Question About Painting Z-max Post Bases And Brackets. - Carpentry - Contractor Talk
Old 03-28-2019, 02:17 AM   #1
VinylHanger's Avatar
Rewards Points: 9,652
Can I paint them, and how do I prep them. The outdoor accents weren't in the job budget, but if I can I would like to paint them to make them look a bit better.
I've seen everything from wipe them with vinegar to you need to wait two years so they can build up a layer of zinc protection.
Anyone had success painting them. Post bases, and L brackets mainly.
VinylHanger is offline
Old 03-28-2019, 07:08 AM   #2
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 12,942
Re: Question About Painting Z-max Post Bases And Brackets.
I'm sure you can, as galvanizing something only attracts the oxidation to the coating and not the metal below. (Think galvanized nodes on a boat motor lower unit) So, If it completely enclosed and can't oxidize, the paint would adhere and stay. The problem you would have is down the road if the paint cracks at all it will oxidize behind the paint and peel off.
You would be better off buying their powder coated brackets and painting those.
Take out the papers and the trash
Or you don't get no spendin' cash
If you don't scrub that kitchen floor
You ain't gonna rock and roll no more
Deckhead is online now
Old 03-28-2019, 07:57 AM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,150
I see them painted all the time with limited or no prep and no special paint. The paint generally seems to fare about as good as exterior paint does. When in contact with the ground, not well at all. I'd think a good primer from a rattle can and you'd be in good shape.
Golden view is online now
Rio (03-28-2019)
Old 03-28-2019, 08:19 AM   #4
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,528
Galvanized metal should be cleaned thoroughly with detergent and rinsed with clean water to remove any oil residue from manufacturing. Do not use solvents to clean as they will leave a film . Any oxidation should be removed.
Prime with high quality latex primer and top coat with latex paint. Do not use oil based paints or primers , they are not compatible and will fail .
Alkyd oil paints chemically react with the zinc coating and create a soap like film that will make the paint peel in sheets.
Idothat is offline
The Following 2 Users Say Thank You to Idothat For This Useful Post:
Golden view (03-28-2019), hdavis (03-28-2019)
Old 03-28-2019, 09:26 AM   #5
Normally I would buy them. I am painting everything black. However, there was a budget decision and the powder coated ones came out of the budget.
I have a bad habit of just spending my money and buying the upper level parts anyway, but I am not going to do that on this one. It would be a huge difference, and that would be straight out of my pocket.
I already skimmed the budget down out of my pocket because it will be a very cool project, so I can't put anything extra into it. No matter how much I want to. Even as you know, I still am. I just can't do that with the brackets.
So, as you see in this thread, I have two or three different way to do it. That is the problem I'm finding online.
Old 03-28-2019, 10:16 AM   #6
edward trowelhands
Trade: Diplomat
This is very good information
The Following 2 Users Say Thank You to Golden view For This Useful Post:
finisher65 (04-07-2019), Idothat (03-28-2019)
Old 03-28-2019, 10:41 AM   #7
hdavis's Avatar
Rewards Points: 7,622
There really isn't two ways to do it. Something like a an acrylic bonding primer and acrylic top coats. That's pretty much it.
Prep is whatever is needed, based on condition. Soapy water, soapy water and bon ami, soapy water and sand paper. Roughening the surface obviously improves adhesion at the expense of the zinc protection.
If you want to spend a lot if money, you can use any if the automotive systems for galvanized.. .
hdavis is online now
Old 03-29-2019, 02:41 AM   #8
I ended up buying the outdoor accents. Got a good deal at the local shop, so it made sense. Would have done it anyway, just to alleviate the hassle.
I do need to paint a few heavy L brackets, so I'll use latex on them.
Old 03-29-2019, 03:13 AM   #9
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,796
self etching primer
cedarboarder is online now
Old 03-29-2019, 05:17 AM   #10
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,768
Not all Acrylic bonding primer is exterior. Another good choice for galvanize is SW Procryl primer.
Ohio painter is offline
The Following User Says Thank You to Ohio painter For This Useful Post:
cedarboarder (03-29-2019)
Old 03-29-2019, 09:49 AM   #11
Can I get that in a can? I'd like to rattle can them if possible. Looks better.
Old 03-29-2019, 11:31 AM   #12
Procryl is only in gallons. Not many quality primers in a rattle can for what you are wanting to do.
hdavis (03-29-2019)
Old 03-29-2019, 02:51 PM   #13
hdavis's Avatar
If you upgrade to rustoleun, they have the epoxy primer for their epoxy system in rattle cans.
Old 03-29-2019, 04:42 PM   #14
I was looking on line and it looks like zinzzer 123 will work on galvanized.
It also says use with any topcoat. Can I use 123, then topcoat with a rattle can of satin black rustoleum or krylon?
Old 03-29-2019, 05:17 PM   #15
edward trowelhands
Trade: Diplomat
Not the oil based. It's annoying that there is an oil and water base with the same name.
Old 03-29-2019, 06:00 PM   #16
It's the water based. I have some of the gray primer left from another job.
