Preferred Pocket Door Hardware - Carpentry - Contractor Talk
Old 05-14-2014, 11:30 AM   #1
Dan_Watson's Avatar
Rewards Points: 2,748
Whats your preferred pocket door hardware?
Dan_Watson is offline
Old 05-14-2014, 11:47 AM   #2
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Preferred Pocket Door Hardware
We get ours from Jeld-wen. Sucky doors but the pocket door kit I feel are better than the other kits. Other than the metal encased 1x that is, but that still may not stop drywall screw going through. It is semi assembled so they are more awkward to take to the job site but less time messing with the kit.
CrpntrFrk is offline
Old 05-14-2014, 12:20 PM   #3
pizalm's Avatar
Rewards Points: 830
We use Johnson kits. Can't complain about the quality. Attaching blocking to the "studs" is a pita though.
pizalm is offline
Old 05-14-2014, 01:56 PM   #4
tjbnwi's Avatar
Rewards Points: 4,096
Johnson or Häfele track kits, with bearing rollers.
Johnson or Kwikset pulls/latches. The 2-1/8" round, not the notch in.
tjbnwi is online now
Old 05-14-2014, 06:53 PM   #5
CrpntrFrk's Avatar
Here is a picture of a double. Jeld wen kit.
The Following User Says Thank You to CrpntrFrk For This Useful Post:
Dan_Watson (05-14-2014)
Old 05-14-2014, 07:26 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 10,368
I'm using Johnson's right now. They suck. The rollers seem ok, but the track was not parallel with the wood frame, thus the frame that was set level now has an out of level track cause the door to roll open a few inches. Gonna need to use the latch I'd say. Whenever possible from now on I'll be buying hafele or hettich hardware and constructing my own wall detail.
Morning Wood is offline
Old 05-14-2014, 07:28 PM   #7
SAcarpenter's Avatar
Trade: residential/remodeling carpenter
Rewards Points: 938
Most of our suppliers send out johnson kits. The ones that come in a box with the metal studs. All of our builders have gone to a 2x6 wall so we just use the head track and throw away the metal studs. Some builders wizened up and now order the track only. Then we use lsl 2x4 studs or heavy gauge steel studs for the openings. All this makes for a nice solid opening
You can rest when you're dead
SAcarpenter is offline
Old 05-14-2014, 10:07 PM   #8
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Häfele makes nice stuff.
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
Old 05-15-2014, 05:14 AM   #9
Steve57's Avatar
Trade: general contractor
Rewards Points: 105
I have used Grant Hardware in the past. It works great but is a pain to install. I found a company in Colorado that makes the jamb set, knocked down, using Hafele Hardware. 2 guys installed 5 jamb sets, in one day. It takes 1 guy about a day to install the Grant set up.
Steve57 is offline
Old 05-15-2014, 05:17 AM   #10
3rd Generation
Nick R's Avatar
Rewards Points: 391
I like the idea of steel stud. How do you attach at the floor?
Nick R is offline
Old 05-15-2014, 06:44 AM   #11
tjbnwi's Avatar
My guess would be steel stud track, studs turned with wide side parallel to wall face, screws threw track into studs.
Old 05-15-2014, 06:45 AM   #12
Rewards Points: 938
Drill holes and toe screw
Old 05-15-2014, 07:07 AM   #13
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Assemble your own with pieces. The aluminum I beam and rollers from Heitech (sp?) I find are the best. Frame your own walls.
Chris
Chris Johnson is offline
Old 05-15-2014, 07:18 AM   #14
Dan_Watson's Avatar
Where do you buy it?
Old 05-15-2014, 07:32 AM   #15
tjbnwi's Avatar
Enter your zip code;
http://www.hafele.com/us/products/12380.asp
pocket door panic Kenny B Windows, Siding and Doors 4 02-02-2014 06:20 PM
Tile shower over a pocket door. Uncle-chicken Tiling 12 11-24-2013 10:57 PM
Blum mini pocket Mortiser..... PrestigeR&D Contractor Swap 10 05-22-2013 06:09 PM
Cellular PVC J Pocket TrimBoard joevar1005 Windows, Siding and Doors 1 07-30-2010 09:46 PM
Pocket Door Question CJanssen Carpentry 14 08-07-2009 09:02 PM
