Paint T&g Beforehand? - Carpentry - Contractor Talk
Old 06-07-2020, 09:01 AM   #1
woodspike's Avatar
Rewards Points: 914
i always say " no you can`t " when asked .
but has anyone ever tried painting t&g , and then assembling it?
will the paint bind up in the joints ?
this willl be a very show`y area. i need it to look good when finished.
got a lot of cypress to put up , and its raining a lot these days
one of the guys said " can`t we paint the t&g first?
of course i said no,
i guess i could experiment with a few small pieces
but thought i`d ask since its sunday .
or maybe prime it , since some primer is thinner
or watered down paint of the color i want to use.
, but will that reall do me anything in the long run
i do plan to 2 coat paint it either way again after either way.
woodspike is offline
Old 06-07-2020, 09:05 AM   #2
tjbnwi's Avatar
Rewards Points: 4,468
Re: Paint T&g Beforehand?
Prime with primer tinted the topcoat color.
tjbnwi is online now
META (06-07-2020)
Old 06-07-2020, 09:09 AM   #3
META's Avatar
Trade: General and Trades
Rewards Points: 7,344
This question also depends on the T and G cut, and how much relief is present. Can the cut allow for a paint coating.....etc.
META is online now
Old 06-07-2020, 11:35 AM   #4
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,947
I've done it when the customer wanted stain, so there was virtually no interference between the T and the G.
I'll see if I can find the pics.
rescraft is offline
Old 06-07-2020, 11:45 AM   #5
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 380
We have done it with pine and cedar. If you don't do it ahead of time, you may see some bare areas when the wood shrinks.
Easy Gibson
Warren is online now
The Following 3 Users Say Thank You to Warren For This Useful Post:
Calidecks (06-07-2020), META (06-07-2020), Mordekyle (06-07-2020)
Old 06-07-2020, 02:55 PM   #6
woodspike's Avatar
Rewards Points: 914
i guess i`ll try the tinted prime tomorrow
i have lots of scraps.
like i said , its rained almost every day for the last 2-3 weeks.
i have about 2000 l. feet to put up.
Old 06-07-2020, 03:53 PM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,776
I buy all my tongue and groove prefinished. Never had an issue, however the T&G company could be knived for it.
Mike.
_______________
Calidecks is online now
SouthonBeach (06-07-2020)
Old 06-07-2020, 04:03 PM   #8
META's Avatar
Like Warren said, it's a mess when it shrinks and exposes nude.
META is online now
Old 06-07-2020, 04:24 PM   #9
AustinDB's Avatar
Rewards Points: 1,570
I've pre-stained my t&g ceilings and i was a lot of work in part b/c of the drying space necessary.
if you're painting, I would lay the 16's out so they rack back at an angle and shoot just the tongue's a quick coat. as long as the 1 coat gives you enough coverage without adding thickness. The tinted primer idea sounds like a winner-would there be any concern with difference of sheen between top coat and primer?
AustinDB is offline
Old 06-08-2020, 06:21 AM   #10
RichVT's Avatar
Rewards Points: 1,275
I've polyurethaned miles of T&G before installation. Never had a problem installing it.
RichVT is online now
Old 06-08-2020, 09:14 PM   #11
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,974
I have primed T & G prior to installation with no problems of paint build up. The tinted primer is a good option should there be shrinkage.
Ohio painter is offline
Old Yesterday, 06:08 PM   #12
builditguy's Avatar
Rewards Points: 2,096
I always paint t&g before installation.
If you install it, then paint, then you get some shrinkage and it looks like crap.
Paint beforehand, then get some shrinkage and itís still painted
builditguy is offline
Old Today, 06:22 AM   #13
90%-er
onmywayup's Avatar
Rewards Points: 2,446
I made the mistake of laying a ton of it out on plastic on a driveway and spraying it all ahead of time. Half that stuff curled up like a rainbow as it dried. Dumbass. If you do it ahead of time, find a place to get it done in a climate controlled environment.
onmywayup is online now
Old Today, 08:59 AM   #14
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,117
Bare minimum tint some primer and paint the tongues. That way if (when) it shrinks it won't really be noticeable. You'll still have color on the areas that show up.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old Today, 12:04 PM   #15
GC/carpenter
Calidecks's Avatar
Don't get much shrinkage with kiln dried.
Mike.
_______________
