Osb - Carpentry - Contractor Talk
Osb
Old 12-21-2014, 10:08 PM   #1
nkt's Avatar
Trade: carpenter/framer
Osb
I am installing OSB on the interior walls and ceiling of a detached garage which will be insulated but it will not be heated very often and it will not have A/C. I would like to butt all the panels to each other without spacing but I wasn't sure if there would be an expansion problem. I don't know if it matters, but it will get a coat of paint.
Maybe I wasn't clear. I do not want to have any spacing and I've heard that none is needed, but I want more opinions. I know that spacing is not needed for carport ceilings and soffits when using plywood.
nkt is offline
Old 12-21-2014, 10:23 PM   #2
Donohue Const's Avatar
Rewards Points: 1,736
Re: Osb
I think a framer should know how to space osb!
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
The Following 2 Users Say Thank You to Donohue Const For This Useful Post:
asgoodasdead (12-26-2014), NJGC (12-26-2014)
Old 12-21-2014, 10:34 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 42
Re: Osb
I spaced mine with a 10d finish nail and it's been there 24 years with no problems.
griz is online now
Jaws (12-21-2014)
Old 12-21-2014, 10:40 PM   #4
Yianno's Avatar
Trade: Building Renovator
Rewards Points: 326
Re: Osb
If you wants just use some "h" clips for spacers
Yianno is offline
Old 12-22-2014, 12:26 AM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 46
Re: Osb
Not saying it is right, but can't remember the last time saw a framer here use H clips or space osb.
Randy Bush is online now
Old 12-22-2014, 07:03 AM   #6
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Re: Osb
I framed plenty of houses with OSB sheathing using an 8D HDG nail for spacing. More often than not, the spacing was all but closed up before the WRB went on the walls. Of coarse, working on the coast, the humidity was always high.
In my experience, it's better to space it than to wish you had spaced it.
loneframer is offline
The Following 3 Users Say Thank You to loneframer For This Useful Post:
asgoodasdead (12-26-2014), MIKE ANTONETTI (12-27-2014), Rio (12-27-2014)
Old 12-22-2014, 07:23 AM   #7
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Re: Osb
I think he meant to say he was a 'farmer'.
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 12-22-2014, 09:20 AM   #8
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 76
Re: Osb
I'm planning to do the same in my garage at some point. I plan to space for exapnsion. I'd be scared of it bubbling out in the middle with no room for expansion.
If seeing the gaps bother you, just rip down the scraps of osb & put the strips over the gaps.
pinwheel is offline
Old 12-22-2014, 05:46 PM   #9
Yianno's Avatar
Rewards Points: 326
Re: Osb
Here we usually use them on the roofs. I don't ever recall seeing anyone space osb at all. At the same time I don't think I remember seeing any h clips in a long time either but im occasionally doing roofing, only when certain customers ask or when it's a really small job and i could use th money then subbing the job out lol.
Yianno is offline
Old 12-22-2014, 05:47 PM   #10
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Osb
My buddy didn't space his, and doesn't have a problem. Same deal, insulated garage with a heater for when he needs it
jlsconstruction is offline
Old 12-22-2014, 07:22 PM   #11
pizalm's Avatar
Rewards Points: 838
Re: Osb
I didn't space the sheets in my garage either. No swelling. It's kept above freezing in the winter with a wood stove to heat it when I need it.
Sent from my iPad using Tapatalk
pizalm is online now
Old 12-22-2014, 07:26 PM   #12
Mark122's Avatar
Rewards Points: 464
Re: Osb
i wouldnt be concerned about the spacing.
if i we ocd enough to be bothered by the spacing i would think the strips covering them would bother me even more.
Mark122 is offline
The Following User Says Thank You to Mark122 For This Useful Post:
slowsol (12-22-2014)
Old 12-22-2014, 07:36 PM   #13
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
Re: Osb
My garage interior is sheeted and painted with osb. No spacing was left and no problems in eight years. It is code here to space wall sheeting on the exterior of the houses we frame. We generally use a 2 1/2 inch nail to hold the space.
muskoka guy is offline
Old 12-22-2014, 07:39 PM   #14
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
Re: Osb
Read the stamp on the back side of the sheet.
NKLHD
knucklehead is offline
The Following 2 Users Say Thank You to knucklehead For This Useful Post:
asgoodasdead (12-26-2014), SAcarpenter (12-22-2014)
Old 12-22-2014, 08:02 PM   #15
stacker of sticks
Rewards Points: 590
Re: Osb
What's it say. I don't have a sheet in my living room to read
Old 12-22-2014, 08:12 PM   #16
hdavis's Avatar
Rewards Points: 412
Re: Osb
It will tell you proper spacing. U
sually 1/8".
hdavis is online now
pinwheel (12-22-2014)
Old 12-22-2014, 08:20 PM   #17
slowsol's Avatar
Rewards Points: 2,248
Re: Osb
The last job we did, the roof sheathing came in 95.75" sheets. It was pretty nice.
-John
slowsol is offline
Old 12-22-2014, 08:33 PM   #18
SAcarpenter's Avatar
Trade: residential/remodeling carpenter
Rewards Points: 938
Re: Osb
Osb-imageuploadedbycontractortalk1419297952.408706.jpgOsb-imageuploadedbycontractortalk1419298221.488647.jpgOsb-imageuploadedbycontractortalk1419298236.484648.jpg
I didnt see a support spacing requirement but we do anything over 16" gets an "H" clip
You can rest when you're dead
SAcarpenter is offline
Old 12-25-2014, 05:43 PM   #19
cowboysdad's Avatar
Trade: Carpentry/Remodeling
Rewards Points: 68
Re: Osb
Did a job like this at the end of summer. Didnt space it as per his request otherwise I would have spaced it with an 8d nail. Was out there last week to look at the next project. He has only heated his shop twice so far but hasn't had any issues.
cowboysdad is offline
Old 12-25-2014, 08:35 PM   #20
cturnquist01's Avatar
Trade: Trim and Cabinet Carpentry
Rewards Points: 12
Re: Osb
We use zip board not spaced with 1.5" screen stock on the seams. Get paint and no insulation. Haven't heard of any probs with swelling
cturnquist01 is offline
Tags
osb/framing
