Recommendations For Tackling Entry Door Hardware Swap? - Carpentry - Contractor Talk
Old 12-14-2018, 09:05 AM   #1
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 14,134
Old 1 3/4" entry door with classic early century mortised cartridge lockset. One of the bigger ones I've seen. It also looks like this isn't the first in the door, which is pretty chewed up.
Customer wants a modern lockset installed which will necessitate cleaning up the cartridge hole as well as the knob/deadbolt holes on the face of the door from the previous lockset.
Do I head straight for the Dutchman, or should I be looking into doing an epoxy or bondo based repair? What have you guys had success doing?
Door will be painted, so there's a good bit of leeway.
Thanks
Easy Gibson is offline
Old 12-14-2018, 10:39 AM   #2
Texas Wax's Avatar
Rewards Points: 1,886
Re: Recommendations For Tackling Entry Door Hardware Swap?
Thanks
Dutchman all the way.
The body-cartridge hole for sure tho. Maintain the integrity of the door around the new lockset. Personally I won't bondo unless it's very small or thin. Epoxy no way, to phunkin messy. I don't mind Dutchmans, after enough of them actually fairly easy. But I'm old school trained and tooled so I know mileage varies, a lot, for others.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
Repede Emil (03-13-2019)
Old 12-14-2018, 03:44 PM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,444
Going cylindrical?
Inner10 is offline
Old 12-14-2018, 05:24 PM   #4
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
Dutchman with the gorilla glue that foams up to fill any little voids
Anderson is offline
Old 12-22-2018, 10:59 PM   #5
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,116
my 2 cents aviod the polyurithanes and there stickie mess .There is no strength in the foaming action . Just wood glue .your just filling the space .i make a big tenon to fill the body mortise .it comes flush to the strike mortise which gets it's own dutchmen . the later is done with more attention since it gets seen .
JFM constr is offline
The Following User Says Thank You to JFM constr For This Useful Post:
Old 12-23-2018, 11:38 AM   #6
jimwalter's Avatar
Trade: carpentry
Rewards Points: 363
I've gone with the bondo before, more of a headache than its worth do a dutchman
jimwalter is offline
Need recommendations to fix newly but poorly finished concrete floor MikeGC Concrete & Paving 20 03-08-2014 07:11 PM
Looking for a fresh idea to trim out entry door AustinDB Finish Carpentry 17 02-01-2013 03:12 AM
