Retro Flashing Commercial Windows - Carpentry - Contractor Talk
Old 04-02-2020, 01:05 PM   #1
Ohio419's Avatar
Rewards Points: 6
I could really use some help on this one so any input will be appreciated. I'm working for a General Contractor on a commercial project. He's a good guy, pays well, but not the most knowledgeable. He's asked me to install vertical wood siding. The windows and doors have been installed. They're open back aluminum frames. They all extend proud of the wall face by 3/4". It seems like someone had the idea that the frame could be used as a flange. Rainscreen will be Cor-a-Vent Sturdi Batten which adds 7/16". There's no flashing. Some of the Tyvek is tucked in, some is just cut. I can see gaps as large as 1" in the rough opening. Other openings are tight. Lots of spray foam insulation in place. The building interior is finished. I have experience with Dupont's Flexwrap but there's no way to get it into the jamb ( some spots yes, but most no). Removing the windows isn't an option. I'm thinking bending up some aluminum is the only option?
Retro Flashing Commercial Windows-window-all.jpg   Retro Flashing Commercial Windows-window-close.jpg
Ohio419 is offline
Old 04-02-2020, 01:20 PM   #2
diplomat
Golden view's Avatar
Rewards Points: 1,322
Re: Retro Flashing Commercial Windows
Peel and stick very carefully applied to the 3/4" aluminum, with heat and roller if needed to be sure there is a very good bond. What's the trim detail? Can it be rabbeted over the aluminum fast at least 1/2" and caulked to the aluminum? That plus Z flashing above the trim and you have 3 levels of mediocre protection.
Golden view is offline
asevereid (Yesterday)
Old 04-02-2020, 01:41 PM   #3
Ohio419's Avatar
Rewards Points: 6
Thanks for the reply! I like it and appreciate the help.
Ohio419 is offline
Old 04-02-2020, 02:19 PM   #4
VinylHanger's Avatar
Rewards Points: 12,304
I's do what Golden view said. I would also fill the gap with caulk first. Before filling, I would run a strip of sticky flash onto the vapor barrier and as tight to the frame as possible. This gives you a good place to run an exterior bead before sealing them up with the trim.
You are just going to be able to try and mitigate water intrusion as much as possible, not stop it. You want to keep it to the outside as much as possible.
Using 2x trim material will give you enough thickness to rabbit out a cap to set over the rim. On the tops of the frames themselves use an aluminum flashing and on top of the trim do the same with sticky flash taped over both.
Also, make sure you use a good caulk, like QuadMax at every joint and change in trim direction, as well to fill the gaps. I wouldn't use any water based caulk in this instance. This isn't the place to save money.
Also, I would make sure that your contract says you aren't responsible for water intrusion or failure due to previously and improperly installed windows.
How does the window supplier want you to flash and seal them. I would call them and see what they say first.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Golden view (04-03-2020)
Old 04-02-2020, 02:19 PM   #5
diplomat
Let others weigh in too. Often someone has a better idea than me.
Old 04-03-2020, 07:01 AM   #6
Ohio419's Avatar
Rewards Points: 6
I think I understand. I did a quick head detail. Not to scale but close. So you're saying two layers of flashing right? Basically a double drip cap?
Ohio419 is offline
Old 04-03-2020, 08:14 AM   #7
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,258
Given some of the gaps are up to an inch I would not fill that with caulk. Rather use a foam backer rod or possibly spray window foam to fill . Also flash under the wrap at the top.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Old 04-03-2020, 08:56 AM   #8
diplomat
With backer rod some of the caulks work fine with huge gaps.
Randy Bush (04-03-2020)
Old 04-03-2020, 11:46 AM   #9
I wouldn't put the venting under the trim, just the siding.
What is the venting? Or is that your rainscreen?
I'd use backer rod as well. Just figured it was obvious if the guy is a contractor.
Sent from my SM-N975U using Tapatalk
Old 04-03-2020, 12:39 PM   #10
diplomat
Your detail seems OK but I was describing having the rabbeted trim tight to the aluminum and caulked to it. Though, it's true that that doesn't allow water out.
Old 04-03-2020, 02:14 PM   #11
Randy Bush's Avatar
I would really consider not using a wood product for trim board. I would Boral or a PVC trim board.
