Question For Carpenters From Painters - Page 3 - Carpentry - Contractor Talk
Old 04-26-2010, 09:33 PM   #41
MRB 6.5TD's Avatar
Re: Question For Carpenters From Painters
Originally Posted by Leo G View Post
Wood will move and joints will open. It is going to happen unless you glue.
If you only nail it will look great for some time. But it will open up. No doubt in my mind.
x2 100% .. IT's a must. Also make sure the glue is stainable. Don't have to overdue it.
MRB 6.5TD is offline
Old 04-27-2010, 09:42 AM   #42
orson's Avatar
Trade: Kitchen & Bath
Rewards Points: 502
I always glue every miter joint with no exceptions and consider it hackery not to do so.
When I'm doing raw stain grade trim I use a stainable wood glue and try to keep the glue to the back of the miter so no glue squeezes out.
Even wiping stain grade wood with a damp cloth can produce a fluctuation in the way the stain takes, so I try to get zero glue squeezing out of the joint, but if I do I wipe the glue off by running my finger down the miter joint wiping the excess into the joint where it will show up the least when stained.
My preference is to install the trim stained and with 1 coat of finish then fill the holes with color matched putty and then apply another finish coat.
orson is offline
Old 05-06-2010, 06:38 PM   #43
gdwoodbutcher's Avatar
Trade: carpenter cont.
Hello Carl, I assume your kidding about Illinois carpenters. The casings should be glued at mitres and butt joints at sill, as well as the apron to underside of sill. Any squeeze out should be wiped away with damp rag. (double check a few minutes later to make sure I got all traces, if it's still coming out, well then the joint is not very tight !) The casings are NOT supposed to be glued to the window, it makes them impossible to change out in the future, just well nailed to jamb and wall with nice even spacing thru-out. I never sand mitres, as then you must sand entire piece, and then I'd be doing the painters job. I also do not fill nail holes as the painter will likely want to stain first. It sounds like you should talk with Homeowners, before you sign to do the work, because it sounds like a LOT of extra work because some guy couldn't bother to clean up after himself. If your a sub for the installer, well, good luck with that. My experience with window installation companies is they ONLY care about speed. Once there done, they know the customer won't need them for another couple decades. Anyways, Illinois has TON'S of great carpenters, and painters!
gdwoodbutcher is offline
Question from lawyer trying to help contractor scp Business 52 02-25-2011 01:23 AM
Question for GC re: rough/final cleans britanie General Discussion 6 06-07-2009 06:42 PM
Contract question MACEXCAVATING Excavation & Site Work 4 12-20-2008 09:24 PM
