Question For Carpenters From Painters - Page 2 - Carpentry - Contractor Talk
Old 04-25-2010, 06:45 PM   #21
CarlW's Avatar
Rewards Points: 75
Re: Question For Carpenters From Painters
Originally Posted by WarnerConstInc. View Post
Kent, I think it was every where.
All it is, is someone who does not care.
My original purpose for asking the question was because I was wondering if it was a lack of education. Do they not care or are there some guys that just don't know that smearing glue on raw wood is unacceptable? When working on new homes, we get doors shipped and installed to the jobsite with so much glue smeared on them that we have to remove the doors, place them on horses and random orbit sand the entire face before staining. I have to charge the builder extra to do this....it just seems so silly. When I ask the builder to log a complaint with the lumber people, he looks at me like I'm an alien.
CarlW is offline
Old 04-25-2010, 06:45 PM   #22
FRISCODEKOY's Avatar
Trade: High end EVERYTHING
Hack is a great term for the idiots responsible for that kind of shoty work. Glue should never touch the visible faces raw wood that is to be stained. A good carpenter will check their miters and then Carefully put just enough gule about 1/8th back from the face, and join the two piece in such a fashon as to force the excess glue out the back of the miter. Then clean it up with a moist rag. (if even needed)
FRISCODEKOY is offline
Old 04-25-2010, 06:46 PM   #23
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 382
Originally Posted by CarlW View Post
Actually, I don't see why the finish would be necessary. Once the wood is stained, you are free to smear glue on it. I like to apply finish after installation so that all my putty gets a coat of poly....if you don't do that, the putty will eventually dry up and fall out.
I've been using color putty forever. It's oil based & doesn't fall out. Pulled trim on a job this spring that had been filled in the early 80's with color putty & had trouble finding the previous nail holes when I put the trim back on. I know the builder that built the home & when I worked for him, all trim was prefinished with no followup finish.
pinwheel is online now
The Following User Says Thank You to pinwheel For This Useful Post:
PrestigeR&D (04-26-2010)
Old 04-25-2010, 06:47 PM   #24
mics_54's Avatar
Trade: contractor
One can usually tell how trim is going to be finished by the type of material.
Back in the day, I trimmed and built cabs and sanded to 100 grit. The rest was up to the painter/finisher. That was the scope of the job. There shouldn't be glue all over but...since one can't always see glue till you attempt to stain...it's the stainers job to prep it for stain.
mics_54 is offline
The Following User Says Thank You to mics_54 For This Useful Post:
pinwheel (04-25-2010)
Old 04-25-2010, 06:51 PM   #25
mics_54's Avatar
Trade: contractor
color putty gets top coated.
mics_54 is offline
orson (04-27-2010)
Old 04-25-2010, 06:51 PM   #26
CarlW's Avatar
Rewards Points: 75
Originally Posted by Leo G View Post
You run the risk of ghosting if you apply putty in the hole before finishing. The spot the the putty was applied to can infect the wood. You go around and can see where the put was applied even though it was sanded off. Not all putties do this.
As a finisher all my finishes get put on first and then I use wax crayons to fill in the holes. With the correct color crayon you don't even know the hole is there unless you go searching for them.
Very interesting. I have never had much success with the crayons. I gave up pretty quick because I couldn't get the entire hole filled without some extra work. It's probably better for me from a production standpoint to use color putty because it is just faster. I always seal the wood first though before applying putty.
CarlW is offline
Old 04-25-2010, 07:36 PM   #27
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
brown sharpie....
I bet these guys are getting cut rates from Pella to bang em out fast.
I would guess they're only getting paint grade rates and are providing just that.
geez... installer, trim guy, paint guy, rrp guy....
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
mics_54 (04-25-2010)
Old 04-25-2010, 09:44 PM   #28
BuildersII's Avatar
Trade: General
Rewards Points: 250
There is a slight issue with cleaning glue off of stain-grade trim with a damp cloth, and that is that even though you get most of it, some of that glue will get into the pores of the wood and cause the stain to be absorbed differently. Personally, I don't see any reason to glue joints on casing trim anyways, as an 18 ga nail through the corner will hold it tight just fine.
BuildersII is offline
Old 04-25-2010, 09:47 PM   #29
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,667
Wood will move and joints will open. It is going to happen unless you glue.
If you only nail it will look great for some time. But it will open up. No doubt in my mind.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
orson (04-27-2010), pinwheel (04-27-2010)
Old 04-25-2010, 09:52 PM   #30
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
Leo is there a particular technique you use to fill the holes with a crayon?
naptown CR is offline
Old 04-25-2010, 09:58 PM   #31
Cjeff's Avatar
Trade: Renovations
Yeah, every stained trim I have put on is stained before install, then the painters use a 'kit' and stain and mix putty to fill the holes.
Miter's are glued and any excess glue squeezed out is wiped off.
Cjeff is offline
Old 04-25-2010, 09:59 PM   #32
LRG WoodCrafting
Leo G's Avatar
Rub the crayon over the hole until it fills in and wipe the excess off with a paper towel. Takes about 20 seconds per hole. Seems like a long time. But if you filled the hole with putty and had to sand it would take longer.
I don't really like the soft colored putties. Just because they never dry and will be soft always. The wax will work on finishes up to semi gloss. When you have a gloss finish you need other means of filling holes.
I use touch up products by Mohawk.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 04-25-2010, 10:03 PM   #33
solar guy
naptown CR's Avatar
I use the Mohawk too
try this sometime
take a paper towel that is dampened with paint thinner or mineral spirits.
Wipe the area you are going to fill, Rub the crayon until the hole is filled and then come back with the damp cloth to clean excess
This doesn't react with the conversion varnish and will speed the filling process by at least half.
The first swipe keeps the crayon from sticking to the surface and the second wipes clean easily and smooths out the surface.
Old 04-26-2010, 01:39 AM   #34
Design Build
wallmaxx's Avatar
Trade: well....that was unpleasant
Rewards Points: 2,670
I'm just a framer with limited trim carpentry experience. My first inclination would be to nail it with a 23 gauge pin nailer. Almost invisible.
If that didn't work...I've seen some very cool contact gel glue and aerosol spray combo system that sets in 10 seconds. Done right, that could do a nice job.
Life - Liberty - Pursuit of Happiness
Freedom is a God-given right
2A is my personal guarantee
wallmaxx is online now
Old 04-26-2010, 06:59 AM   #35
LRG WoodCrafting
Leo G's Avatar
23 ga might be a little lightweight. But if you glued everything it would work. I would probably use 18 ga.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 04-26-2010, 09:11 AM   #36
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,838
2P 10 and 23ga pins work good.
CA glues are not for beginners though.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 04-26-2010, 05:31 PM   #37
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 42
does the 2p 10 affect the stain color at all??
goneelkn is online now
Old 04-26-2010, 06:16 PM   #38
LRG WoodCrafting
Leo G's Avatar
It's glue. Take a wild guess.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Winchester (05-05-2010)
Old 04-26-2010, 06:22 PM   #39
alboston's Avatar
Rewards Points: 688
Always helpful as a carpenter that you have done the entire process a few times. On very small jobs I install and finish myself. You learn very quickly not to leave glue, etc on the work. Nothing worse than screwing yourself tends to carry over to not screwing the next trade on the bigger jobs.
alboston is offline
Old 04-26-2010, 06:55 PM   #40
I like Green things
Especially when you leave half the skin on your finger stuck to the piece.
Warner Mill Works
Facebook
YouTube
Question from lawyer trying to help contractor scp Business 52 02-25-2011 01:23 AM
Question for GC re: rough/final cleans britanie General Discussion 6 06-07-2009 06:42 PM
Contract question MACEXCAVATING Excavation & Site Work 4 12-20-2008 09:24 PM
