One Way To Flatten A Very Large Slab Of Wood. - Carpentry - Contractor Talk
Old 05-31-2015, 09:22 AM   #1
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
One way to flatten a very large slab of wood.-imageuploadedbycontractortalk1433082017.328989.jpgOne way to flatten a very large slab of wood.-imageuploadedbycontractortalk1433082059.897899.jpgOne way to flatten a very large slab of wood.-imageuploadedbycontractortalk1433082095.731238.jpgOne way to flatten a very large slab of wood.-imageuploadedbycontractortalk1433082113.605604.jpg
Gus Dering is offline
The Following 5 Users Say Thank You to Gus Dering For This Useful Post:
Creter (05-31-2015), KAP (05-31-2015), pinwheel (05-31-2015), Sir Mixalot (05-31-2015), superseal (05-31-2015)
Old 05-31-2015, 09:26 AM   #2
mnld's Avatar
Trade: drywall junky
Rewards Points: 498
Re: One Way To Flatten A Very Large Slab Of Wood.
That's a pretty sweet slab! What's it for?
mnld is offline
Old 05-31-2015, 09:36 AM   #3
Gus Dering's Avatar
Its going to be a desk top.
It's Elm. Never worked with Elm before. Should look nice with a clear coat on it.
Here is the off fall all sanded and detailed to use as a sample.
One way to flatten a very large slab of wood.-imageuploadedbycontractortalk1433082969.071352.jpg
One way to flatten a very large slab of wood.-imageuploadedbycontractortalk1433082994.287589.jpg
heavy_d (05-31-2015), overanalyze (05-31-2015), Robie (05-31-2015), superseal (05-31-2015), Xtrememtnbiker (05-31-2015)
Old 05-31-2015, 11:49 AM   #4
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Would love to keep that as a live edge . Beautiful slab .
Eaglei is offline
Old 05-31-2015, 12:20 PM   #5
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
what's the other way?
Tom Struble is offline
Old 05-31-2015, 01:23 PM   #6
Gus Dering's Avatar
We are keeping both live edges. Concave against the wall to create the cord drop area. The sample is the sample edge as well. A little draw knife work on the sharp edge is all I'm doing.
Tom, the other way is how you would do it.
The Following 3 Users Say Thank You to Gus Dering For This Useful Post:
Eaglei (05-31-2015), pinwheel (06-01-2015), Tom Struble (05-31-2015)
Old 05-31-2015, 07:21 PM   #7
Box Builder
Morning Wood's Avatar
Rewards Points: 10,078
Quick, install that thing before it becomes unflat.
Morning Wood is online now
The Following User Says Thank You to Morning Wood For This Useful Post:
Gus Dering (05-31-2015)
Old 05-31-2015, 07:55 PM   #8
Renaissance Man
superseal's Avatar
Rewards Points: 5,830
Elm is is one of the most beautiful table top choices.
My island in the kitchen is going to be elm, soon as I get around to it.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Old 05-31-2015, 08:17 PM   #9
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 2,581
That's cheating.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 05-31-2015, 08:35 PM   #10
Gus Dering's Avatar
Originally Posted by Leo G View Post
That's cheating.
I paid the price for it.
To do this I created a "route" on a 5 inch thick material, told it to "pocket". The pocket choice basically creates the code to remove all the material within the route. Easy enough.
Then I just offset the Z axis at the machine by the depth I want to take for the next pass and run the same program. This is a setting at the machine that adds a number to every Z command that is in the program. In this case I just kept placing successive negative numbers to the Z for each pass. This is much easier than going back to the office and creating a new program for each pass and I could control the depth for the first and last pass easily. At the end, I had the Z offset by 3/4".
The danger is if you forget to zero out that offset and run another program.
Yes, yes I did just that.
Ran a fly cutting program to clean up the spoils board. The spoils board was about 1/4 inch thick. Fly utter bit was told to go a full 3/4" deeper than that. It got ugly real fast. Ate a circle in the top and limited out the machine. Still don't know if I knocked it out of alignment. We will see tomorrow.
Pretty much sucked the fun out of a Friday afternoon :-)
They say your memory is the first to go. I can't remember what is second.
Old 05-31-2015, 08:49 PM   #11
LRG WoodCrafting
Leo G's Avatar
Usually it's the memory that's 2nd to go. And viagra can't help that.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Gus Dering (06-01-2015)
Old 05-31-2015, 09:09 PM   #12
Box Builder
Ouch man.
Wood framing/furring for suspended drywall ceiling akm Carpentry 30 04-24-2013 09:42 PM
going over existing wood shakes davinci Windows, Siding and Doors 33 07-08-2012 07:09 PM
Flagstone over slab paulbronson Flooring 2 10-26-2009 07:15 PM
large slab in pole barn tomscarpt Masonry 17 04-04-2009 03:41 PM
wood floor over concrete slab dutchlegacy Flooring 9 05-27-2008 09:15 PM
