's Avatar
Trade: carpenter
Rewards Points: 96
Router Lift
I am thinking into getting a router table and am going to want a router lift to go with it.
What lift would you recommend and why. Also what do you thing of the incra router fence system.
Thank you for any feedback and recommedations
rondon is online now
Old 06-29-2015, 05:38 AM   #2
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Re: Router Lift
Just a thought---buy a shaper instead----it will have a cast iron fence --nice crank wheel for height adjustment and a hefty motor---an adapter to hold router bits--the ability to cut raised panels without bogging down---just a thought. Look into Grizzly.
mikeswoods is offline
Old 06-29-2015, 07:35 AM   #3
Radical Basement Dweller
Robie's Avatar
Rewards Points: 7,896
Re: Router Lift
I have the Precision Router Lift from Woodpeckers and love it.
I use an Incra fence...love that also.
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
Old 06-29-2015, 08:50 AM   #4
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 102
Re: Router Lift
I'm no help on the lift, I don't have one.
I've got a shaper dedicated to running router bits, but it doesn't do as good a job as my router in the router table leaving a smooth finish. Just doesn't turn enough rpm's on the smaller diameter bits to leave a smooth profile. That said, shop fox has a better fence than the grizzly shapers, but it's about the same price point.
pinwheel is offline
Old 06-29-2015, 06:55 PM   #5
rondon's Avatar
Trade: carpenter
Rewards Points: 96
Re: Router Lift
That is sort of what I am looking at. What did you use for the table.
Old 06-29-2015, 10:07 PM   #6
Robie's Avatar
Re: Router Lift
I made the top from two pieces of 3/4" Baltic Birch ply and solid maple edges. Both the top and bottom are laminated with Formica. I bought the template for the router lift from Woodpecker's when I bought the lift.
Great people to deal with.
Mark Twain
Robie is online now
The Following 2 Users Say Thank You to Robie For This Useful Post:
CO762 (07-10-2015), Railman (06-30-2015)
Old 06-29-2015, 10:45 PM   #7
JesseCocozza's Avatar
Rewards Points: 810
Re: Router Lift
I've got a JessEm router lift that I absolutely love. I've also got the incra ultra positioner with an auxiliary fence (not pictured below) that I made because I haven't sprung for the wonder fence, not sure if I will, just because I like making my own stuff when I can. I love to make things with box joints and this setup is just ridiculously easy to use. It's in my garage for my "fun" projects that I do on the weekends. I've got a 2-1/4 HO Bosch router and have been able to make raised panel doors with it as well. Like I said, it's my at home weekend setup, so I haven't really put it through the ringer on any of my finish carpentry jobs.
Pardon the mess, this was halfway through building my table saw / router workstation.
One of the projects I used it for.
JesseCocozza is offline
The Following 4 Users Say Thank You to JesseCocozza For This Useful Post:
CarpenterSFO (07-18-2015), kwunch (07-02-2015), Railman (06-30-2015), Robie (06-30-2015)
Old 06-30-2015, 07:43 AM   #8
AustinDB's Avatar
Rewards Points: 1,426
Re: Router Lift
I had a JessEm w the large PC motor, wonderful fence and lift assembly, only problem is that I rarely used it. Check them out at Woodcraft to get a feel on design.
AustinDB is offline
Old 06-30-2015, 07:02 PM   #9
rondon's Avatar
Trade: carpenter
Rewards Points: 96
Re: Router Lift
I did talk to a guy at Woodcraft and the felt that the Jessum lift was a lot better the the Woodpecker one.
I am having a hard time in knowing which lift to get.
Old 06-30-2015, 07:31 PM   #10
Railman's Avatar
Trade: Railing
Rewards Points: 901
Re: Router Lift
The JessEm is pricy, but we've had no issues with ours with the 3 1/4hp Porter Cable. It's had moderate use ( maybe 10,00 ft or so?) over the last 6 yrs or so. Be sure to use as heavy a table as you can find. 1 3/4" Solid core doors work great.
On a side note....some people complain about the router lift dropping while cutting. This is almost always caused by improper technique when setting of the router height. What you have to do is start low, & sneak up on to the required height. If you start too high, & just back it down, it doesn't preload the elevator threads, & due to vibration, it will drop.
The same applies to thickness sanders, or pretty much any machinery that has jack screws for height adjustment. On my Extrema 37" thickness sander, the programmable touch pad does this automatically. If drive belt happens to go too high, it drops back way low, & sneaks up to correct height again.
Joe
Railman is online now
The Following 2 Users Say Thank You to Railman For This Useful Post:
charimon (07-04-2015), m2akita (07-06-2015)
Old 07-08-2015, 01:08 PM   #11
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
Re: Router Lift
Skip the router lift and get a router with above the table adjustment. I use a Triton, and it has performed very well for me.
Rustbucket is offline
The Following User Says Thank You to Rustbucket For This Useful Post:
Walraven (07-08-2015)
Old 07-08-2015, 02:30 PM   #12
rondon's Avatar
Trade: carpenter
Rewards Points: 96
Re: Router Lift
Thanks everyone for your replies. Think I will be going with the Jessum II when the time comes.
Old 07-08-2015, 10:32 PM   #13
DC INC's Avatar
Trade: Finish Carpenter
Rewards Points: 139
Re: Router Lift
I have the kreg precision lift, great unit, the trunnions are huge, and fine adjustment is easy and accurate
Dave,
Let the sawdust fly!
DC INC is offline
Router bearings shot? dkillianjr Tools & Equipment 8 03-14-2013 11:06 PM
BEST router table, Lift and router combination? grafcustom Tools & Equipment 22 07-21-2011 06:00 PM
What's the Best Router Table Lift? 904sorock Finish Carpentry 0 12-26-2010 08:31 PM
Woodpecker router lift and top ApgarNJ Tools & Equipment 3 07-13-2010 08:14 PM
