Remove Countertop Support Behind Dishwasher - Carpentry - Contractor Talk
Old 04-16-2019, 08:28 PM   #1
Mr_Stop's Avatar
Rewards Points: 378
I got a call from a client who had a new dishwasher installed by some Orange Apron hired pro. The dishwasher is sticking proud of the cabinets by a couple of inches. I'm looking at it tomorrow, but from what the homeowner reported, the top of the new dishwasher is hitting a support block for the granite countertop.
The dishwasher is next to the sink, in the middle of the cabinet run. Are there any issues with cutting out/removing the support block in the back for the granite?
Mr_Stop is offline
Old 04-16-2019, 08:38 PM   #2
tjbnwi's Avatar
Rewards Points: 2,826
Re: Remove Countertop Support Behind Dishwasher
Change from 2x to 1x. Decrease height of support if necessary.
tjbnwi is online now
MarkJames (04-16-2019), Mr_Stop (04-16-2019)
Old 04-16-2019, 08:42 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,875
If in the middle of the run, I'd remove it. Confirm side supports on either end of DW.
Could be a hose hanging it up, though.
MarkJames is online now
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
Bull Trout (04-16-2019), Mr_Stop (04-16-2019)
Old 04-16-2019, 09:11 PM   #4
TheConstruct's Avatar
Rewards Points: 870
May not be so much of a support as somewhere to fasten the dishwasher. If you can fasten the dishwasher on the sides it may not be needed but I agree if you can replace it with something thinner would be ideal.
TheConstruct is offline
Old 04-16-2019, 09:44 PM   #5
rselectric1's Avatar
Rewards Points: 850
If there is no seam above it, it can be removed most likely. Post pics before you pull it.
rselectric1 is offline
Old 04-16-2019, 10:09 PM   #6
KAP's Avatar
Trade: Custom
Rewards Points: 32,738
Way overthinking this... just install some granite L-brackets or hard surface universal bracket... problem solved...
KAP is offline
Old 04-16-2019, 10:11 PM   #7
rrk's Avatar
Rewards Points: 1,386
no need for it with 1 1/4" granite top
rrk is offline
Old 04-16-2019, 10:14 PM   #8
KAP's Avatar
Trade: Custom
Chances are probably not, but I wish I could say that I haven't seen it fail above a dishwasher with no support... it's generally why they exist... the fact they do tell you it's happened enough for someone to come up with a solution...
Guess he could roll the dice, but the last person who touches it...
KAP is offline
Old 04-16-2019, 10:21 PM   #9
MarkJames's Avatar
I can't imagine a failure like that unless the cabinet install was totally jacked or they were having ragers on the countertops.
Old 04-16-2019, 10:22 PM   #10
tjbnwi's Avatar
Remove the support, crank the dishwasher legs all the way out so the dishwasher supports the counter top......all problems solved....
rrk (04-17-2019)
Old 04-16-2019, 10:27 PM   #11
MarkJames's Avatar
That hurts my knuckles to even consider it.
Old 04-16-2019, 10:30 PM   #12
KAP's Avatar
Trade: Custom
Never done that, but might interfere with the door opening... but interesting idea...
KAP is offline
Old 04-16-2019, 10:57 PM   #13
tjbnwi's Avatar
Bosch and euros---front drive leg jack screws.....
Calidecks (04-16-2019), MarkJames (04-17-2019)
Old 04-18-2019, 08:10 AM   #14
Mr_Stop's Avatar
Rewards Points: 378
Thanks for the help. The install was a complete hack job and the delivery, uh I mean "installer" clearly had no idea what he was doing.
The counter was supported on both sides of the dishwasher. I ended up removing the 2x4 cleat on the back wall. Unfortunately a 1x cleat was still too thick to allow the face of the applied cabinet panel to be flush with the frame. The cabinets have inset doors/drawers, so the dishwasher had to go back extra far. The back of the dishwasher stops ~ 1/4" from the bottom of the counter, so there is hardly room for a bracket. While probably not "ideal," I ended up using 1/2" plywood with a silicone bead as a cleat.
This is about the fourth Bosch dishwasher I have installed, so I knew how tight the clearance is and the tolerances. You have just a small window (7" high by 2.5" wide) at the bottom of the cabinet to run your hoses/cords. You would think the "installer" should know this installing them all day long. He ran the hose out the opposite side and looped across the back creating further clearance issues. I had to drill a new hole and completely rerun everything. Not to mention, I cleaned up a bunch of his sloppy work.
The installer mentioned to the client that he had never installed a cabinet panel before. Well I hadn't either, but fortunately there are these things included called "instructions." Bosch even includes a nice template. Well the installer didn't use the template nor instructions. I think he just used the old hardware and locations. The door was mounted too low, so the dishwasher couldn't open all the way. He also used only two screws (out of the 6-8 you're supposed to) and velcro to hold the door on so it was falling off. To compound issues, he threw away all the hardware so the H/O has to order a new kit so I can install it correctly...
Mr_Stop is offline
Old 04-18-2019, 08:56 AM   #15
META's Avatar
Trade: General and Trades
Rewards Points: 2,970
Probably doesn't help you now, but I often use angle steel or aluminum in the upper back corner of cavities in place of lumber.
META is online now
The Following 2 Users Say Thank You to META For This Useful Post:
KAP (04-18-2019), Mr_Stop (04-18-2019)
Old 04-18-2019, 02:18 PM   #16
KAP's Avatar
Trade: Custom
Originally Posted by meta View Post
probably doesn't help you now, but i often use angle steel or aluminum in the upper back corner of cavities in place of lumber.
aka...
Originally Posted by KAP View Post
way overthinking this... Just install some granite l-brackets or hard surface universal bracket... Problem solved...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
META (04-18-2019)
Commercial bathroom sink countertop supports platinumLLC General Discussion 5 05-29-2017 06:15 AM
Cart Style Pump Support Needed? NorthTexas55693 Pressure Washing 3 09-06-2016 01:40 PM
tile countertop jhammer7 Tiling 5 07-13-2011 10:48 PM
